E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section. |
09-11-2004, 23:31 | #1 (permalink) |
Insane Poster Join Date: Mar 2000 Location: Deep Space 9 Age: 47
Member: 1091 Status: Offline Thanks Meter: 0 | C60 problem with unlock Only difference is now that intel flash is inside and usualy it was AMD. How can I unlock this? |
09-12-2004, 16:00 | #3 (permalink) |
Member: 1091 Status: Offline Thanks Meter: 0 | freia says boot not accepted (all 3 possibilities with bootloader, with and without testpoint). I even tried to re-flash with swup version 20 and after 50kb it said 'update denied by phone'... tested with and without testpoint. Updating to v25 and v23 works ok. bootcore patch says: 'unknown error'. Any ideas? trox Last edited by trox; 09-12-2004 at 18:50. |
09-12-2004, 22:29 | #5 (permalink) |
Member: 1091 Status: Offline Thanks Meter: 0 | Testpoint is ok. With testpoint I can't connect to swup at all. I made over 100 tespoints on c60 with no failure and I am pretty sure it is ok... unless there is some other testpoint to be made.. trox |
09-12-2004, 22:31 | #6 (permalink) | |
No Life Poster Join Date: Oct 1999 Age: 48
Member: 4201 Status: Offline Thanks Meter: 6 | Quote:
09-13-2004, 09:22 | #9 (permalink) |
Product Manager Join Date: Feb 2003 Location: Your Exclusive Source
Member: 20645 Status: Offline Sonork: 100.1579175 Thanks Meter: 635 | hello mate try to change it configration and then try to unlock if not use crd it work always fine with out any configration |
09-13-2004, 11:49 | #12 (permalink) |
Member: 1091 Status: Offline Thanks Meter: 0 | Ok, today I bought new c60, same as before, same version, same flash... I cut testpoint track as usual as I did MANY times before, and I checked connection (according to testpoin repair schematic) and there is no connection after cut. 100%... BUT, winswup is still working.... so, is there new testpoint on this phone? Can someone post 100% working testpoint picture for c60 so I can verify? trox |
09-18-2004, 22:17 | #15 (permalink) |
Insane Poster Join Date: Sep 2003 Age: 52
Member: 39438 Status: Offline Thanks Meter: 2 | hello ! have indentical proble.I was cut test point on C60 V23 and freia15 says: COMM_LoadBoots : Waiting to power on the phone ... COMM_LoadBoots : phone is powered on COMM_SendBoot : boot file is not accepted any help?another test point, or what? |
Problem with unlocking X70 with panaufo | azizraza | Panasonic | 0 | 05-25-2005 14:05 |
c60 probleme with a componant... | kamo44 | E-Gold Based Phones | 0 | 06-22-2004 19:42 |
c60 - problem with flash | demboch | E-Gold Based Phones | 7 | 03-04-2004 09:27 |
problem with unlocking with 2.3 reader | Destructor | ARM9 BASED M62 / M62+ | 5 | 02-29-2004 22:20 |
problem with unlock c60 | demboch | E-Gold Based Phones | 0 | 02-23-2004 19:20 |
