Al21 cannot flash I HAVE GOT ONE AL21 IN BLINKING CONDITION. I HAVE TRY TO FLASH IT BUT THIS ERROR. Start... Loading BootsModel(AX75)... StartBoot does not answer! Start... Loading ServiceBoot... Sending ServiceBoot Ok. The phone was switched off on an error: EXIT: 7313 08 0000 Open file "D:\Flash\cracked\Siemence\AL21lg1Sw11_00-100_FF\AL21lg1Sw11_00-100_FF.bin" for write in Flash. FullFlash file used FlashID: 0001/2221 Start... Loading BootsModel(AX75)... Sending StartBoot Ok. Sending MainBoot Ok. SIEMENS AL21 lg1 Sw04 FlashID: 0001/227E-2221-2201 Flash Size: 16Mb, WriteBuffer: 32 bytes Region(1): Blocks 128, Size 128Kb Window RAM block: 512Kb Start EEPROM segments at addres 0x7A0000 FSN: 95627417 -> PhoneID: 17746295 OTP IMEI: 359167005373380 HASH: F2A1C6FC252F46628B2F29D862CFF897 Read EEP0067 block (ver00), size 20 bytes - Ok. Read EEP0076 block (ver00), size 10 bytes - Ok. Read EEP5005 block (ver00), size 64 bytes - Ok. Read EEP5007 block (ver00), size 10 bytes - Ok. Read EEP5008 block (ver00), size 224 bytes - Ok. Read EEP5009 block (ver00), size 10 bytes - Ok. Read EEP5012 block (ver00), size 14 bytes - Ok. Read EEP5077 block (ver00), size 232 bytes - Ok. Read EEP5093 block (ver00), size 76 bytes - Ok. Read EEP5121 block (ver00), size 56 bytes - Ok. Read EEP5122 block (ver00), size 6 bytes - Ok. Read EEP5123 block (ver00), size 12 bytes - Ok. EEPROM blocks is written in ".\Backup\AL21lg1Sw04_Backup090405155005.eep" file. ClearFlashSeg at 0x000000 does not answer! Open file "D:\Flash\cracked\Siemence\AL21lg1Sw11_00-100_FF\AL21lg1Sw11_00-100_FF.bin" for write in Flash. FullFlash file used FlashID: 0001/2221 Start... Loading BootsModel(AX75)... Sending StartBoot Ok. Sending MainBoot Ok. SIEMENS AL21 lg1 Sw04 FlashID: 0001/227E-2221-2201 Flash Size: 16Mb, WriteBuffer: 32 bytes Region(1): Blocks 128, Size 128Kb Window RAM block: 512Kb Start EEPROM segments at addres 0x7A0000 FSN: 95627417 -> PhoneID: 17746295 OTP IMEI: 359167005373380 HASH: F2A1C6FC252F46628B2F29D862CFF897 ClearFlashSeg at 0x000000 does not answer! Start... Loading BootsModel(AX75)... Sending StartBoot Ok. Sending MainBoot Ok. SIEMENS AL21 lg1 Sw04 FlashID: 0001/227E-2221-2201 Flash Size: 16Mb, WriteBuffer: 32 bytes Region(1): Blocks 128, Size 128Kb Window RAM block: 512Kb Start EEPROM segments at addres 0x7A0000 FSN: 95627417 -> PhoneID: 17746295 OTP IMEI: 359167005373380 HASH: F2A1C6FC252F46628B2F29D862CFF897 Use OTP IMEI: 359167005373380 USE SKEY: 12345678 *#0000*12345678# - Network Lock *#0001*12345678# - Service Provider Lock *#0002*12345678# - Corporate Code *#0003*12345678# - Phone Code *#0004*12345678# - Network Subset Lock *#0005*12345678# - Only Sim Read BCORE addr: 0x800000 size: 0x020000... BCORE backup in ".\Backup\AL21lg1Sw04_BCORE_090405155227.bin" file. Write BCORE at addr: 0x800000... ClearFlashSeg at 0x800000 does not answer! |
dagos |
Al21-yeni_FULL_FLAS_EPROM.rar http://rapidshare.com/files/21784962...EPROM.rar.html |
flash 16mb file with joker 3.5.6c with most lower baud rate . all will be ok ......... if there is no hardware problem. tested..... |
here is log http://i284.photobucket.com/albums/l.../al21error.jpg Open file "D:\Flash\cracked\Siemence\AL21lg1Sw11_00-100_FF\AL21lg1Sw11_00-100_FF.bin" for write in Flash. FullFlash file used FlashID: 0001/2221 Start... Loading BootsModel(AX75)... Sending StartBoot Ok. Sending MainBoot Ok. Com1 115200 BAUD: Ok. SIEMENS AL21 lg1 Sw04 FlashID: 0001/227E-2221-2201 Flash Size: 16Mb, WriteBuffer: 32 bytes Region(1): Blocks 128, Size 128Kb Window RAM block: 512Kb Start EEPROM segments at addres 0x7A0000 FSN: 95627417 -> PhoneID: 17746295 OTP IMEI: 359167005373380 HASH: F2A1C6FC252F46628B2F29D862CFF897 ClearFlashSeg at 0x000000 does not answer! |
Open file "D:\Flash\cracked\Siemence\Al21-yeni_FULL_FLAS_EPROM\al21full.bin" for write in Flash. FullFlash file used FlashID: 0001/2221 Start... Loading BootsModel(AX75)... Sending StartBoot Ok. Sending MainBoot Ok. Com1 115200 BAUD: Ok. SIEMENS AL21 lg1 Sw04 FlashID: 0001/227E-2221-2201 Flash Size: 16Mb, WriteBuffer: 32 bytes Region(1): Blocks 128, Size 128Kb Window RAM block: 512Kb Start EEPROM segments at addres 0x7A0000 FSN: 95627417 -> PhoneID: 17746295 OTP IMEI: 359167005373380 HASH: F2A1C6FC252F46628B2F29D862CFF897 ClearFlashSeg at 0x000000 does not answer! Open file "D:\Flash\cracked\Siemence\Al21-yeni_FULL_FLAS_EPROM\al21eprom.bin" for write in Flash. Start... Loading BootsModel(AX75)... Sending StartBoot Ok. Sending MainBoot Ok. Com1 115200 BAUD: Ok. SIEMENS AL21 lg1 Sw04 FlashID: 0001/227E-2221-2201 Flash Size: 16Mb, WriteBuffer: 32 bytes Region(1): Blocks 128, Size 128Kb Window RAM block: 512Kb Start EEPROM segments at addres 0x7A0000 FSN: 95627417 -> PhoneID: 17746295 OTP IMEI: 359167005373380 HASH: F2A1C6FC252F46628B2F29D862CFF897 WriteFlash block at 0x7A0000 does not answer crc! |
