x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
11-22-2002, 19:42 | #1 (permalink) |
No Life Poster Join Date: Sep 2002 Location: Portugal
Member: 15312 Status: Offline Sonork: 100.1576041 Thanks Meter: 1,097 | V55 for SL45i for real, not for SLCK(6688i) This not crap as SLCK_5508, passing by SLIK_5501... download this : http://www.sl45.kiev.ua/firmware/ff_sl45.zip 1. shoot this "FuBu" with Unisiemens into your Phone 2. Repair EEprom with map-file 3. Reactivate Java with Multitool by Warlord |
11-23-2002, 18:30 | #5 (permalink) |
Freak Poster Join Date: Feb 2002 Location: Poland Age: 40
Member: 9600 Status: Offline Thanks Meter: 0 | Hello. I've uploaded this firmware to my SL45i today - this full flash has JAVA acitvated, so you don't need to play with Warlord tool - just upload it with UniSiemens and write a map. About changes: JAVA support was improved: midlets run faster (in my opinion) and some of them at last run at all :P (for example, I couldn't run "Stack Attack 2" from M(T)50 on firmware v49, and now it's working). Also you can set upper case permanently while writing sms by pressing "*" (just like in S/ME45). I haven't notice more changes between v49 and v55 (I have SL45 only few days so far and I haven't seen v52 and v54 so I'm not able to say more... ). |
11-25-2002, 00:54 | #7 (permalink) |
Crazy Poster Join Date: Sep 2002
Member: 15540 Status: Offline Thanks Meter: 0 | instead of repairing eeprom with map just save your eeprom with uni-siemens and replace the eeprom of the fubu after the flash - you won't have trouble with your phone settings and t9 and so on the eeprom areas are compatible |
11-25-2002, 00:55 | #8 (permalink) |
Insane Poster Join Date: May 2002
Member: 12263 Status: Offline Thanks Meter: 1 | Best way open the 55.bin with an hexeditor and break it at 5F0000 (that is: without eprom, last 64 Kb) then flash it and that's all! nothing else to do! a third way: flash the entire 55.bin and after write your eprom if u have saved it before.... in both ways phone works, tested! |
11-25-2002, 00:57 | #9 (permalink) |
Member: 15540 Status: Offline Thanks Meter: 0 | hey wind - nice idea *g* can you send me your cutted fubu (without eeprom) [email protected] EDIT OK Thx - made it by myself - was not toooo difficult Last edited by holg; 11-25-2002 at 01:40. |
11-25-2002, 09:30 | #10 (permalink) |
Member: 12263 Status: Offline Thanks Meter: 1 | holg............well so! have u notice? u had post a minute before yesterday.... my way without eprom tested also from ver19 anyway i am trying to do better, a more little flash.bin for not lose and touch in flash other settings like possible changed immagines vocal commands and so on.... |
11-25-2002, 20:29 | #11 (permalink) |
Member: 15312 Status: Offline Sonork: 100.1576041 Thanks Meter: 1,097 | Flashing without map Best way to flash without map With an hexeditor open the 55.bin and cut it at 5F0000 (without eprom) then flash it with unisiemens.....nothing else to do! A third way: if u have saved your eprom, flash the entire 55.bin and after write your eprom with your settings in both ways phone works, tested! |
12-01-2002, 23:56 | #15 (permalink) |
Member: 12263 Status: Offline Thanks Meter: 1 | Last way.... ......is open fullflash55 and setting unisiemens so: Flash: From 000000 Size: 5F0000 then write flash, no more cut file Save your pictures: if someone with Fw52 or Fw54 had modified the flash with new/change pictures in sl45, can save (read) the pictures before flashing Ver55 and reload (write) after always with unisiemen (read/write flash) so: Flash: Start 4A0000 Size 01E000 Attention! this address (4A0000) is valid only for versions 52, 54 and 55! Wind |
All Successfully Unloced Phones Screen Shots Post Here For Only Box Users Not For P.s | ..::: Naveed :::.. | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 1 | 07-18-2008 09:51 |
Please calculate map for SL45i v55 thanx and best regards | Monty | Phone Unlocking Codes & Maps | 2 | 12-23-2002 17:33 |
Please calculate map for SL45i v55 thanx | Monty | Phone Unlocking Codes & Maps | 2 | 12-11-2002 15:10 |
Map for SL45i v55 request | johnmar | Phone Unlocking Codes & Maps | 2 | 12-06-2002 15:10 |
Is there any REAL unlock solution for sl45i s/w 43 ? | VLD | x1x to x45/x50 | 0 | 02-04-2002 12:15 |
