E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section. |
05-16-2006, 07:36 | #1 (permalink) |
No Life Poster Join Date: May 2001 Location: gujarat india
Member: 4600 Status: Offline Thanks Meter: 79 | AX72 unlocking problem here is log. Start... Loading BootsModel(AX75)... Sending StartBoot Ok. Sending MainBoot Ok. SIEMENS AX72 lg98 Sw02 Soft FlashID: 0001/2221 FlashID: 0001/227E-2221-2201 Flash Size: 16Mb, WriteBuffer: 32 bytes Region(1): Blocks 128, Size 128Kb Start EEPROM segments at addres 0x7A0000 FSN: 82194B71 -> PhoneID: 714B1982 OTP IMEI: 357402007604066 HASH: 59F9A4A026DF8DFC03648386D4F06AB9 Use OTP IMEI: 357402007604066 USE SKEY: 12345678 *#0000*12345678# - Network Lock *#0001*12345678# - Service Provider Lock *#0002*12345678# - Corporate Code *#0003*12345678# - Phone Code *#0004*12345678# - Network Subset Lock *#0005*12345678# - Only Sim BCORE HASH is equivalent - not change. Read EEPROM addr: 0x7A0000 size: 0x060000... EEPROM backup in ".\Backup\AX72lg98Sw02_EEPROM_060516120311.bin " file. Write EEPROM addr: 0x7A0000 size: 0x060000... WriteFlash block at 0x7E0000 does not answer crc! |
05-17-2006, 07:26 | #2 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: GEORGIA,Tbilisi
Member: 75765 Status: Offline Thanks Meter: 722 | Is battery OK ? Quote:
Regards, B | |
05-19-2006, 05:36 | #3 (permalink) | |
Member: 4600 Status: Offline Thanks Meter: 79 | Quote:
Thanks for help, solved o.k. | |
06-20-2006, 08:29 | #6 (permalink) |
Super Moderator Join Date: Feb 2005 Location: United Arab Emirates , Dubai Age: 38
Member: 113928 Status: Offline Sonork: 100.111866 Thanks Meter: 1,838 | yes make a TP then Click Recall All Keys check the unlocking logs AX72 Start... Loading BootsModel(AX75)... Sending StartBoot Ok. Sending MainBoot Ok. SIEMENS AX72 lg98 Sw01 Soft FlashID: 0001/2221 FlashID: 0001/227E-2221-2201 Flash Size: 16Mb, WriteBuffer: 32 bytes Region(1): Blocks 128, Size 128Kb Start EEPROM segments at addres 0x7A0000 FSN: 4DD828FF -> PhoneID: FF28D84D OTP IMEI: 357402004061187 HASH: 73B2DE8EAB6087F9E547CC608FE6A94A Use OTP IMEI: 357402004061187 USE SKEY: 12345678 *#0000*12345678# - Network Lock *#0001*12345678# - Service Provider Lock *#0002*12345678# - Corporate Code *#0003*12345678# - Phone Code *#0004*12345678# - Network Subset Lock *#0005*12345678# - Only Sim Read BCORE addr: 0x800000 size: 0x020000... BCORE backup in ".\Backup\AX72lg98Sw01_BCORE_060506212917.bin" file. Write BCORE at addr: 0x800000... Change BCORE HASH - Ok. Read EEPROM addr: 0x7A0000 size: 0x060000... EEPROM backup in ".\Backup\AX72lg98Sw01_EEPROM_060506213049.bin " file. Write EEPROM addr: 0x7A0000 size: 0x060000... Change BOOTKEY - Ok. Change EEP0076 - Ok. Change EEP5009 - Ok. Change EEP5077 - Ok. Change EEP5121 - Ok. Change EEP5122 - Ok. Change EEP5123 - Ok. br MAJID |
AX72 unlock problem | mobile_juice | SIEM Service Tools | 0 | 10-12-2009 15:11 |
ax72 unlocking problem | TEKIN | Martech CLIP / Box / Key | 23 | 04-19-2007 16:39 |
Problem AX72 Unlock ???? | koa | DreamBox | 2 | 07-12-2006 19:05 |
Ax72 v1 problem | cobraro22 | E-Gold Based Phones | 0 | 03-15-2006 18:57 |
