E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section. |
03-19-2009, 01:24 | #1 (permalink) |
Insane Poster Join Date: Dec 2006 Location: BHaYaG
Member: 405056 Status: Offline Thanks Meter: 4 | a65 need flashfile to repair network for friea by nutzo amd chipset! any one have? the format of the flashfile is .FLS.............................. thanks in advance |
03-19-2009, 17:28 | #2 (permalink) | |
No Life Poster Join Date: Dec 2006
Member: 416908 Status: Offline Thanks Meter: 398 | Quote:
...for A65 -AMD freia flasher, download files from: http://rapidshare.com/files/211111002/A65_AMD_freia.rar dagos | |
03-22-2009, 10:23 | #4 (permalink) | |
Member: 405056 Status: Offline Thanks Meter: 4 | Quote:
thank u mr DAGOS, i tried your flash file but again no network!!!!!!!! | |
03-22-2009, 11:54 | #5 (permalink) | |
Please post log file from Joker. I send you link from the Joker fullflash file. In which country you live??? http://rapidshare.com/files/17685583...7_AMD_16MB.rar dagos BTW: before fullflash your phone, try to unlock with Joker (not by Freia). Maybe working after Last edited by dagos; 03-22-2009 at 11:59. | |
The Following User Says Thank You to dagos For This Useful Post: |
03-23-2009, 03:05 | #7 (permalink) |
Member: 405056 Status: Offline Thanks Meter: 4 | everytime i use joker this message appears Open file "D:\CELLPHONE TECHNICIAN TOOLS BY DARWINBAGSIK\FLaSHFiLeS\SieMeNS\A65\A65_AMD_No_Net _Fix_FF\A65_AMD_No_Net_Fix_FF.bin" for write in Flash. FullFlash file info: FlashID: 0001/2212 SIEMENS A65 Sw15 lg98 RealLgPack: lg5 Start... Loading BootsModel(A65)... Sending StartBoot Ok. Sending MainBoot Ok. SIEMENS A65 lg5 Sw06 Soft FlashID: 0001/2212 FlashID: 0001/227E-2212-2200 Flash Size: 16Mb, WriteBuffer: 32 bytes Region(1): Blocks 256, Size 64Kb Start EEPROM segments at addres 0x7C0000 FSN: AE7B4ABB -> PhoneID: BB4A7BAE OTP IMEI: 354494007302430 HASH: 68F74045495650DF29E446B19B70C636 ClearFlashSeg at 0x000000 does not answer! in friea by nutzo flashing continue! my problem is i cant flash with joker only in friea, i cut the testpoint already! no service!!! THANKS mr. DAGOS |
03-23-2009, 04:25 | #8 (permalink) | |
Try to fullflash using the older version of Joker. dagos Last edited by dagos; 03-27-2010 at 04:09. | |
03-23-2009, 09:55 | #9 (permalink) |
Member: 405056 Status: Offline Thanks Meter: 4 | Open file "C:\Documents and Settings\MaRGie\My Documents\JokerV0324\A65_AMD_No_Net_Fix_FF.bin" for write in Flash. FullFlash file used FlashID: 0001/2212 Start... Cancel. Open file "C:\Documents and Settings\MaRGie\My Documents\JokerV0324\A65_AMD_No_Net_Fix_FF.bin" for write in Flash. FullFlash file used FlashID: 0001/2212 Start... Loading BootsModel(A65)... Sending StartBoot Ok. Sending MainBoot Ok. SIEMENS A65 lg5 Sw06 FlashID: 0001/227E-2212-2200 Flash Size: 16Mb, WriteBuffer: 32 bytes Region(1): Blocks 256, Size 64Kb Window RAM block: 512Kb Start EEPROM segments at addres 0x7C0000 FSN: AE7B4ABB -> PhoneID: BB4A7BAE OTP IMEI: 354494007302430 HASH: 68F74045495650DF29E446B19B70C636 Read EEP0067 block (ver00), size 20 bytes - Ok. Read EEP0076 block (ver00), size 10 bytes - Ok. Read EEP5005 block (ver00), size 64 bytes - Ok. Read EEP5007 block (ver00), size 10 bytes - Ok. Read EEP5008 block (ver00), size 224 bytes - Ok. Read EEP5009 block (ver00), size 10 bytes - Ok. Read EEP5012 block (ver00), size 12 bytes - Ok. Read EEP5077 block (ver00), size 232 bytes - Ok. Read EEP5093 block (ver00), size 76 bytes - Ok. Read EEP5121 block (ver00), size 56 bytes - Ok. Read EEP5122 block (ver00), size 6 bytes - Ok. Read EEP5123 block (ver00), size 12 bytes - Ok. EEPROM blocks is written in ".\Backup\A65lg5Sw06_Backup090323165434.eep" file. ClearFlashSeg at 0x000000 does not answer! |
03-23-2009, 09:58 | #10 (permalink) |
03-24-2009, 02:31 | #12 (permalink) |
Member: 405056 Status: Offline Thanks Meter: 4 | thank you again mr. dagos but it seems my a65 doesnt flash in joker with any baudrates! same logs! do you have a fls file amd repair network for friea? @pepot |
03-24-2009, 06:11 | #13 (permalink) | |
Fullflash file "A65_AMD_No_Net_Fix_FF.bin" working only with SST software, not with Joker. For Freia I don't have any fullflash wile with firmware up to FW6. So, use SST for flashing your phone, after repair using this function from SST software and finally unlock your phone using Joker software. Download archive from http://rapidshare.com/files/212830609/sst_install.rar , run SST5_Setup.exe and replace installed file "SST.exe" with file from archive. The other way is to use fullflash backup from Joker (amd FULLFLASH - FIRMWARE 17). http://rapidshare.com/files/212831318/a65_sw17.rar That is. dagos | |
03-24-2009, 08:10 | #14 (permalink) |
Member: 405056 Status: Offline Thanks Meter: 4 | everytime i flash my a65 in sst it shows writing flash but there is no status bar! in short no flashing, i set all the baudrate but it gaves me the same result. THANKS again mr. DAGOS i appreciate your goodness. waiting again for your reply! |
03-24-2009, 18:55 | #15 (permalink) | |
Try to fullflash with Joker (lower version) sended fullflash file (with FW17). dagos | |
NEED S5233A Caldata file to repair network | a7mad01 | Z3X-Team Products | 7 | 03-02-2010 14:15 |
siemens friea by nutzo any one have this? | potsky_24 | E-Gold Based Phones | 1 | 03-17-2009 03:27 |
How to repair network not found after NVM repair? | Burnt Cobba | NSPRO | 5 | 08-17-2008 15:27 |
need flashfile & repair eprom | saketdeo | Infinity-Box | 2 | 08-11-2008 23:19 |
I Need Flashfile To Convert From P900 To P910i | caribe | Cruiser Suite | 0 | 04-05-2007 12:11 |
