Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > x1x to x45/x50
x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50.
Old 07-03-2002, 02:03   #1 (permalink)
Member: 6653
Sonork: 100.1597550
Thanks Meter: 26
SL45 - EEPROM data damaged
How to repair ? please post link for good soft or send to me ( [email protected] )
Old 07-03-2002, 02:40   #2 (permalink)
Member: 1408
Thanks Meter: 39
Re: SL45 - EEPROM data damaged
Sorry to rest members , just some words in russian
Õîðîøèé ó òåáÿ íèê , ñï-ËÎÕ ..
WBR
Crew
Old 07-03-2002, 04:54   #3 (permalink)
Danchik's Avatar
Member: 5014
He said to read old posts
Old 07-03-2002, 05:51   #4 (permalink)
Member: 8734
Send me a log of yor phone, and ill help you
Old 07-03-2002, 13:18   #5 (permalink)
Member: 6653
Sonork: 100.1597550
Thanks Meter: 26
MAP not wanted, if exist. I don't write map to phone, at say's EEPROM data damaged. How to recovered eeprom ?
Old 07-04-2002, 03:13   #6 (permalink)
Member: 8734
Still need log, send it to me i will re-construct eeprom for you...
Old 07-04-2002, 04:54   #7 (permalink)
Mobileman_hu's Avatar
Member: 3097
Thanks Meter: 30
Hi!
I had the same problem a few days ago and I solved it:
Just use All 3/4 Siemens 2.5 cracked by Xak, and loadthe .flx file then mark writw flash, write IMEI, Burst mode, them click on Init mobile. eeprom area will be ok, IMEI will be ok, then phone will turn on just for a second. After this you need to upload a MAP file to the phone and thats it!!!
This is working 100%
Old 07-04-2002, 14:07   #8 (permalink)
Sher's Avatar
Member: 6837
Thanks Meter: 5
Hi sp-lox,
i had the same problem with SL45 ,
I USED THE MAPPER , but it gave error ËEPROM DAMAGED"
then i FLASHED the phones with ALL 3/4 by PRO
after flash the phone switched on !
i repaird 4 SL45 by this method
BEST OF LUCK
Best Regards
Old 07-06-2002, 05:53   #9 (permalink)
Member: 5292
Thanks Meter: 5
Where I can make .FLX files for using with
All 3/4 siemens software
Old 07-06-2002, 05:54   #10 (permalink)
Member: 5292
Thanks Meter: 5
I needed for S45
Old 07-06-2002, 22:59   #11 (permalink)
Member: 11033
Dear friends, where I can find .FLX for SL 45?
May be somebody send it to ME
Thx
Old 07-07-2002, 03:29   #12 (permalink)
Member: 13113
Could somebody Send me a s45 flex file...
[email protected]
Old 07-07-2002, 05:25   #13 (permalink)
Member: 7743
Here
All Flx flash :
http://www.odblokgsm.sk/download/
Old 07-07-2002, 06:44   #14 (permalink)
Member: 13113
They won't work ...do i do somthing wrong??
Old 07-07-2002, 12:21   #15 (permalink)
Member: 11033
Re: Here
Originally posted by s3nt4
All Flx flash :
Thanx you
eeprom data damaged marici24 x1x to x45/x50 10 06-17-2002 21:02
SL42e EEPROM data damaged KATOUE x1x to x45/x50 9 06-07-2002 05:53
S40 EEPROM data damaged Jebek x1x to x45/x50 7 05-28-2002 06:25
what is the solution for EEPROM data damaged Sher x1x to x45/x50 6 03-24-2002 07:48
eeprom data damaged? What can i do? Proggy x1x to x45/x50 6 01-16-2002 14:39
Page generated in 0.23717 seconds with 9 queries
