x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
08-21-2002, 07:08 | #1 (permalink) |
Freak Poster Join Date: Jul 2001 Age: 48
Member: 5375 Status: Offline Thanks Meter: 1 | solution for c45 which can not logged by max logger 100% solution is werry easy u need detect corect ID from phone detecting ID can IDB reader too but u must replase bites e.g. if from IDB reader ID is 12 34 56 78 for max logger ID will be 78 56 34 12 after detecting ID u must creat original map open original map with max logger choise c45 when map is opened than choise sl45 and write map u will get 100% unlocked and repaired phone |
08-21-2002, 14:58 | #3 (permalink) |
Freak Poster Join Date: Feb 2002 Location: Jakarta
Member: 9261 Status: Offline Thanks Meter: 0 | explain more detail..... you mean IDB or LDB ? and what is max logger ? my problem is phone can't create log file (indicator stop in logging to phone). i use publc logger all version (3.0 up to 4.0) |
08-21-2002, 15:29 | #4 (permalink) |
Member: 5375 Status: Offline Thanks Meter: 1 | @ Hary sorry yes it is LDB file u can also detect ID with public logger 4.2 but u must read log with sl45 when u will detect ID u must create c45 map with corect ID and Imei after generate right c45 map open public logger 4.2 choise c45 open calculated right map when map is opened choise sl45 and write imei it is all post resoult Last edited by GURO; 08-21-2002 at 15:44. |
can not login to mxkey logger | aneeshkumar | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 02-02-2010 15:07 |
Unlock for Motorola phones which you can not unlock by codes... | Denis | Main Sales Section | 0 | 10-24-2009 15:31 |
Unlock for Motorola phones which you can not unlock by codes... | Denis | Main Sales Section | 0 | 10-11-2009 18:42 |
how can i flash motorolla phone which can not enter TEST MODE? | kwasasco | Motorola P2k | 1 | 07-12-2008 08:50 |
Can not log C45 | joeblack | x1x to x45/x50 | 6 | 05-26-2002 22:57 |
