Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > E-Gold Based Phones
E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section.
Old 11-02-2008, 15:09   #1 (permalink)
Member: 57286
Thanks Meter: 8
please give me file c60 for sst
the c60 flash id is intel ,i want Chinese language ,please help me,thank‘s
Old 11-02-2008, 17:48   #2 (permalink)
dagos's Avatar
Member: 416908
Thanks Meter: 398
...download from http://eh.student.utwente.nl/~landy/...?dir=C60_C60A/
user: mobile
password: elibom
firmware update (with your country language pack - I suppouse LG07) and flash it using data cable (and phone is powered on).
Fullflash files is used only if your phone is crashed...
If you needed the fullflash file, go to http://rapidshare.com/files/159989380/c60v27full.rar and download archive.
Fullflash it and after make the firmware upgrade with your country language pack (see on attachemment).
dagos
Old 11-03-2008, 05:19   #3 (permalink)
Member: 57286
Thanks Meter: 8
thank's reply. i download C60_270700_service ,but it's can't connect the phone? C60_270700_service isn't supper the intel
falsh ?have Chinese language ?
Old 11-03-2008, 06:30   #4 (permalink)
dagos's Avatar
Member: 416908
Thanks Meter: 398
...to make firmware upgrade you need to have data cable (used for datatransfer, not for flashing/unlocking - service cable) and your phone need to be started.
If you cut track in your phone to realise testpoint for flashing/ unlocking, of course not is working. In this case you need to use the service cable, open WINSwup file, check "Skip" Pre-Check and Post-Check, configure com port and baudrate to 115200. Click on "Start" button and push quicly power on button from your phone (your phone need to be in Power off status).
Regarding to the language pack for your country (see in my last post -attachemment), I suppouse to need to have LG07...
dagos
Old 11-03-2008, 08:16   #5 (permalink)
Member: 57286
Thanks Meter: 8
yes i cut tp for sst flashing.
sst haven't intel flie for c60 lg07?
now wo can i do?
the service cable pinouts?
Old 11-05-2008, 05:44   #6 (permalink)
dagos's Avatar
Member: 416908
Thanks Meter: 398
now wo can i do?
...the service cable use the only this pins:
-pin2: GND
-pin3: TX
-pin4: RX
dagos
Old 11-06-2008, 17:40   #7 (permalink)
Member: 57286
Thanks Meter: 8
yes ,i try ,but C60_270600_service no connect the phone and JokerV0343 no conect the phone now please give me the file c60v27lg07 for sst
thank's
the service config is right?
Old 11-06-2008, 18:43   #8 (permalink)
dagos's Avatar
Member: 416908
Thanks Meter: 398
thank's
...OK, to repeat!
To use Joker:
-to connect with Joker, you need to cut one way in your phone. Open Joker and click on TP to see which way you neet to cut.
-select phone type A65/C60; COM Port wich you use with the SERVICE cable (data cable not working); com speed to 115200; Bot Typ to Normal.
-go to the Service menu, click on Service Mode button and push shortly to the power on button from your phone. In the right application window, needed to apeair the all information about your phone. Now you entered in Service Mode.
- Go to the Flash menu and select FullFlash; check after Protect BCore (is esential!!!) and Recalc. Keys
-Click on the Write button and wait to finished.
Now your phone is flashed and unlocked.
To use Winswup file:
If way in your phone is cutted, you need to flash firmware with the other methode:
-open winswup file and select baudrate and com port. In your picture, I see to you configurated corectly!
-connect the SERVICE CABLE to your phone, check "Skip" pre-check and "Skip" post-check.
-click on Start button and push shortly power on button from your phone.
The progres bar in the Connect Mobile section quicly will be full. After will started Erase Flash.....
-wait to finish it and power on your phone....
If the way not is cutted, is easy!
Open winswup file, set connection parameters, connect DATA CABLE, power on your phone, click on Start button and wait to finished flashing process. After this process is finished, your phone will start automatically!
Is needed to know:
-DATA CABLE is cable to transfer files beetwen your phone and PC using one of the Phone Manager software. Is used any Siemens cables type, except the C55 serial data cable. This is the one of the Service Cable in E-Gold and S-Gold phones. USB cables like DCA510 (have inside USB to serial converter chip) is used for Data and Service cable (dual functionality).
-Service cable is the serial cables like C55 darta cable, DCA500 and the cables used with the boxes.
That is,
dagos
BTW: not is easy to find fullflashes with the chinese language. Maybe one of the members from China make backup from his C60 phone and give to you. Not essential, for Joker or SST, is the same.
Old 11-07-2008, 05:52   #9 (permalink)
Member: 57286
Thanks Meter: 8
thank's Replies once more ,please look,the joker is ok connect the phone but the WinSwup isn't connect the phone ,you said the lg07 is only someone backup but no one have it ,just i only use the WinSwup ,but it isn't connect my phone ,wo can i do ?the way is cuted)
Old 11-07-2008, 06:15   #10 (permalink)
dagos's Avatar
Member: 416908
Thanks Meter: 398
...your phone is locked. First phase:
you need to unlock. Enter in Service mode (in the Service menu) and click to Read + Calculate keys). Regarding to the firmware upgrade to your Language pack, I will return.
dagos
Old 11-07-2008, 06:26   #11 (permalink)
dagos's Avatar
Member: 416908
Thanks Meter: 398
dagos
...I tested again and for me is working:
Open winswup file, set connection parameters, connect DATA CABLE, power on your phone, click on Start button and wait to finished flashing process. After this process is finished, your phone will start automatically.
Plese give to me which type of cable you use?
dagos
Old 11-09-2008, 04:18   #12 (permalink)
Member: 57286
Thanks Meter: 8
i use superstar ,the cable is right beacuse wo can flash the c60 by sst5.32
Old 11-09-2008, 05:39   #13 (permalink)
dagos's Avatar
Member: 416908
Thanks Meter: 398
...this is the data cable for C55/SL55 (in your case is the Service cable). To make firmware upgrade, you need to have Data Cable for E-Gold series, otherwise you not be able to work with WinSwup files....
dagos
Old 11-09-2008, 07:07   #14 (permalink)
Member: 57286
Thanks Meter: 8
that's your mean the cable for sst isn't same the winswup cable?
Old 11-09-2008, 16:06   #15 (permalink)
dagos's Avatar
Member: 416908
Thanks Meter: 398
..NO, man...
SST cables is for flashing/unlocking (use only Rx and Tx). For WinSwup you needed to have the cable with all signals (Rx,Tx,RTS...).
dagos
Please give me a help for my T720 seahome Phone Unlocking Codes & Maps 0 11-14-2003 02:39
Please give me the code for the following phone charly007 Phone Unlocking Codes & Maps 2 02-21-2003 22:36
Please Give Me Best Price For Logs! ! ! CobWeb Wanted Products 0 01-17-2003 11:08
Page generated in 0.27436 seconds with 10 queries
