Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > x1x to x45/x50
x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50.
Old 08-07-2003, 16:16   #1 (permalink)
Member: 24832
SL45i dead - Siemens Sensor Tools Cause: Help needed
Hello everyone!
My friend's phone is dead - he tried to make changes (calibrate the battery) in Siemens Sensor Tools, and f**ed it up. SST shows an error window with text: Unable to read Eelite BlockId=67 Info; ( www.darus2.republika.pl/1.jpg ) Could someone tell me, what the hell is going on? Swup, new eeprom, map doesn't make any effect.
Best regards
Phalanx
Old 08-07-2003, 16:23   #2 (permalink)
Member: 22487
I faced this problem before. This block could be corrupted. I'm sure that new EEPROM will fix the problem.
Old 08-08-2003, 06:14   #3 (permalink)
Member: 33336
Yes...a new eeprom will fix this.
I have had this problem heaps of times.
Upload a new EEPROM, and then use KSIE to change the IMEI. If this doesn't work, then use a fullflash and change the IMEI with KSIE.
If this doesn't work then there's something much more wrong than simply a corrupted blk.
Old 08-08-2003, 06:39   #4 (permalink)
Member: 22487
I think you should backup your own EEPROM so that you don't need to write new MAP anymore.
Old 08-08-2003, 07:42   #5 (permalink)
Member: 25696
Hi ,
I think the problem in some of block on your eeprom compare your eeprom whit eeprom tools www.siemens-club.ru end seen block 60 to 70
Old 08-08-2003, 10:23   #6 (permalink)
Member: 24832
All is now ok, thank you, guys for your help.
Old 06-20-2004, 12:40   #7 (permalink)
Member: 69547
Hi Phalanx,
Please would you advise how you corrected the battery problem?
I have similar problem!
Cordially,
[email protected]
Old 06-20-2004, 14:27   #8 (permalink)
Member: 66722
Phalank my problem it's same with u....
please send me
[email protected]
Old 06-24-2004, 14:56   #9 (permalink)
Member: 26318
I will try to answer...
To calibrate the battery you must measure the voltage of the battery with Voltmeter at 2 stages:
1) when the battery is empty.
2) when the battery is full
Then you should enter these values into the fields:
Vbatt1
Vbatt2
and then click the button: "Calculate SpgY03V and SpgY04V" and "Write Phone"
and it should be done!
You should not touch the other values as you can go out of range easily -> damages the eeprom ->
BUT I have never done this procedure as I have no problem with my batt., I only read about it in one of the Czech forums.
Perhaps in the future when I buy a stronger battery....
(I guess you could use the patch: "Drawing signal level in dB and battery level in mV" to measure the Voltage, but do not know how accurate it is)
Old 06-28-2004, 01:29   #10 (permalink)
Member: 23520
Vbatt1
Vbatt2
But what do we write in the
VbattDSP1
VbattDSP2 fields because in order to calculate spgy03 and 04v we need
those values too
Old 08-02-2004, 17:14   #11 (permalink)
Member: 26318
VbattDSP1 + VbattDSP2 fields
I have found out that these two values VbattDSP1 + VbattDSP2 which are needed in order to perform the calculation are corresponding to the values Vbatt1 + Vbatt2. They should be the same except that these should be in digital form (Vbatt1 + Vbatt2 are analog values) so the phone can uderestand it (I guess that it needs to be run through phone`s A/D converter - bur still do not know how). This method of battery calibration should be similar to the one done at Siemens.
can't use siemens sensor tool -- help :)) uimuha Siemens-Benq Flash Patching 4 10-15-2004 07:11
SL45i DEATH WITH SENSOR TOOL !!!! PYCON x1x to x45/x50 2 07-17-2004 20:05
Help! Siemens sensors tool 1.3! morzsi x1x to x45/x50 3 11-06-2003 21:05
Siemens Sensor Tools Help - Battery empty Problem stigma x1x to x45/x50 4 03-15-2003 12:10
Need blk-File for Siemens Sensor Tool for SL45 vikado77 x1x to x45/x50 4 07-09-2002 23:04
Page generated in 0.32360 seconds with 8 queries
