A55 TestPoint question Hi, I'm a newbie. I have an A55 v11 that I'd like to transform to C55. I read that with v11 I have to use a testpoint. The question is: after modifying the phone (cutting the wire) and flashing it, do I have to restore the test point? Or not? Is it the same for all other mobiles? (wire restoration or not?) I think it's very difficult to repair the wire after using the testpoint. I hope it hasn't to be restored.... :( Please answer me! :) THANKSSSSS |
each phone has certain rest point and after what ever you will do with your phone no need to repaire the wire again |
hi you must do( test point).you can t turn other varıous...cut test point and try to flash the phone c 55 V 24 fls and unlock(no map saved use orjınal imei)..ok..good luck..regards |
Thanks Thanks guys. I'll try to use tp then. And no repairs! :D :D :D thanks again ;) |
