SL45i dead - Siemens Sensor Tools Cause: Help needed Hello everyone! My friend's phone is dead - he tried to make changes (calibrate the battery) in Siemens Sensor Tools, and f**ed it up. SST shows an error window with text: Unable to read Eelite BlockId=67 Info; ( www.darus2.republika.pl/1.jpg ) Could someone tell me, what the hell is going on? Swup, new eeprom, map doesn't make any effect. Best regards Phalanx |
I faced this problem before. This block could be corrupted. I'm sure that new EEPROM will fix the problem. |
Yes...a new eeprom will fix this. I have had this problem heaps of times. Upload a new EEPROM, and then use KSIE to change the IMEI. If this doesn't work, then use a fullflash and change the IMEI with KSIE. If this doesn't work then there's something much more wrong than simply a corrupted blk. |
I think you should backup your own EEPROM so that you don't need to write new MAP anymore. |
Hi , I think the problem in some of block on your eeprom compare your eeprom whit eeprom tools www.siemens-club.ru end seen block 60 to 70 BR |
All is now ok, thank you, guys for your help. |
Hi Phalanx, Please would you advise how you corrected the battery problem? I have similar problem! Cordially, [email protected] |
I will try to answer... To calibrate the battery you must measure the voltage of the battery with Voltmeter at 2 stages: 1) when the battery is empty. 2) when the battery is full Then you should enter these values into the fields: Vbatt1 Vbatt2 and then click the button: "Calculate SpgY03V and SpgY04V" and "Write Phone" and it should be done! You should not touch the other values as you can go out of range easily -> damages the eeprom -> :( BUT I have never done this procedure as I have no problem with my batt., I only read about it in one of the Czech forums. Perhaps in the future when I buy a stronger battery.... (I guess you could use the patch: "Drawing signal level in dB and battery level in mV" to measure the Voltage, but do not know how accurate it is) |
But what do we write in the VbattDSP1 VbattDSP2 fields because in order to calculate spgy03 and 04v we need those values too |
VbattDSP1 + VbattDSP2 fields I have found out that these two values VbattDSP1 + VbattDSP2 which are needed in order to perform the calculation are corresponding to the values Vbatt1 + Vbatt2. They should be the same except that these should be in digital form (Vbatt1 + Vbatt2 are analog values) so the phone can uderestand it (I guess that it needs to be run through phone`s A/D converter - bur still do not know how). This method of battery calibration should be similar to the one done at Siemens. |
