Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > E-Gold Based Phones
E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section.
Old 12-11-2004, 10:07   #1 (permalink)
Member: 64182
A65 dead after interupt SWUP Flash
I change LP with siemens SWUP but phone is dead after interupt on 2%
Did somebody know how to flash with frea.I read another A65 firmware like C60 and write to dead phone and unlock too, but the phone is not power on.
Any solution?
Old 12-11-2004, 10:13   #2 (permalink)
ziko's Avatar
Member: 16916
Try again with SWUP, but check SKIP on Pre-Check
Ziko
Old 12-11-2004, 10:56   #3 (permalink)
Member: 64182
I already try but "bootcore not detected"
Old 12-12-2004, 00:54   #4 (permalink)
gecata's Avatar
Member: 16994
Try to cut TestPoint as C60 or MC60 and write fubu. Then unlock with freia15 as c60.
Old 12-12-2004, 02:42   #5 (permalink)
Member: 30844
Please where can i get the picture, cause i see the mobo a little different.
Old 12-12-2004, 09:32   #6 (permalink)
Member: 85460
THIS is the picture i used for cutting testpoint on my A65 with infineon chip.Works like a charm.You might also wanna do a search and read previous posts on this topic.
Old 12-13-2004, 08:28   #7 (permalink)
Member: 64182
I have one who work and I read flash with frea like C60 from 0x200000 and write to dead phone and unlock(phone already cut) everything without any errors but the phone not power up
Old 12-13-2004, 19:00   #8 (permalink)
pepos's Avatar
Member: 41508
I I have so that same problem ,there has been anyhow solution.
Old 12-15-2004, 19:41   #9 (permalink)
pepos's Avatar
Member: 41508
Please about assistance in solution problem to deaden A65
FREIA - Engine build 15, Frontend build 11
COMM_LoadBoots : selected phone family is 13
TTY_OpenCOMPort : opening Prodigy
COMM_IsBootRunning : bootcode does not seem to be running
COMM_LoadBoots : Waiting to power on the phone ...
COMM_LoadBoots : phone is powered on
COMM_LoadBoots : internal loader version is 01.02
COMM_LoadBoots : EEPROM IMEI is 35449200146727
COMM_LoadBoots : original IMEI is 35449200146727 (locked)
COMM_LoadBoots : found SIEMENS C60 lgX vff (1)
COMM_LoadBoots : flash ids are 00012212 [00000000] - FFFF
COMM_LoadBoots : phone ids are 9AC67CBE [00000000]
COMM_UpdateIMEIBlocks : original IMEI is locked
O.K.
Old 12-17-2004, 21:25   #10 (permalink)
Member: 17896
If you have working phone , try to read full flash from it , choose M55 and read flash - about 14mb, then choose M55 boot and read flash too- about 2mb. Connect your dead phone to the cabel and choose M55 boot in frea and write flash, then choose M55 and write flash , and then ..... unlock it.
This solution works for me.
Hopes to help you.
BR Zab4o
Old 12-18-2004, 00:38   #11 (permalink)
pepos's Avatar
Member: 41508
Thanks for tip I will try and give know
Old 12-18-2004, 23:24   #12 (permalink)
pepos's Avatar
Member: 41508
Big thanks.Your solution to have been 100% functional.
Old 12-21-2004, 17:07   #13 (permalink)
codec_romania's Avatar
Member: 9843
please help a65 dead
i have a problem
i have a dead a65
i have flashed it like you said with files read as m55 and m55 boot from a good a65 and after i flashed it, phone powers up for a second and then buzzzzz
now i tried to unlock it and says eeprom imei is corrupt
what can i do please
SEC_BCDIMEIToNormalIMEI : invalid decoded IMEI
COMM_LoadBoots : EEPROM IMEI (17) is corrupt
COMM_LoadBoots : original IMEI is 35449200120466 (locked)
COMM_LoadBoots : found SIEMENS A65 lg95 v5 (1)
COMM_LoadBoots : flash ids are 00012212 [00000000] - 1201
COMM_LoadBoots : phone ids are 368776CD [368776CD]
COMM_UpdateIMEIBlocks : update is not accepted
TTY_CloseCOMPort : Closing UFS2
ps i did not write eeprom as well ... i wrote only files from an a65 ( as m55 and m55boot ) like somebody wrote here.
many thanks in advance
mihai
mihai@codectelecom.com
Old 12-22-2004, 15:46   #14 (permalink)
Member: 7610
Sonork: 100.1575451
I have the same problem
Old 12-28-2004, 17:07   #15 (permalink)
Member: 17896
Try to unlock it as C60.
i wanted one solution for realive siemens a65 dead after unlock by other unlocker Braycel DreamBox 1 03-04-2010 15:28
5310 dead after interupted flashing pali Nokia Base Band 5 ( BB-5 ) 2 07-26-2009 09:26
A65 dead with SST full flash duha2 E-Gold Based Phones 8 11-08-2005 13:17
A65 dead after bad test point cut!!! eddierasta E-Gold Based Phones 8 05-17-2005 18:03
A65 dead after cutting track alcomm63 E-Gold Based Phones 6 02-06-2005 08:46
Page generated in 0.36097 seconds with 11 queries
