E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section. |
05-26-2009, 16:01 | #1 (permalink) |
No Life Poster Join Date: Aug 2008 Location: The Matrix :) Age: 36
Member: 833760 Status: Offline Sonork: 100.1597150 Thanks Meter: 114 | A31 with ST Chip dead by Joker Code: Loading BootsModel(AX75)... Sending StartBoot Ok. Sending MainBoot Ok. Com1 115200 BAUD: Ok. Warning: HASH data error! SIEMENS A31 lg3 Sw07 FlashID: 0020/88C4 Flash Size: 16Mb, WriteBuffer: 64 bytes Region(1): Blocks 127, Size 128Kb Region(2): Blocks 4, Size 32Kb Window RAM block: 2048Kb Start EEPROM segments at addres 0x7A0000 FSN: A166AF35 -> PhoneID: 35AF66A1 OTP IMEI: 358757005619088 HASH: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF ClearFlashSeg at 0x800000 does not answer! |
05-26-2009, 22:49 | #2 (permalink) | |
No Life Poster Join Date: Dec 2006
Member: 416908 Status: Offline Thanks Meter: 398 | Quote:
dagos | |
05-27-2009, 11:27 | #3 (permalink) |
Member: 833760 Status: Offline Sonork: 100.1597150 Thanks Meter: 114 | Code: Open file "G:\!!!GSM\Siemens\Guide_A31\A31lg98Sw07_00-100_FF_id002088c4.bin" for write in Flash. FullFlash file info: FlashID: 0020/88C4 SIEMENS A31 Sw07 lg98 RealLgPack: lg98 Start... Loading BootsModel(AX75)... Sending StartBoot Ok. Sending MainBoot Ok. Com1 115200 BAUD: Ok. Warning: HASH data error! SIEMENS A31 lg3 Sw07 Soft FlashID: 0020/88C4 FlashID: 0020/88C4 Flash Size: 16Mb, WriteBuffer: 64 bytes Region(1): Blocks 127, Size 128Kb Region(2): Blocks 4, Size 32Kb Start EEPROM segments at addres 0x7A0000 FSN: A166AF35 -> PhoneID: 35AF66A1 OTP IMEI: 358757005619088 HASH: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF USE SKEY: 13329921 *#0000*12345678# - Network Lock *#0001*12345678# - Service Provider Lock *#0002*12345678# - Corporate Code *#0003*12345678# - Phone Code *#0004*12345678# - Network Subset Lock *#0005*12345678# - Only Sim ClearFlashSeg at 0x000000 does not answer! |
05-27-2009, 18:15 | #4 (permalink) |
Member: 416908 Status: Offline Thanks Meter: 398 | Which version of Joker i have to do? This time I try it with 3.5.6c. On 115200 speed only with ax75 option does something. Please if it possible explain a bit more.[/QUOTE] ...first, try to use the lower version of Joker (JokerV0324), check only ReCalk Keys and use the AX72/75, C110 option. dagos |
06-10-2009, 09:21 | #5 (permalink) |
Member: 833760 Status: Offline Sonork: 100.1597150 Thanks Meter: 114 | Another A31 with Spansion flash DEAD! I used UFS+Direct Com and martech box pinout cable! Please tell me what is wrong! Now the situation is same. I read the fullflash with a75 option but i cant write back! tried all models all everything! |
03-20-2010, 19:54 | #8 (permalink) | ||
Freak Poster Join Date: Mar 2004 Location: VietNam Age: 44
Member: 56938 Status: Offline Sonork: 100.1590777 Thanks Meter: 152 | My A31 Can go to Service mode Quote:
When Press Recalk All key Quote:
Thanks | ||
A31 Can't Not Be Unlocked By Joker!!!! | denard | E-Gold Based Phones | 8 | 09-25-2007 19:37 |
A31 ST chip problem | Invader | DreamBox | 7 | 01-31-2007 19:38 |
Problem unlock A31 with ST flash chip | goro_bg | DreamBox | 10 | 09-25-2006 08:41 |
C65 with AMD chip dead | NSerN | SIEM Service Tools | 5 | 05-26-2005 14:06 |
