Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > x1x to x45/x50
x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50.
Old 08-23-2002, 06:21   #1 (permalink)
Member: 9048
X45 Service Menu Activation
Test it!
ME/S45 v26 Netmonitor + Second CRC Check Off Patch
2AD7B8 2D -> 0D
2C499E 2D -> 0D
C45 v14 Netmonitor + Second CRC Check Off Patch
06D4F4 2D -> 0D
0A2868 2D -> 0D
Note:
For S/ME45 you MUST calculate first level CRC by siemcrc4x after apply patch!
For C45 you don't need to calculate first level CRC!
Old 08-23-2002, 18:30   #2 (permalink)
Member: 9600
Hello.
OK, let it be - I'm writing it again . This solution is working for me (on ME45 v26). I'm going to combine it with Sergey's discover and try to change CRC without program - the result was previosly the same as DarkBear's calculator, so I assume that it'll work. I'll post the results here.
Thank you again DarkBear for your great work - maybe you'll menage to discover more surprises like that, in Siemens firmware. We're all counting on you!
Old 08-23-2002, 19:01   #3 (permalink)
qbc
Member: 14648
Hi again Darkbear, you was realy realy greeat!!!!!!!!!!!!! :-)
my s45 its still alive and work with the developer menu without any problems!!! :-)
i have some other question, is it possible to make s45 to s45i is it from the hardware the same?
Old 08-23-2002, 20:01   #4 (permalink)
Member: 10764
2 DarkBear
DarkBear
What can u say about SL45?
How can I activate NetMonitor in this model?... FW52 and 54?...
I read recently this post and there was a link that it's your solution... Is this true???
<LINK>
http://forum.gsmhosting.com/vbb/show...threadid=52642
</LINK>
<POST>
Enable easy Netmon on SL45 !!!!!!!
read & try this! is very easy...
1. Download flash and eeprom ( Unisiemens );
2. Edit flash with HexWorkshop - at offset 00217F58 change 2D to 0D
3. Flash your phone with modifyed .bin
4. To activate Netmonitor-Menue press Menu and #
5. Be happy :-)
P.S. Solution by Darkbear ;-)
WBR
Proggy
</POST>
Old 08-24-2002, 03:21   #5 (permalink)
Registered User
Member: 8828
What about c45 v35??
Old 08-24-2002, 08:15   #6 (permalink)
nrg
Member: 7764
Hi
Dark Bear thank you for your effort to make my siemens phone more usefull exacly me45 v26 Developer Menu works and rocks!
Now I have a question have you seen 58f60 and later offsets of s/me45 firmware? It seems that there are mayby games from old s25 in firmware like minesweeper, wayout but also other like space inviders or kauai what do you think about it ?? Is it only a sign of something that is not present in firmware or there is a chance to have more gamez in s/me45?
Old 08-24-2002, 09:35   #7 (permalink)
Member: 14636
V28 for S/ME45 is out now! Here are the offsets for the netmonitor which worked for me:
0x002A72A6 from 2D -> 0D
0x002BE6B6 from 2D -> 0D
Old 08-24-2002, 17:20   #8 (permalink)
nrg
Member: 7764
v28
where can I get v28 for me45?
Old 08-24-2002, 20:38   #9 (permalink)
Member: 14636
you can get it at several update partners, the version not leaked to the internet so far.
Old 08-25-2002, 13:44   #10 (permalink)
Member: 1086
Question
Is it possible to activate this menu on MT50 v14?
Old 08-26-2002, 07:35   #11 (permalink)
Member: 9048
Re: 2 DarkBear
Originally posted by Stanislav
DarkBear
<LINK>
</LINK>
<POST>
5. Be happy :-)
WBR
Proggy
</POST>
Yes & it work
Try read here http://www.ttp.ru/sl45/viewtopic.php...07bb5ba7f4d19b
Old 08-26-2002, 07:41   #12 (permalink)
Member: 9048
To find offsets i need full image, send it to me & i find it!
Old 08-30-2002, 16:11   #13 (permalink)
ken
Member: 5472
C45 v 31
0A1106 2D ----->0D
0DB4B2 2D ----->0D
OK...
Old 09-03-2002, 09:56   #14 (permalink)
nrg
Member: 7764
developer menu description
If you want to find out what are all those marks in netmonitor go here also you can find very interesting program there which is some kind of debugger activator but see for yourself debuger but supports only S 30880-S4050-Xxxx and S 30880-S4250-Xxxx phones I guess x35 series?
Htc G1 menu activating. ck.sufail Android based Phones / Tablets 5 03-08-2010 21:42
c55 service menu activation on freia. enh E-Gold Based Phones 1 12-16-2004 11:54
3200 menu activation livewirecebu Nokia Digital Core Technology 4 ( DCT-4 ) 6 12-06-2004 17:05
x45 Service Manuals here ZenerDiode x1x to x45/x50 26 10-15-2002 01:09
S45 - problem with 'W@P over GPRS' after Service Menu activation whatever x1x to x45/x50 6 09-24-2002 01:51
Page generated in 0.26097 seconds with 9 queries
