x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
09-28-2005, 17:01 | #1 (permalink) |
Junior Member Join Date: Sep 2005 Age: 45
Member: 185139 Status: Offline Thanks Meter: 0 | Sl45 turns off in car comfortkit http://sl45.*****s.net/ and installed it. Then the problem started. Phone works just fine except in the car use. I have now 512mb mmc card and it also works just fine. Comfort kit works with the original flash which was 2.XX something, but it did not accept 512mb card. Thats why I upgrated it. Any ideas for the prolem? I tried to find some answers but no luck. I have two of these SL45 phones and I tried the one with older flash and it works just fine. Then i flashed it also and the same problem occurs. Also tried two different batteries. These phones are both SL45, not SL45i, if thats makes a diffrence. Should the slik56 even be installed to SL45 or is just for a SL45i model? Last edited by visale; 09-28-2005 at 21:20. |
10-14-2005, 09:50 | #4 (permalink) |
No Life Poster Join Date: Mar 2004
Member: 60520 Status: Offline Thanks Meter: 0 | Hm... If you've upgraded your SL45 to v56, you still don't have activated Java, do you? It sounds quite nonsense, but maybe if you activate Java in your SL? I can also send you some EEPROM blocks that might bring your phone to work. |
10-14-2005, 16:09 | #5 (permalink) |
Member: 185139 Status: Offline Thanks Meter: 0 | Thanks for replying! I dont know what the eeprom is. Flashing is the only thing that I've done to my phone. I havent activated java, because I havent needed it, actually dont know what to do with it! Now I have been trying to downgrade my phone. First to v54. Works just fine, except in car use. Neither works v52. Just flashed v43, haven't tested yet. Ill test it as soon as my girl friend retuns with my car... But If the phone starts to operate with one of the oldest flashes, it certainly will not accept my new 512mb mmc! That was the only reason why i flashed it! I would prefer the car comfortkit use more than the mp3 player... The phone also turns of if I activate my SL45 audio recorder in car use! Does this help to isolate the problem? http://www.inet.hr/~tofabija/Softwer...ishVersion.zip I downloaded that file. Is there something that might go wrong? Should there be made some sort of back up and how it is done? What are those BAck up Blocks or restore Blocks? Edit: v43 and the problem continues. It has to be something else than just a version issue. Did flashing erase/damage something important? Edit2: activating of java didnt help either. could the flaw actually be in my car kit? But the problem did occur after flashind. I would like to trie v23, but flasher wont work with Win XP. Last edited by visale; 10-15-2005 at 11:27. |
11-02-2005, 21:06 | #6 (permalink) |
Member: 185139 Status: Offline Thanks Meter: 0 | I also noticed that when Im in: Calls Dialled folder and then I press the Right side soft key called "View" the phone also turns off! Very strange. Can anyone help me somehow how to try eliminate this problem? Could it have something to do with the battery? |
11-02-2005, 21:26 | #7 (permalink) | |
No Life Poster Join Date: May 2003 Location: GERMANY Age: 49
Member: 27745 Status: Offline Thanks Meter: 0 | Quote:
11-03-2005, 16:16 | #8 (permalink) |
No Life Poster Join Date: Oct 2003
Member: 42457 Status: Offline Thanks Meter: 1 | @trustkill He wrote that he downgraded to v54 and v43 so it isn't a patch problem. @visale It could be an error in eeprom area imho.... what method do you used to appy the downgrades? Update via WinSwup? or via a Fullflashfile? If you used WinSwup your EEProm area keeps original and then I'm 100% sure it's an EEProm error. Try this. 1) Make an update of your Fullflash and from your EEProm area with V_Klay 1a) If anything goes wrong you can easily reactivate your phone by flashing 2) Ask rc-flitzer for his EEProm files (they are good) 3) Download Skylords EEProm - tool from here 4) Download Freia from here 4a) Freia is needed for unlocking your phone 5) Start Freia and make backup of your battery paramters 5a) Select phone modell: Siemens SL45 5b) Click on Miscellanous functions 5c) Backup battery Paramters 5d) Turn of your phone 5e) Click OK in Freia 5f) Press Short Red Key... 5g) Read Success message - Battery Paramters are saved into Freia folder 6) Start EEProm Tool 6a) Click Connect to phone, Press Red Button short (same procedure as you did in Freia) 6b) On left side select open file 6c) Open rc-flitzers .eep file (Only this! it's the only one) 6d) mark all entries in list in click right arrow in EEProm Tool Main Window 6e) mark all entries in right windows now 6f) Click write to phone 7) Start Freia again 7a) Click Unlocking functions 7b) Click Direct unlock no map saved 7c) Enter your IMEI into IMEI window 7ca) IMEI is found if you remove battery - there's a little sticker 7cb) IMEI is wrote like this: 123456-12-1234567 7cc) If you enter IMEI in Freia you can't enter last digit. That's okay, last digit is checksum 7d) Click okay - press red button...... 8a) Start Freia again 8b) Click on Misc. functions 8c) Click on Restore battery paramters 8d) Cick okay.... Red button..... 9) FINISH This is an exclusiv todo and howto and very very save imho. If this doesn't help well then try to upload a complete EEProm via V_Klay. But then you've also to restore battery paramters to avoid some problems with standby time and indicator level. And you need also to make an unlock. It looks a bit difficult but it isn't. You can't destroy your SL45 by flashing or unlocking - don't be afraid |
11-04-2005, 18:26 | #9 (permalink) |
Member: 185139 Status: Offline Thanks Meter: 0 | Thanks Cyperghost! I'll try that as soon as possible if that would cure my problems! WinSwup is the program I have used, nothing else. But that was quite enought to start having some problems. Phone also turns occasionally off even thought the battery is not dead yeat. I have cleaned the contact surfaces but thats not the case. |
11-08-2005, 11:18 | #10 (permalink) |
Member: 185139 Status: Offline Thanks Meter: 0 | Now my eeprom has been changed. Does it differ in any way to the original? Using the eeprom tool two lines could not be written. Lines 69, acoustic... and 73, ringtonemelodies... Is this a problem? And what is that acoustic thing? I havent been able to test the phone yet. Dont have the car right now, but the phone still works and thats a good thing though! |
11-08-2005, 12:52 | #11 (permalink) |
Member: 185139 Status: Offline Thanks Meter: 0 | Dammed! Still the stupid thing turns off! What next? Should I do the battery teaching thing? How is that done..? Search might help me on that one.. Edit: Cant find topic that contains SL45 battery solutions... help... Edit2: The phone has gone worse after I did that eeprom change. Now in car use I cant even start the phone if its attached to car kit. It turns of before I can apply my PIN-code. Also it seems that it turns off much easier than before, almost nothing can be done in car use. And when the phone turns off it just crashes. It doesnt indicate that battery is low. It doesnt do "soft stop" at all. Just like battery was removed. I also noticed that it occasionally turns when Im receiving a phone call and then it indicates Low Battery and does the soft stop procedure. Battery indicator on display looks normal, according to reality when the battery was recharged last time. While listening mp3, no problems is occured. You can listeng several hours straight through and the phone stays on!!! What is my phones problem !!! Last edited by visale; 11-10-2005 at 11:08. |
11-14-2005, 23:32 | #13 (permalink) |
Member: 185139 Status: Offline Thanks Meter: 0 | First of all I upgraded my v.23 to v.56 with winswup following instructions. Successfully, according to the program. Also copied new mmc contence. Phone started to turn off in car use, everything else was normal. Then I upgraded my second phone, yes I have two of these, v.23 to v.56 with winswup. I Used the same mmc card that I previously upgrated. Phone started to turn off in car use, everything else was normal. The stranges thing is that neither phone wont work in my car after flashing. Once I were able to make a call using the carkit. Only once. Have no idea why it worked, but o'boy I was glad! Then I contacted this forum for help. And I tried do downgrade my phone gradually by using winswup. No good. Then I followed your instruction by the letter how to change eeprom and back up my battery settings. As it says in your instructions. Phone seems to be gettting even worse. It turns now off without any reason at all. Battery indicator is reasonable. It says full. And it is logical in every case. But it keeps turning off suddenly or says "battery empty" when receiving a call. What is pa? Power amplifier? Read something about that? The eeprom was the one you suggested. In Freia the procentual indicator showed 0% all the time during these processes, but it did indicate Ok in the end of every process. Tomorrow I use my old battery, the original 650 mAh and that lasts about 24 h. We'll see if it crashes also... Battery is by the way Insmat 750 mAh and it is few months old. Old Siemens1000 mAh died completely, wouldnt even tried to start the phone. Still volt meter says 3,6V... Thats why I bought another phone, but it was the battery after all. Thought that my pnone died! Update: I tested the old battery but it didnt last as long as I remembered. 8 hours or so, little mp3:s also. During that 8 h hour period I didnt receive any phone calls. Then I changed the Insmat back. As soon as changed the battery I received a call and phone started to whining about the battery... Still u can listeng mp3's. And make a new right after the "battery empty" message. Last edited by visale; 11-16-2005 at 12:08. |
11-16-2005, 17:28 | #14 (permalink) |
Member: 42457 Status: Offline Thanks Meter: 1 | Buhh... Go to this link http://eh.student.utwente.nl/~landy/ Username: mobile PW: elibom and download complete fullbackup from SL45i.... Start at point 7 from the list |
11-16-2005, 20:18 | #15 (permalink) |
Member: 185139 Status: Offline Thanks Meter: 0 | Buhh??? What does that mean? On that page I couldnt download anything... "Service Temporarily Unavailable The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later" Maybe later then? Full back up? Does this mean that 3,3 MB flash file or maybe something more? Eeprom? Edit: I cant download those files! "Service Tempora..." I've been using my second phone and it works much better. Doesnt work in car, but it stays on and doesnt whine about the battery. Last edited by visale; 11-17-2005 at 14:15. |
SL45 turn off longtime. Should i turn off it by remove batt or without remove batt? | ^NaT^ | x1x to x45/x50 | 6 | 12-06-2005 03:19 |
Set pernament password for "Password for Functions Access" but SL45 turn off. | ^NaT^ | x4x, x5x Flashpatching | 1 | 05-10-2005 07:21 |
Nokia 3310 is turning off in talk | invision | Nokia Hardware & Hardware Repair | 12 | 02-27-2005 04:06 |
A 3618 turn off in the mesages | uni_gsm_tech | Sony Ericsson | 1 | 08-20-2003 10:23 |
HTML turned off in signatures? | laxxe | Board, Server and Login Problems/Support | 3 | 03-09-2002 05:41 |
