x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
03-10-2004, 12:35 | #1 (permalink) |
Freak Poster Join Date: Jun 2003 Location: INDONESIA Age: 56
Member: 31339 Status: Offline Thanks Meter: 5 | Sl45 Memorycard Problem how to make sl45 accept MMC 32 mb other than original siemens, I mean MMc that before using in nokia, cause I have MMC 32 but if i inserted to phone and try to play Mp3 it says insert multimedia card, if i use original one it can play. thanks best regards |
03-10-2004, 13:49 | #2 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Croatia/Zd Age: 43
Member: 26670 Status: Offline Thanks Meter: 5 | check contacts. it should work anyway. Never mind that is not originall from siemens... I've used at my sl45i mmc from kingmax and other brands... |
03-11-2004, 09:23 | #4 (permalink) |
Insane Poster Join Date: Sep 2003 Location: UAE
Member: 40325 Status: Offline Thanks Meter: 0 | Well the first question is, r u using the mmc card as it was from nokia.. i mean, did u format ur mmc as it was having nokia folders and info.. if not then first thing is tht u need to format the mmc card, and install all the default folders of siemens and it shud work prefectly fine.. |
03-11-2004, 14:23 | #5 (permalink) |
Member: 31339 Status: Offline Thanks Meter: 5 | actually I'm not only try 1 MMC but many MMC from 16mb,32,128,256mb, AND it doesn't work in this Hp, only work if using the original one, the MMC and HP contact is good, and before the MMC is formatted (already try fat 16, and fat 32), and the last thing I do is clone the working MMC using Winhex, and doesn't help too. please more heellllllllpppppppp????? thanks retgards |
03-12-2004, 09:44 | #7 (permalink) |
Insane Poster Join Date: Jul 2003 Location: Sydney, Oztralya
Member: 36064 Status: Offline Thanks Meter: 0 | @elwan: strange.. believe me, ANY mmc should work fine with SL45. i use kingmax, and i sold my original mmc long time ago. do you hev memory card reader? try format the mmc, then copy the backup of your contact list and all the folders... are you sure the mmc is working in the nokia? maybe the mmc is in damage condition. |
03-18-2004, 10:46 | #9 (permalink) |
Member: 31339 Status: Offline Thanks Meter: 5 | yes, I have MMC card reader ver1.0 and ver 2.0, and I try formatted the MMC using this 2 card reader, and Under win98 and XP,using fat 16, and 32,still no help, in computer and any nokia that have MMC 3650,3660,9210 it's working, but in siemen sl45 not, other siemens(my friend) not accept too, could it be the "software vers" of the phone? mine is LG1 ver 16, what is your friends? thanks regards |
03-18-2004, 17:32 | #10 (permalink) | |
No Life Poster Join Date: Apr 2003 Location: Italy
Member: 26267 Status: Offline Thanks Meter: 1 | Quote:
What? Version 16? Too old... Oh man, not all the MMC work fine in SL45i. There's a compatibility list... ok? Try to check it... Perhaps your card isn't compatible with Siemens. | |
03-20-2004, 12:07 | #13 (permalink) |
Member: 31339 Status: Offline Thanks Meter: 5 | can you give me the latest with indonesian language? i download the latest ver56 too.or give me the link that have sl45 Indonesian language. thanks best regards |
n73 memorycard problem | jack81 | Nokia Base Band 5 ( BB-5 ) | 0 | 04-04-2008 09:02 |
sl45 upgrade problem to sl45i** pls hlp | gsm-lord | x1x to x45/x50 | 2 | 05-31-2002 20:04 |
SL45 contrast problem ... | dghersin | x1x to x45/x50 | 0 | 02-20-2002 08:27 |
SL45 upgrade problems to V49 firmware. | Kiko | x1x to x45/x50 | 1 | 02-10-2002 23:09 |
SL45 Unlocker Problem Please Help | Kola | x1x to x45/x50 | 2 | 01-10-2002 20:20 |
