E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section. |
09-27-2006, 06:24 | #1 (permalink) |
No Life Poster Join Date: Mar 2005 Location: lets See.
Member: 128918 Status: Offline Thanks Meter: 282 | A50 Dead After Unlock. Loading BootsModel(A50)... StartBoot does not loded! Start... Loading BootsModel(A50)... StartBoot does not loded! Start... Loading BootsModel(A50)... Sending StartBoot Ok. Sending MainBoot Ok. SIEMENS A50 lg1 Sw03 Soft FlashID: 0020/88BA FlashID: 0020/88BA Flash Size: 4Mb, WriteBuffer: 4 bytes Region(1): Blocks 63, Size 64Kb Region(2): Blocks 8, Size 8Kb Start EEPROM segments at addres 0xBF0000 FSN: 8B9F458D -> PhoneID: 8D459F8B OTP IMEI: 350446527629449 HASH: DA3FF0504AC8A43DBC0C13FFC950D91D Use OTP IMEI: 350446527629449 USE SKEY: 12345678 *#0000*12345678# - Network Lock *#0001*12345678# - Service Provider Lock *#0002*12345678# - Corporate Code *#0003*12345678# - Phone Code *#0004*12345678# - Network Subset Lock *#0005*12345678# - Only Sim Read BCORE addr: 0x800000 size: 0x010000... BCORE backup in ".\Backup\A50lg1Sw03_BCORE_060925122441.bin" file. Write BCORE at addr: 0x800000... Change BCORE HASH - Ok. Read EEPROM addr: 0xBF0000 size: 0x010000... EEPROM backup in ".\Backup\A50lg1Sw03_EEPROM_060925122505.bin" file. Write EEPROM addr: 0xBF0000 size: 0x010000... Change EEP0076 - Ok. Change EEP5009 - Ok. Change EEP5077 - Ok. Change EEP5121 - Ok. Change EEP5122 - Ok. Change EEP5123 - Ok. Change BOOTKEY - Error! No More Powerup Br. |
09-28-2006, 08:05 | #5 (permalink) |
No Life Poster Join Date: Aug 2004 Location: Romānia
Member: 76629 Status: Offline Thanks Meter: 76 | Joker has a bug when uses ReCalc All Keys with A50... Yes, it will kill the phone! But FREIA will get the phone alive with Unlocking only, not Full Flash! Further, if you want to use Joker with A50, do this: 1: Calc Skey 2:Enter Skey in phone 3: Put phone in Service Mode 4: Read and Calc Keys (Create blocks) Phone will be alive and unlocked! Last edited by hacktek; 09-29-2006 at 00:35. |
09-28-2006, 09:41 | #6 (permalink) | |
Member: 128918 Status: Offline Thanks Meter: 282 | Quote:
And Now fully Understand how to do the Steps with Joker For A50. BR Last edited by Afzaal; 09-29-2006 at 08:37. | |
09-29-2006, 00:32 | #7 (permalink) |
Member: 76629 Status: Offline Thanks Meter: 76 | Yes.. that is the procedure! And here is another trick: After that steps, you can enter Skey in phone again (Don't let the phone in Factory Mode!) Use FREIA and make Unlock, but with Autolock to provider checked! Put a SIM into phone, power on the phone! Phone will be locked on the network from first SIM card you used! The best is to power on with the customer SIM card inside (or another SIM card from the same network). If Customer will return for a full unlock, you can type *#0000*12345678# and phone will be unlocked again! If the customer don't return, it's perfect! When he will lost (or sell) his phone, the phone will be locked to network, so the new owner must go for unlocking again! That is much more money for the same phone, because you will ask for money for unlocking, right? P.S.: You can see the lock status of SIEMENS phones by typing *#0606# without SIM and press INFO (or MORE) . Best regards, HackTek |
11-27-2006, 17:37 | #8 (permalink) |
Junior Member Join Date: Nov 2006
Member: 384019 Status: Offline Thanks Meter: 0 | A50 v10 unlock i friends! I have an old Siemens A50 sw10 to unlock. What is the best (free) solution, to unlock it WITHOUT test point? I have freia 18 (cracked) and freia build 15, can they do the job? Thanks in advance |
help urgently G1157 dead after unlock.. | razisamb | FuriousGold | 4 | 03-29-2010 15:38 |
A50 dead after write firmwaire | patric | x1x to x45/x50 | 2 | 06-29-2004 22:03 |
help me !!! siemens a50 dead after bad flash | dragoss | Phone Unlocking Codes & Maps | 4 | 06-29-2003 20:59 |
A50 dead after write firmwaire | patric | x1x to x45/x50 | 5 | 03-29-2003 01:43 |
A50 dead after unlock with 1.02 free unlocker | comiter | x1x to x45/x50 | 8 | 01-07-2003 13:06 |
