A62 phone disabled phone code when insert sim,it says :phone disabled phone code. how to remove this code. I have no box for siemens. need solution using joker or freia |
u dont need tp, just choose bootcore bug on joker, go to skey and click recal all keys, phone will be unlocked. |
Boots Already loaded! SIEMENS A62 lg98 Sw07 Soft FlashID: 0001/220C FlashID: 0001/227E-220C-2201 Flash Size: 8Mb, WriteBuffer: 32 bytes Region(1): Blocks 128, Size 64Kb Start EEPROM segments at addres 0xFC0000 FSN: AB9CC9EB -> PhoneID: EBC99CAB OTP IMEI: 358000001138047 HASH: 0CC25AB08D5DEE70C8E0FDD85F622F13 Use OTP IMEI: 358000001138047 USE SKEY: 12345678 *#0000*12345678# - Network Lock *#0001*12345678# - Service Provider Lock *#0002*12345678# - Corporate Code *#0003*12345678# - Phone Code *#0004*12345678# - Network Subset Lock *#0005*12345678# - Only Sim BCORE HASH is equivalent - not change. Read EEPROM addr: 0xFC0000 size: 0x030000... EEPROM backup in ".\Backup\A62lg98Sw07_EEPROM_090622220343.bin" file. Write EEPROM addr: 0xFC0000 size: 0x030000... CRC error in transfer buffer or bad RAM! (Block at 0xFC0000). what kind of error this is boss??? |
-select Type; A60/A62, comport 1 or 2, COM Speed: 115200 and bootcore Typ: BCoreBug - go to SKey menu and click to "Calc SKey. After calculation click on "Send Skey". If is OK, your phone enter in Factory mode (verify in Service Menu-> Service Mode). If give error, you need to cut one track from the seccond layer (click on TP tab to see picture) and repeat this steps in the "Normal" Boot Typ. dagos |
****** Joker Siemens EGOLD Phone Version 0.3.5.2 Test Only opened. ****** ****** Tuesday, June 23, 2009, at 12:35:05 ****** Start... Loading BootsModel(A60)... Sending StartBoot Ok. Error: MainBoot answer code 0xÿÿÿÿ! Start... Cancel. Start... Loading BootsModel(A60)... Sending StartBoot Ok. Sending MainBoot Ok. Com1 115200 BAUD: Ok. SIEMENS A62 lg98 Sw07 Soft FlashID: 0001/220C FlashID: 0001/227E-220C-2201 Flash Size: 8Mb, WriteBuffer: 32 bytes Region(1): Blocks 128, Size 64Kb Start EEPROM segments at addres 0xFC0000 FSN: AB9CC9EB -> PhoneID: EBC99CAB OTP IMEI: 358000001138047 HASH: 0CC25AB08D5DEE70C8E0FDD85F622F13 Boot terminated. Test and Calc Skey... BOOTKEY: F92682B09AA68262074AC47CBF4EBCC3 SKEY: 12345678 Start... Loading BootsModel(A60)... Sending StartBoot Ok. Error: MainBoot answer code 0xÿÿPV! Start... Boots terminated! Loading ServiceBoot... Error: ServiceBoot answer code 0xAD! Start... Loading BootsModel(A60)... Sending StartBoot Ok. Error: MainBoot answer code 0xÿÿÿÿ! Start... Loading BootsModel(A60)... Sending StartBoot Ok. Error: MainBoot answer code 0xÿPVO! Start... Boots terminated! Loading BootsModel(A60)... Sending StartBoot Ok. Error: MainBoot answer code 0xÿÿÿÿ! Start... Boots terminated! Loading BootsModel(A60)... Sending StartBoot Ok. Error: MainBoot answer code 0xÿÿPV! Start... Boots terminated! Loading BootsModel(A60)... Sending StartBoot Ok. Error: MainBoot answer code 0xÿÿÿP! Start... Loading BootsModel(A60)... Error: Load StartBoot answer code 0xFF! Start... Loading BootsModel(A60)... Sending StartBoot Ok. Sending MainBoot Ok. Com1 115200 BAUD: Ok. SIEMENS A62 lg98 Sw07 Soft FlashID: 0001/220C FlashID: 0001/227E-220C-2201 Flash Size: 8Mb, WriteBuffer: 32 bytes Region(1): Blocks 128, Size 64Kb Start EEPROM segments at addres 0xFC0000 FSN: AB9CC9EB -> PhoneID: EBC99CAB OTP IMEI: 358000001138047 HASH: 0CC25AB08D5DEE70C8E0FDD85F622F13 Boot terminated. Test and Calc Skey... BOOTKEY: F92682B09AA68262074AC47CBF4EBCC3 SKEY: 12345678 Start... Loading BootsModel(A60)... Sending StartBoot Ok. Error: MainBoot answer code 0xÿPVO! Start... Boots terminated! Loading BootsModel(A60)... Sending StartBoot Ok. Sending MainBoot Ok. Com1 115200 BAUD: Ok. SIEMENS A62 lg98 Sw07 Soft FlashID: 0001/220C FlashID: 0001/227E-220C-2201 Flash Size: 8Mb, WriteBuffer: 32 bytes Region(1): Blocks 128, Size 64Kb Start EEPROM segments at addres 0xFC0000 FSN: AB9CC9EB -> PhoneID: EBC99CAB OTP IMEI: 358000001138047 HASH: 0CC25AB08D5DEE70C8E0FDD85F622F13 Use OTP IMEI: 358000001138047 USE SKEY: 12345678 *#0000*12345678# - Network Lock *#0001*12345678# - Service Provider Lock *#0002*12345678# - Corporate Code *#0003*12345678# - Phone Code *#0004*12345678# - Network Subset Lock *#0005*12345678# - Only Sim BCORE HASH is equivalent - not change. Read EEPROM addr: 0xFC0000 size: 0x030000... ReadFlash error CRC (0x3F75<>0x5B69)! Start... Loading BootsModel(A60)... Sending StartBoot Ok. Sending MainBoot Ok. Com1 115200 BAUD: Ok. SIEMENS A62 lg98 Sw07 Soft FlashID: 0001/220C FlashID: 0001/227E-220C-2201 Flash Size: 8Mb, WriteBuffer: 32 bytes Region(1): Blocks 128, Size 64Kb Start EEPROM segments at addres 0xFC0000 FSN: AB9CC9EB -> PhoneID: EBC99CAB OTP IMEI: 358000001138047 HASH: 0CC25AB08D5DEE70C8E0FDD85F622F13 Use OTP IMEI: 358000001138047 USE SKEY: 12345678 *#0000*12345678# - Network Lock *#0001*12345678# - Service Provider Lock *#0002*12345678# - Corporate Code *#0003*12345678# - Phone Code *#0004*12345678# - Network Subset Lock *#0005*12345678# - Only Sim BCORE HASH is equivalent - not change. Read EEPROM addr: 0xFC0000 size: 0x030000... EEPROM backup in ".\Backup\A62lg98Sw07_EEPROM_090623121110.bin" file. Write EEPROM addr: 0xFC0000 size: 0x030000... CRC error in transfer buffer or bad RAM! (Block at 0xFC0000). Start... Boots Already loaded! SetSpeedBaud: Com1 already use 115200 BAUD! SIEMENS A62 lg98 Sw07 Soft FlashID: 0001/220C FlashID: 0001/227E-220C-2201 Flash Size: 8Mb, WriteBuffer: 32 bytes Region(1): Blocks 128, Size 64Kb Start EEPROM segments at addres 0xFC0000 FSN: AB9CC9EB -> PhoneID: EBC99CAB OTP IMEI: 358000001138047 HASH: 0CC25AB08D5DEE70C8E0FDD85F622F13 Boot terminated. Test and Calc Skey... BOOTKEY: F92682B09AA68262074AC47CBF4EBCC3 SKEY: 12345678 ****** Joker Siemens EGOLD Phone Version 0.3.5.2 Test Only closed. ****** ****** Tuesday, June 23, 2009, at 12:14:29 ****** |
****** Joker Siemens EGOLD Phone Version 0.3.5.2 Test Only opened. ****** ****** Tuesday, June 23, 2009, at 12:29:17 ****** Start... Loading BootsModel(A60)... Sending StartBoot Ok. Error: MainBoot answer code 0xÿPVO! Start... Loading BootsModel(A60)... Sending StartBoot Ok. Error: MainBoot answer code 0xÿÿPV! Start... Loading BootsModel(A60)... Sending StartBoot Ok. Sending MainBoot Ok. Com1 115200 BAUD: Ok. SIEMENS A62 lg98 Sw07 Soft FlashID: 0001/220C FlashID: 0001/227E-220C-2201 Flash Size: 8Mb, WriteBuffer: 32 bytes Region(1): Blocks 128, Size 64Kb Start EEPROM segments at addres 0xFC0000 FSN: AB9CC9EB -> PhoneID: EBC99CAB OTP IMEI: 358000001138047 HASH: 0CC25AB08D5DEE70C8E0FDD85F622F13 Boot terminated. Test and Calc Skey... BOOTKEY: F92682B09AA68262074AC47CBF4EBCC3 SKEY: 12345678 ****** Joker Siemens EGOLD Phone Version 0.3.5.2 Test Only closed. ****** ****** Tuesday, June 23, 2009, at 12:45:20 ****** unable to solve my proble after using test point. |
dagos |
but I have no flash file and dont know how to flash it. please provide me.(File+operating method) |
download the following files: A62 firmware 06 language pack 98 (multi flash files): http://www.4shared.com/file/11388050..._bootcore.html and/or A62 firmware 07 language pack 91 (single flash file - use only the 8MB fullflash): http://www.4shared.com/file/96828339...62_07_AMD.html I propouse to use the last Joker software: http://www.4shared.com/file/88732412...ker_0356c.html So, open Joker, select Type; A60/A62, comport 1 or 2, COM Speed: 115200 and bootcore Typ: Normal. Go to flash menu, select FullFlash, check only ReCalc Keys and click to Write. Select fullflash file (file with 8MB dimension) and wait to finish. I propouse to try first to flash only bootcore area (to not loose your stored files). Use flash file "A62_80-01_BC_bcore.bin" from the "a62_v06_bootcore.rar" archive. Set in the Flash menu "BCORE" option and remain checked only ReCalc Keys option. Wait to finish and enter in Service Mode to see if is OK (phone status Factory Mode). After try to start normarly your phone. If not working, remain to fullflash everything (Bootcore, EEprom,Language pack) using 8MB fullflash file. dagos |
after u have done tp then recalulate skey it will work, tested by me several times. good luck |
dagos |
So, open Joker, select Type; A60/A62, comport 1 or 2, COM Speed: 115200 and bootcore Typ: Normal. Go to flash menu, select FullFlash, check only ReCalc Keys and click to Write. Select fullflash file (file with 8MB dimension) and wait to finish. I act upon on above instruction. but after that such logs received in the end. Error: MainBoot answer code 0xÿÿÿÿ! in case of flashing and calc skey and recalc skey. in all conditions above logs received. |
dagos |
