E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section. |
01-31-2006, 17:48 | #1 (permalink) |
No Life Poster Join Date: May 2004 Location: Colombia Age: 34
Member: 64398 Status: Offline Thanks Meter: 153 | A71 IMEI Change in Here The .bin is attached (A71 v32 A0.bin) and the manual with steps (in spanish) 100% Tested |
The Following User Says Thank You to Tr0nAd0r For This Useful Post: |
04-12-2006, 18:53 | #3 (permalink) | |
No Life Poster Join Date: Aug 2005
Member: 167420 Status: Offline Thanks Meter: 19 | Quote:
05-13-2006, 01:44 | #5 (permalink) |
Member: 64398 Status: Offline Thanks Meter: 153 | @All: The A70/A71 all version is in other thread, search it @djssergy, the CF75 solution was posted by my friend Primux, i will post now the A76 solution |
05-22-2006, 18:01 | #6 (permalink) |
Banned Join Date: Dec 2005 Location: Argentina
Member: 210069 Status: Offline Sonork: 100.1603653 Thanks Meter: 42 | Hey man! i'm from argentina, and i can't make siemens a71!!!! the mobile is dead when flash... u can help me? i try & try but i can't make imei... PLIX HELP MEEEEEEE!! thx... |
10-12-2006, 23:55 | #8 (permalink) | |
Member: 64398 Status: Offline Thanks Meter: 153 | Quote:
generate patch with IPatcher apply patch to fullflash with VKlay flash using fullflash with Joker change imei with Joker | |
10-17-2006, 07:11 | #10 (permalink) |
No Life Poster Join Date: Sep 2002 Location: Türkiye Age: 47
Member: 15880 Status: Offline Sonork: 100.1612155 Thanks Meter: 452 | this metod is not *** pls tel me with lower time and beter patch sulotion best regarts senkron24 ps: with portial patch on e-golds |
04-06-2008, 06:32 | #12 (permalink) |
Freak Poster Join Date: Oct 2006
Member: 366557 Status: Offline Thanks Meter: 12 | Please helpme howto repair ??? Start... Loading BootsModel(A70)... Sending StartBoot Ok. Sending MainBoot Ok. Com2 115200 BAUD: Ok. Warning: HASH data error! SIEMENS A71 lg5 Sw32 Soft FlashID: 0001/221D FlashID: 0001/227E-221D-2200 Flash Size: 4Mb, WriteBuffer: 32 bytes Region(1): Blocks 64, Size 64Kb EEPROM segments not found! FSN: B13B6B7A -> PhoneID: 7A6B3BB1 OTP IMEI: 356473001183291 HASH: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF Error: EEP0067 not found! Error: EEP0076 not found! Error: EEP5005 not found! Error: EEP5007 not found! Error: EEP5008 not found! Error: EEP5009 not found! Error: EEP5012 not found! Error: EEP5077 not found! Error: EEP5093 not found! Error: EEP5121 not found! Error: EEP5122 not found! Error: EEP5123 not found! ClearFlashSeg at 0x810000 does not answer! |
04-06-2008, 10:46 | #13 (permalink) | |
No Life Poster Join Date: Dec 2006
Member: 416908 Status: Offline Thanks Meter: 398 | Quote:
See on my posts how to repait bootcore area (use Joker, uncheck "Protect Bootcore; check "ReCalc Keys"...). dagos | |
04-06-2008, 11:12 | #14 (permalink) |
Member: 416908 Status: Offline Thanks Meter: 398 | ..I'm returned. I suppouse to you used for flashing "Flash Siemens A71 Sw32.bin". This is the backup file created using SST software. So, fullflash your phone using SST. If you are unsure abut your file, download from this file from http://www.megaupload.com/?d=B4G2RTN5 dagos |
07-31-2008, 01:34 | #15 (permalink) |
Junior Member Join Date: Jul 2008
Member: 825555 Status: Offline Thanks Meter: 0 | Siemens TC35i IMEI Change Hi Tr0nAd0r and all .. Here's the problem I have in hand: Need to flash a Siemens MC35i module with a new IMEI. I can get at the Tx/Rx lines and do the dirties ...etc. Question: what do you recommend in terms of hardware and software for flashing ? Excuse the newbie question, but I am not really very familiar with phone unlocking tools out there, but I am a microelectronics engineer and chip designer, so getting fingers dirty is no problem at all Thanks in advance .. worldentropy |
motorola imei change -zfrank here add pls | ali.baydur | Motorola P2k | 2 | 02-13-2010 18:28 |
Dct4 Asic2 Imei Change Way Here | ikhlaq | Universalbox | 0 | 08-24-2007 13:36 |
BOOOMM motorola c1xx series imei change ONLY HERE | MaHmUt1982 | Motorola P2k | 35 | 03-24-2007 23:13 |
Can i imei change in 32kbyte eeprom, or in the flash? | dollyb | Old Ericsson Phones & Sony Phones | 2 | 07-12-2001 02:13 |
Imei change in nokia 16xx/2110 | jonwillow | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-09-1999 20:33 |
