Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > E-Gold Based Phones
E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section.
Old 10-13-2005, 17:56   #1 (permalink)
Member: 94090
c60 dead after unlock
I've c60 gives buzzer & light for 1 sec & turn off(AMD FLASH)
I made a test point
I used freia15
when I unlocked it,it became dead
I tried to repair c60
1-I select c60 boot repair it says this lacks of this area as eeprom area
(c60 boot,normal mode)
2-c60 eeprom(c60,normal)
3-c60 flash (c60,normal)
4-direct unlock no map is saved
but it's still dead.
I tried also with a lot of flashes but it's still dead
I tried with winswup but it says no bootcore found
I tried with sst5.31
I used c60,normal mode
flash v20 lg4 full repair
repair
it still dead!!!!!!
Is there any help?
Old 10-13-2005, 19:03   #2 (permalink)
Member: 56523
Check this for repair dead C60.
If your hardware ok your phone work after that.
http://rapidshare.de/files/6239245/c60repair.rar.html
Old 10-13-2005, 20:22   #3 (permalink)
Member: 94090
after sst5.31 cracked
no connection with freia15
any help pls
thanks in advance
Old 10-13-2005, 20:29   #4 (permalink)
Member: 56523
Check testpoint and read the instuktions in the file. I take this procedure many times an ever phone ok.
Old 10-13-2005, 20:58   #5 (permalink)
Member: 94090
I said "I made test point & c60 accept flashing "
Old 10-15-2005, 11:37   #6 (permalink)
Moderator
Chris02's Avatar
Member: 41076
Take a working C60
And read 2 Fullflashes:
1.) with C60 (14MB)
2.) with C60 boot (2MB)
Then flash these two files to your dead phone.
The 14MB Fubu with C60 and the 2MB with C60 boot!!!
After you have done this go to unlock-->direct unlock-->use org. IMEI-->power on shortly
Will revive your phone 100% if you will do it like I discriped
Old 10-16-2005, 10:19   #7 (permalink)
systemworm's Avatar
Member: 68498
U can also try this solution.Revived hundreds of C60.
http://download.siemens-club.ru/file...e_solution.zip
Old 10-22-2005, 07:44   #8 (permalink)
TheBrain's Avatar
Member: 97899
I flashed it with SST full repair (16 MB) and it gives me "Bad Comunication" at last. Not power on......and now on Freia:
COMM_SendBoot : waiting for boot ack
COMM_SendBoot : boot file is not accepted
TTY_CloseCOMPort : Closing COM1
What to do?!?
TheBrain
Old 10-22-2005, 09:07   #9 (permalink)
Member: 56523
Make Testpoint and use the solution that i postet before.
If your hardware ok your phone is again alive.
Old 10-23-2005, 13:57   #10 (permalink)
Member: 193422
I boys, for repair siemens with display blue for 2 second and buzzz follow this metod:
1 You need a usb cable not original, freia, vklay, winsup and fullflash. Find program and fullflash here
2 Make testpoint (be careful)
3 Flash the phone with vklay (in advanced option enable bootcore writing)
4 Unlock with freia, use direct unlock no map is saved and use original imei
At this point the phone is ok, use winsup for upgrade firmware and put correct language pack.
I revive 3 C60 and 1 A60 with this metod.
Excuseme for my english.
Ciao
Old 10-23-2005, 14:55   #11 (permalink)
amitks_in's Avatar
Member: 111665
Ciao
Hi thanks ! can u give me the pinouts of USB cable ! I need urgently plz !
Old 10-23-2005, 15:15   #12 (permalink)
Member: 59606
usb diagram+driver
I think you dont need usb cable you can also revive it with com cable
Old 10-23-2005, 15:17   #13 (permalink)
Member: 193422
You can see here but i have buy cable on ebay for 5euro......
Old 10-23-2005, 15:18   #14 (permalink)
amitks_in's Avatar
Member: 111665
Originally Posted by abdelrx
usb diagram+driver
Thanks freind I needed to unlock A-70 through joker and some one said it uses USB cable only !
Old 10-23-2005, 15:40   #15 (permalink)
Member: 59606
for a70 com cable work fine
help urgently G1157 dead after unlock.. razisamb FuriouS TeaM Products 4 03-29-2010 15:38
Siemens C60 dead after unlocking with Freia for UFS3 stil E-Gold Based Phones 5 06-08-2005 16:58
C60 dead after unlock with martech MadPhone SIEM Service Tools 4 06-05-2005 09:39
c60 dead after unlock and cut test point karo-uk E-Gold Based Phones 9 08-27-2004 23:54
C60 Dead after cut the track Help xareme E-Gold Based Phones 2 02-01-2004 18:38
Page generated in 0.38165 seconds with 11 queries
