Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > x1x to x45/x50
x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50.
Old 03-24-2001, 23:40   #1 (permalink)
Member: 3792
Post totally dead c35
I woke up in the morning and the phone was turned off, know it don't power on. any ideas????
Old 03-24-2001, 23:56   #2 (permalink)
Member: 2517
Wink
Try flash your phone......
Old 03-25-2001, 00:54   #3 (permalink)
Member: 1715
Post
Hi there..
I once had the same problem.. battery went down while i was looking at the phone, phone powered down, and never went on ..., battery was dead !, try to borough a battery from someone else's phone to try it....
Greetinz Timitiz
Old 03-25-2001, 02:23   #4 (permalink)
Member: 3792
Post
the battery voltage is 4.3volts
Old 03-25-2001, 02:54   #5 (permalink)
Member: 3792
Post
how do I flash a turned off phone?
Old 03-25-2001, 11:32   #6 (permalink)
Member: 3792
Question
error connecting to mobile with egold.
what can I do?
Old 03-25-2001, 22:16   #7 (permalink)
Member: 1630
Cool
use swup and *xbi or run *.exe and wait....and confirm the question with "YES" and then push POWER ON as usual.....
Old 03-27-2001, 20:08   #8 (permalink)
Member: 3747
Hi!
Use All25 or All26. This is good progs...
And flash original (or small) version U phone... Like use *c3r files.
Use this soft I repair more dead phone...
Only full charge battery on ahother phone!!!
Old 03-27-2001, 21:05   #9 (permalink)
Member: 2553
Thanks Meter: 3
Post
hi,
flashing your phone is surely the wrong thing to do, why should you flash a phone which turned itself off, you should flash it only if the flash was erased or you want to upgrade it or if you get a message like Wrong software by turning on the phone.
I had the same problem with a S25 vers 42 and the problem was solved by using another Battery, after todays i put the old battery in the phone again and it was and is still working fine.
WBR
Meam
Old 03-28-2001, 09:16   #10 (permalink)
Member: 3756
Thanks Meter: 5
Meam is correct....
Why flashing a phone if you haven't fooled arround with the phone...just replace the battery and see if it's ok...if not, then consider flashing your phone....
Old 03-28-2001, 11:50   #11 (permalink)
Crazy Poster
Member: 2743
Post
And if the phone still in the waranty (or not) why don't you make a round to your siemens representation. They sould help you!
Bertola
Old 03-29-2001, 23:29   #12 (permalink)
Member: 3792
Post
no warranty and I have tried another battery
Old 03-30-2001, 11:49   #13 (permalink)
Crazy Poster
Member: 2743
Unhappy
It seems to be a hardware problem, I don't see any solution unless going to siemens...
Maybe any one have a beter idea.
Bertola
Old 03-30-2001, 15:09   #14 (permalink)
Member: 3638
Post
Maybe your phone earlier was moisten or you made conccusion (by accident). If it was first case, try to put your phone into a sugar or salt (no kidding such things take out moisture, i have expierienced by myself with NOKIA 3110) if it was second case, try to repair it by yourself, of course if you know something about repairing mobiles. If you want some help, i will try to help you.
Good luck,
GSMdEvil
Old 03-31-2001, 10:41   #15 (permalink)
Member: 3792
Post
by the way, the charger was connected when the phone had died. do you have any suggestion what piece of hardware I shall chieck?
C35 Totally Dead prazet x1x to x45/x50 2 12-14-2002 08:44
Steel dead c35 Roman x1x to x45/x50 4 07-27-2001 02:06
Dead C35 TITO x1x to x45/x50 4 07-23-2001 14:20
dead C35 by Martech v 1.7 sedlin x1x to x45/x50 3 06-05-2001 22:23
DEAD c35 phones ... makona x1x to x45/x50 1 03-22-2001 11:39
Page generated in 0.21714 seconds with 10 queries
