Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > x1x to x45/x50
x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50.
Old 10-23-2002, 16:50   #1 (permalink)
DrMobile's Avatar
Member: 5932
Thanks Meter: 1,651
SL45 Dead During hearing MP3 Songs.
Anyone can tell me how i can repair my SL45 agian.. Its now dead.. I need step by step solution to repair my phone. again.
My phone is working with MAP writer 4.. I wrote new map to phone but is still dead.. i need link for flasher and flashes for my SL45.
Best Regards,
WaHaB
Old 10-23-2002, 20:20   #2 (permalink)
Drug_Store's Avatar
Member: 15312
Sonork: 100.1576041
Thanks Meter: 1,057
Download flash file (Flx19) at my site or at http://www.odblokgsm.home.sk/downld.htm
Now download All 3/4 2.0.9 at my site
Download Siemens Logger 4 (at least)
Download Siemens Map Maker 4
You may download those at http://www.odblokgsm.home.sk/downld.htm
(But i´m not sure!!!)
Now use All 3/4 2.0.9 to flash your phone.
(check "Write Flash" / "Write Imei" / "Burst Mode (10% faster)" boxes.)
Tip: Problems flashing??? - Change Baud Rate
After you´ve flashed your, use Siemens Logger, and select "Logger", select SL45 on Model list and press "Read Phone".
(Press On in your mobile when it says "Scanning...")
This it takes 5 seconds
When done, press "Save Log", and save it with anyname you want.
Now use Siemens Map Maker 4, and select "Open Log", select the log file you´ve created. Now press "Save Map" and save it with anyname you want.
Now use Siemens Logger 4, select "Write Imei", select SL45 on Model List. Press "Open Map", and finnaly "Write Imei".
This it may takes 10 or 15 seconds.
Now your phone should be working again.
Now update to any version you want. My advise is to update at least to v52, but if you can and know how, update to v54 with JAVA. (52 also as JAVA).
Good Luck
Old 10-24-2002, 07:12   #3 (permalink)
Member: 13108
Hi
If above method cannot repaired, you must repaired by hardware. short circuit capacity power supply for MP3 IC player, this one has 5 leg LAXB IC. Try it and tell me what happen
Old 10-24-2002, 07:50   #4 (permalink)
ppl
ppl's Avatar
Member: 7069
Thanks Meter: 6
Oh NO-too complex:(
Try simple method:Just make log with some Logger ,Then copy&paste phone ID and desired IMEI in a3x map maker!-yes work fine and solve your problem work 100%
WBR:
Plamen
Old 10-24-2002, 21:08   #5 (permalink)
Drug_Store's Avatar
Member: 15312
Sonork: 100.1576041
Thanks Meter: 1,057
Yes he could solve it by rewritting the map, but I think this problems are caused by bad flash. like auto-shutdown...
My advise remains as reflashing the phone with flx19 and then upgrade to any version is the solution.
Anyway, just reanimate him....
Old 10-24-2002, 21:48   #6 (permalink)
Member: 6265
Siemens mapper 4 doesnt work on SL45 unless u have a dongle.
By the way u could join us on PTnet IRC server on #hacksiemens and #gampt.net
Old 10-27-2002, 10:04   #7 (permalink)
DrMobile's Avatar
Member: 5932
Thanks Meter: 1,651
I try to flash my SL45 my times with All 3/4 2.0.9 but i always get error "execution error, or user break".. Please tell me where is the problem... One time i select C45 as phone type in All 3/4 2.0.9 than flashing starts but phone is still dead. when i try to flash with phone type selected SL45 i get this error "execution error, or user break"..
Waiting for reply,
Best Regards,
WaHaB
Old 10-27-2002, 16:32   #8 (permalink)
Drug_Store's Avatar
Member: 15312
Sonork: 100.1576041
Thanks Meter: 1,057
try to change baud rate. Or use other version of all 3/4, but the 2.0.9 works fine for me....
Old 10-28-2002, 06:15   #9 (permalink)
DrMobile's Avatar
Member: 5932
Thanks Meter: 1,651
I try to change Baud rate but problem is same.
Best Regards,
WaHaB
Old 10-29-2002, 06:01   #10 (permalink)
DrMobile's Avatar
Member: 5932
Thanks Meter: 1,651
My SL45 is still dead. please tell me how i can repair it,
Best Regards,
Wahab.
Old 10-29-2002, 07:21   #11 (permalink)
UHK
Member: 13737
Sonork: 100.100725
Thanks Meter: 193
hello MR wahab !!!!
try to flash with unisiemence its best tool for flash
or
http://www.eakmobile.com/dlpages.html
try above link
or contact me i have sl45 v52 flash file with software and i can upgrade your sl45 into sl45i with java activator
regard
usman hk
Old 10-30-2002, 02:44   #12 (permalink)
Siemens man's Avatar
Member: 3925
Thanks Meter: 21
hi guys
i have sl45 dead. i'm need flx file.i can't download sl45_19_01.flx. link is very slow. please help me anybody. take me please sl45_19_01.flx file.please mail me. [email protected]
thank you
Old 10-30-2002, 20:49   #13 (permalink)
Drug_Store's Avatar
Member: 15312
Sonork: 100.1576041
Thanks Meter: 1,057
Come on people learn something up !!!
Read old posts.
Download v19 flx at: http://www.odblokgsm.sk/download/
I guess that to repair with Unisiemens, you´ve got to have a backup from your or another SL45 (size: 6MB) and write eeprom right after (also a backup from a SL45). Using normal flash files, you may need Log calculation (*.lc) and map file.
Good luck to everyone...
Old 10-30-2002, 20:53   #14 (permalink)
Drug_Store's Avatar
Member: 15312
Sonork: 100.1576041
Thanks Meter: 1,057
http://www.odblokgsm.sk/download/ this works properly for me...
Try to use my site http://lavdate.dhs.org/Drug_Store/ but it´s very unreliable...
Old 10-31-2002, 11:56   #15 (permalink)
Member: 3925
Thanks Meter: 21
hi guys
i'm again. i can't download flx file from this site. http://www.odblokgsm.sk/download/ link very slow. please tell me other good site.
thank you
applications,punjabi stuff,mp3 songs,themes,Smart Movie 3.11 cracked,6600,7610,6630 .::SONU::. Nokia Multimedia 137 06-07-2011 06:00
Which Software Used To Hear Mp3 Songs In 1600? zonetrichur Nokia Multimedia 0 12-28-2006 05:00
Is Any Solution To Hear Mp3 Songs From Bluetooth Headset; petcy GSM Mobile Links 0 12-12-2005 13:32
how to a wav or mp3 song as the phone ringtone on my p800? infogsm Sony Ericsson Media, RingTones, Games 3 10-26-2004 12:17
Page generated in 0.47373 seconds with 8 queries
