Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > E-Gold Based Phones
E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section.
Old 04-17-2009, 07:11   #1 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Sonork: 100.1581941
.....:::::a70 big problem unlocking:::::.....
DEAR FRIENDS,
I HAVE SIEMENS A70 WITH SIM SHOW
*DISABLED PROTECTION CODE*
HOW TO REPAIR THIS?
AM ALLREADY CUT TP
CHECK THIS
SERVICE MODE DETAILS
Start...
Loading ServiceBoot...
Sending ServiceBoot Ok.
BFB Speed 115200 Baud - Ok.
HWID: 241 (A70)
A70 lg7 Sw37 15.05.06 15:16:13
IMEI: 359068009923271
DisplayID: 52, Hyundai D0986EF
Code(05): OTP closed
Code(0A): BootKEY misses in EEPROM
Code(0D): Keys are registered in BCORE
Code(10): Minimal access to BFB
Code(15): Complete condition
Code(19): Monitoring is switched on
Code(1D): Blocks 5121,5122,5123 are present
Battery Voltage 4179 mV.
SecurityMode: Customer
RECALC ALL KEY USING TIME THIS ERROR
Start...
Phone off!
Loading BootsModel(A70)...
Sending StartBoot Ok.
Sending MainBoot Ok.
Com1 115200 BAUD: Ok.
SIEMENS A70 lg7 Sw37
Soft FlashID: 0001/221D
FlashID: 0001/227E-221D-2200
Flash Size: 4Mb, WriteBuffer: 32 bytes
Region(1): Blocks 64, Size 64Kb
Start EEPROM segments at addres 0xBC0000
FSN: D8C25028 -> PhoneID: 2850C2D8
OTP IMEI: 359068009923271
HASH: AAC241C775A7F484F43C2D5B4C7311C2
Use OTP IMEI: 359068009923271
USE SKEY: 07412232
*#0000*12345678# - Network Lock
*#0001*12345678# - Service Provider Lock
*#0002*12345678# - Corporate Code
*#0003*12345678# - Phone Code
*#0004*12345678# - Network Subset Lock
*#0005*12345678# - Only Sim
BCORE HASH is equivalent - not change.
Read EEPROM addr: 0xBC0000 size: 0x030000...
Error Read Flash block 0xBC0000 size 0x004000!
AM USING JOKER VERSION 0.3.5.6
COM SPEED---115200
BOOT TYPE---NORMAL
PLS HELP ME OR PLS GUIDE ME
Old 04-17-2009, 09:31   #2 (permalink)
gul_hassan528's Avatar
Member: 420821
Sonork: 100.1603493
dear SHIJILFONOTLY use sst crack and unlock u r phone
Old 04-17-2009, 12:44   #3 (permalink)
Member: 351924
Sonork: 100.1581941
Bro,how to u?
U have this software
i have no idea with out nokia
pls guide me
Old 04-17-2009, 12:49   #4 (permalink)
::gsmcoder::'s Avatar
Member: 172434
Sonork: 100.161280
you need write a good eeprom to phone and try to recalc all keys again with joker, all will be fine...
Old 04-17-2009, 12:50   #5 (permalink)
Member: 351924
Sonork: 100.1581941
u have this eeprom file
pls share
Old 04-18-2009, 01:29   #6 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
recalculate all key is using for repair, not for unlock.
for unlock need only recalculate field 5008.
calculate skey, enter skey in phone and clear only field 5008.
with this metod work 100%, and no dead phones.
The Following User Says Thank You to orbita For This Useful Post:
Old 04-18-2009, 12:26   #7 (permalink)
Member: 351924
Sonork: 100.1581941
My problem is *DISABLED PROTECTION CODE*
Old 04-18-2009, 13:01   #8 (permalink)
Member: 351924
Sonork: 100.1581941
yes am try this but same problem
phone *DISABLED PROTECTION CODE*
Old 04-18-2009, 13:30   #9 (permalink)
Member: 867704
Sonork: 100.1577334
JOKER - 3.5.6
Use Comport Cable & Com speed 57600.
Go to Service > Than Service mode > Press Read+ Clack all keys.
At Skey > Clack Skey > Reclack All keys.
Try this & Post result.
DREAMS UNLOCK.
The Following User Says Thank You to DREAMS UNLOCK For This Useful Post:
Old 04-18-2009, 22:23   #10 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Yes, with prolific cable will work with hight speed.
With ftdi cable will work with problem.
Better is com cable and low speed for this phone(here is your problem).
And not need make recalculate all key.
This can kill phone.
And repair A70 for beginer is not so easy without backup.
only field 5008 need be changed.
Before make some with unlock, read eeprom.
if software read without problem, you can proced with unlock.
Old 04-18-2009, 22:51   #11 (permalink)
GSM-XPERTS's Avatar
Member: 1001830
Sonork: 100.1627763
use joker crack brothr
Old 04-21-2009, 07:32   #12 (permalink)
Member: 351924
Sonork: 100.1581941
bro,am upoad pm now set is dead
but service mode enter but no go to normal mode
wht can i do
pls help me
big problem reset counter of huawei modems hasanmh GSM / HSDPA Modems and Routers 22 05-03-2010 07:30
big problem with my mx key sshreesai MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 03-31-2010 10:07
Jaf big problem haytham_84 J.A.F. By Jafsupport.com 0 03-29-2010 20:53
6085 big problem kami1987 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 03-29-2010 13:42
Page generated in 0.35995 seconds with 11 queries
