Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > E-Gold Based Phones
E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section.
Old 10-26-2004, 15:22   #1 (permalink)
ALFbcn2000's Avatar
Member: 13300
C60 without java folder ??????
Hi
I have unlocked many C60 with java patch. But today i have a "new" C60 v12 without java folder. I have upgraded it to v23 to try if it install java and jam forders but no result.
has no java this phone version?
I have tried to create a java/jam folders at mobile with SDE but no results.
I heve tested the two (A and B) flex memory and no java folder
Where is java folder?
Have any idea?
Thanks
AlfBcn
Old 10-26-2004, 18:14   #2 (permalink)
bop_gsm's Avatar
Member: 11549
u can unlock ur phone by testpoint
Old 10-26-2004, 20:20   #3 (permalink)
HONGXING's Avatar
Member: 33079
Normally, just create the folders Java/jam and place the applet inside.
If it does not work, try downgrading the C60 by WinSwup
Old 10-27-2004, 01:04   #4 (permalink)
ALFbcn2000's Avatar
Member: 13300
Hi Bop Gsm, I don't want to make testpoint, because what happens if i want to upload a java game?
Protobuyer, I have created java/jam folders with the applet inside but does not work. It does not appear at the phone menu. I believe that if I download soft version with Winswup it dos not appear. Has 12 v originally, and I have tested 12, 20 and 23.
Another solution?
wbr
AlfBcn
Old 10-27-2004, 02:44   #5 (permalink)
ednacell's Avatar
Member: 76978
Another solution?
wbr
AlfBcn
Have you tried to put applet in another folder like for example pictures folder or sounds folder then run the applet. I always delete the applet after I use it anyway. I am just guessing here. I have not run into this problem before.. But it sounds interesting...
Old 10-27-2004, 03:51   #6 (permalink)
ALFbcn2000's Avatar
Member: 13300
Yes i have tried in pictures. I can see the applet, but i can not execute it.
A friend give me a idea. I will post results tomorrow.
Thanks
AlfBcn
Old 10-27-2004, 14:41   #7 (permalink)
ALFbcn2000's Avatar
Member: 13300
Well, problem solved
Open "my Pc" and you can see "Mobile", just "right click" and select "make standard folders". All folders appear and Java/jam too. Just make a subfolder into Java/jam and the applet inside and you can see the applet in the menu "Surf & fun" -> games&applications. Then you can run the applet normally
Thanks to all
AlfBcn
Old 10-28-2004, 01:03   #8 (permalink)
ednacell's Avatar
Member: 76978
Thanks to all
AlfBcn
That was easy wasn't it. Thanks for the infor . Ones learns by doing, and your past experience helped you, you are becoming a true unlocker and problem solver well done......... And thank you for sharing the information with us . My self and I hope others will follow your lead and do the same pass their insights on problems not commonly encountered while unlocking.
E700 no java folder where to upload games pls help codec_romania SYSOL Platform 0 04-22-2005 14:54
C60 V12 Java No TestPoint Yes TL062 E-Gold Based Phones 2 12-20-2004 01:32
missing java folder in pcsuite phone browser enya_rainy Nokia Multimedia 2 09-25-2004 06:40
Unlock Mc60 or c60 with Java J-lock E-Gold Based Phones 2 07-05-2004 13:26
Is it possible Java in a phone without java? coolotter Samsung Media, Games, Ringtones 2 01-17-2004 14:39
Page generated in 0.28206 seconds with 11 queries
