Unlock Server
Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > E-Gold Based Phones
E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section.
Old 07-08-2009, 05:13   #1 (permalink)
dmaetrey's Avatar
Member: 315550
C60 Phone Disabled Phone Code -Pls Help-
How will i solve this? the owner use this before and now they activate maybe the Phone code and they forgot...
tried in joker 0.3.4.3
service mode then
calc skey it doesnt solve...
any help would be greatly aprreciated.
Old 07-09-2009, 02:24   #2 (permalink)
dmaetrey's Avatar
Member: 315550
anybody help... tia,..
Br.
Old 07-09-2009, 02:39   #3 (permalink)
MED9's Avatar
Member: 87853
service mode then
Friend u Must Calc Skey With TP To Slove Ur Prob
The Following User Says Thank You to MED9 For This Useful Post:
Old 07-09-2009, 07:13   #4 (permalink)
laduka's Avatar
Member: 194939
Sonork: 100.1613858
on this case you must to do recalck all keys and nothing other ,.no servise mode no other operation
The Following User Says Thank You to laduka For This Useful Post:
Old 07-10-2009, 04:16   #5 (permalink)
dmaetrey's Avatar
Member: 315550
Calc Skey
Start...
Loading BootsModel(A65)...
Sending StartBoot Ok.
Sending MainBoot Ok.
SIEMENS C60 lg95 Sw16
Soft FlashID: 0001/2212
FlashID: 0001/227E-2212-2200
Flash Size: 16Mb, WriteBuffer: 32 bytes
Region(1): Blocks 256, Size 64Kb
Start EEPROM segments at addres 0x7C0000
FSN: 91CA49D2 -> PhoneID: D249CA91
OTP IMEI: 351945007720908
HASH: 4FB80B9268600A3D8EF10880E2BCA74E
Boot terminated.
Test and Calc Skey...
BOOTKEY: CD85788F6734A9E574CD6A0444D7F71B
SKEY: 22793544
then Recalc all key
Start...
Use OTP IMEI: 351945007720908
USE SKEY: 22793544
*#0000*12345678# - Network Lock
*#0001*12345678# - Service Provider Lock
*#0002*12345678# - Corporate Code
*#0003*12345678# - Phone Code
*#0004*12345678# - Network Subset Lock
*#0005*12345678# - Only Sim
BCORE HASH is equivalent - not change.
Read EEPROM addr: 0x7C0000 size: 0x030000...
Error Read Flash block 0x7C0000 size 0x004000!
Send skey
Start...
Loading ServiceBoot...
Sending ServiceBoot Ok.
HWID: 40 (C60)
C60 lg95 Sw16 24.10.03 09:11:56
DisplayID: 37, Philips Epson S1D15G14
Code(05): OTP closed
Code(08): BootKEY is unknown
Code(0D): Keys are registered in BCORE
Code(10): Minimal access to BFB
Code(15): Complete condition
Code(19): Monitoring is switched on
Code(1D): Blocks 5121,5122,5123 are present
Battery Voltage 3745 mV.
SecurityMode: Customer
Send SKey(22793544)...
Phone Off.
SKey Send: Ok! All Open.
Then i put this number 22793544 to here... (*#0003*12345678# - Phone Code) But still same... or do i miss something???
Old 07-10-2009, 04:58   #6 (permalink)
MED9's Avatar
Member: 87853
Calc Skey
then Recalc all key
Send skey
NNN, Step By Step Try
-Calc Skey
-Send Skey
-ReCalc All Skey
GooD LucK
Old 07-10-2009, 05:03   #7 (permalink)
dmaetrey's Avatar
Member: 315550
why is this in the last logs its error
i did follow u
calc
send
Logs of Recalc All key
USE SKEY: 22793544
But still same
Old 07-10-2009, 05:09   #8 (permalink)
MED9's Avatar
Member: 87853
i did follow u
calc
send
But still same
Friend Look This :
Flash Ur Phone With Full Flash
http://rapidshare.com/files/44803335/C60.rar
And Im Sure U Will Be Fix Ur Prob
Old 07-10-2009, 19:51   #9 (permalink)
Moderator
dagos's Avatar
Member: 416908
@ dmaetrey: fullflash your phone using this file. Before flash, check only "ReCalc Keys"option in the Joker -> Flash menu.
dagos
The Following User Says Thank You to dagos For This Useful Post:
Old 07-11-2009, 07:12   #10 (permalink)
dmaetrey's Avatar
Member: 315550
ok be back after the result...
Old 07-11-2009, 07:49   #11 (permalink)
MED9's Avatar
Member: 87853
Ihope The GooD ReSulT
Old 07-11-2009, 09:09   #12 (permalink)
dmaetrey's Avatar
Member: 315550
dagos
btw
where is that file sir dagos?
i have dl this and follow your instruction but failed...
here is the logs in your steps
Start...
USE SKEY: 22793544
ClearFlashSeg at 0x000000 does not answer!
Old 07-12-2009, 05:35   #13 (permalink)
Moderator
dagos's Avatar
Member: 416908
btw
i have dl this and follow your instruction but failed...here is the logs in your steps
...try again to fullflash (with checked only ReCalc Keys in the Flash menu), but set "Boot Typ" to BCore Bug, not to Normal...
dagos
Old 07-18-2009, 10:08   #14 (permalink)
dmaetrey's Avatar
Member: 315550
dagos
still same error
tried this bin
C60lg95Sw23_00-100_FF.bin
Old 07-18-2009, 10:20   #15 (permalink)
MED9's Avatar
Member: 87853
still same error
tried this bin
Did U Flash With Amd Flash File Or Intel??
siemens A65 phone disabled phone code astana2007 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 03-02-2010 11:07
A62 phone disabled phone code astana2007 E-Gold Based Phones 13 06-25-2009 20:02
3200 disable key pad......pls help agent_lia Nokia Hardware & Hardware-Repair Area 0 07-20-2006 08:40
Phone Disabled-Network Code marketmike x1x to x45/x50 5 06-06-2001 11:09
NEED HELP: c35 phone disabled network code v05 gsnbhagawan x1x to x45/x50 1 03-22-2001 15:34
Page generated in 0.44866 seconds with 12 queries
