E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section. |
03-19-2013, 23:01 | #1 (permalink) |
Junior Member Join Date: Mar 2013
Member: 1902887 Status: Offline Thanks Meter: 1 | AT Commands Siemens C60 For some months i'm trying to make the phone to reply on AT commands but without success. Firstly i was trying with Nokia 1100 and 1600 but i noticed that those are on FBUS and i want the AT commands, a cheap solution also. So i'm having now a Siemens C60. I made a cable and connected it to the computer. When i transmit AT command i got no reply. Please can you tell me what i'm doing wrong? Does the Siemens C60 also need the CTS RTS and DCD connection ? Now i'm using this: |
The Following User Says Thank You to rlucian90 For This Useful Post: |
03-21-2013, 20:10 | #2 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 416908 Status: Offline Thanks Meter: 398 | Hi, invert RX/TX pinouts from RS232 PC connector (female DB-9 connector). For the DCA500 cable schematic, please see in attachemment. You are from Romania? Br, dagos |
The Following User Says Thank You to dagos For This Useful Post: |
03-23-2013, 20:29 | #5 (permalink) | |
Member: 416908 Status: Offline Thanks Meter: 398 | Quote:
you need to cut one track from the second layer to have comunication between phone and PC.. dagos | |
03-28-2013, 12:48 | #6 (permalink) |
Member: 1902887 Status: Offline Thanks Meter: 1 | Hi there, I can't use that test point on the C60 cause it isnt mine. That isn't the same test point for the A57 ? If i do this test point and wire the TX RX and GND only on MAX232 and then in PC serial port can i use Freia to unlock phone and then to use AT commands ? Thank you. |
