E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section. |
09-26-2006, 16:24 | #1 (permalink) |
Junior Member Join Date: Aug 2004 Location: Bulgaria Age: 38
Member: 79630 Status: Offline Thanks Meter: 0 | CF110 problem Thanks in advice |
09-27-2006, 00:21 | #3 (permalink) | |
No Life Poster Join Date: Aug 2004 Location: Romānia
Member: 76629 Status: Offline Thanks Meter: 76 | Quote:
If the phone power off only when you are typing at the keypad, it is hardware. You don't need to replace Flash IC, only resolder it well (maybe remake the balls). The CPU IC may need resoldering, too (attention with the CPU, don't hot it directly! Hot it under the PCB, and move it verry little bit, up, down, left, right!) | |
09-29-2006, 15:36 | #4 (permalink) |
Member: 79630 Status: Offline Thanks Meter: 0 | I`ve tryed to flash phone with full flash but the problem still there. When i power phone ... the phone boots and then switch off I`ve flashed with SST and full flash wich is situated in support |
Problem with CF110 | Bi0H4z4rD | Siemens Hardware Repair Area | 7 | 01-08-2011 16:27 |
acount id problem.help uregent plz [SOLVED] | dani2080 | PolarBox 3 | 2 | 03-29-2010 12:46 |
CF110 problem | shjt | SST-Dongle | 0 | 12-23-2006 03:10 |
Unlock problem with CF110 | Kanwalgee | E-Gold Based Phones | 26 | 09-02-2006 06:33 |
cf110 problem | zata222 | E-Gold Based Phones | 3 | 03-21-2006 14:33 |
