x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
06-01-2002, 18:21 | #2 (permalink) |
Freak Poster Join Date: Apr 2002 Location: Macedonia Age: 43
Member: 10742 Status: Offline Thanks Meter: 13 | hi my friend dont worry..if you lock your phone you will need map file ....he will reset all codes try 1111... i thing its that ....i can help you but after Tuesday... good day my friend |
06-01-2002, 19:58 | #3 (permalink) |
Junior Member Join Date: May 2002
Member: 12464 Status: Offline Thanks Meter: 0 | ThankU my savior!! Ok but if now it locks I'll be without telephone??(It locks all??) If so I'll wait 4 Thusday Another little problem I've read about MAP file but up to now I've not been able to understand....hmmm Do I need another cable??? and if so where have I to find it???? What's the program I need??? Can I make by my own it???? Sincerely thanking U .... |
06-01-2002, 20:12 | #5 (permalink) |
Member: 10742 Status: Offline Thanks Meter: 13 | HI.. YES you need data cable ..then download loger to make log from your phone ..that log you will send to me and i will calculate map file to reset all lock..good day my friend..mail me if you need help |
06-02-2002, 14:50 | #6 (permalink) |
Member: 12464 Status: Offline Thanks Meter: 0 | Sorry to brake U again but...the link you've send me is "broken" so I've found in the same site a program called "public30" is it the same?? Where can I find the data cable?????????? Thanksalotbyebye |
06-06-2002, 03:26 | #7 (permalink) |
Major Poster Join Date: Apr 2002 Location: france Age: 39
Member: 11314 Status: Offline Thanks Meter: 0 | Hi there mate ! Actually, you have to MAKE your own new cable to map your phone.. No, don't worry, it's not that hard, even I managed to make my own cable and unlock my S45 If you have a RS-232 cable, there is an easy way to make your cable, with the original Siemens cable, if you see what I means.. I had to make my cable with the original cable to unlock the phone, and I had to be able to re-use it afterwards as a normal cable. There is ONE easy way to do it. Acutally, you have to put 4 volts between pin 1 and pin 4, so that the chip in the serial plug gets a 3~4 V input.. With some phones, 4 volts come out of pin 4 of the phone, but on Me45, S45 etc, it doesn't work.. So, what I suggest you to do is : 1 Cut you cable in two, 2 put all the wires back together again, 3 take two AA batteries, link them together, 4 Put the - on the black wire (=pin 1 = ground) and put the + on the GREEN wire (=pin 4) The point is that the 4 V go to the serial plug, not to the telephone.. So, don't link the GREEN wires back together at step 2, and but the + of the AA bateries on the Green wire going to the serial computer plug. 5 log with a logger 6 post a map file request 7 load map to phone 8 you are done !!! Well, that works with a Rs-232 serial plug. Lots of luck mate If you have any questions BEFORE cuting your cable, just ask. Oh yes, and when you are finished, just put all the wires back together, and you will be able to use your cable just like a normal RS-233 cable. Greetings ! |
HELP!!!! phone locked HELP HELP!!!! | KALINE20 | Sony Ericsson | 1 | 03-12-2010 19:05 |
Sharp TQ-G400 Phone lock help | bre786 | Sharp | 0 | 01-24-2002 09:57 |
