Unlock Server
Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > E-Gold Based Phones
E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section.
Old 07-17-2008, 12:48   #1 (permalink)
EMOTION BBSR's Avatar
Member: 194285
help about a70. black shadow in screen after flashing
sometime after flashing a70 screen going orange light with a square patch of black shadow. letters not visible clearly. sometimes i am geting this screens
here is log of one set
Start...
Loading BootsModel(A70)...
Sending StartBoot Ok.
Sending MainBoot Ok.
Com3 460800 BAUD: Ok.
SIEMENS A70 lg91 Sw32
Soft FlashID: 0001/221D
FlashID: 0001/227E-221D-2200
Flash Size: 4Mb, WriteBuffer: 32 bytes
Region(1): Blocks 64, Size 64Kb
Start EEPROM segments at addres 0xBC0000
FSN: 5E067298 -> PhoneID: 9872065E
OTP IMEI: 359068003889213
HASH: 10A600B6EB95D0F3E2A1ED49D44F3C43
Use OTP IMEI: 359068003889213
USE SKEY: 12345678
*#0000*12345678# - Network Lock
*#0001*12345678# - Service Provider Lock
*#0002*12345678# - Corporate Code
*#0003*12345678# - Phone Code
*#0004*12345678# - Network Subset Lock
*#0005*12345678# - Only Sim
BCORE HASH is equivalent - not change.
Read EEPROM addr: 0xBC0000 size: 0x030000...
EEPROM backup in ".\Backup\A70lg91Sw32_EEPROM_080718034904.bin" file.
Write EEPROM addr: 0xBC0000 size: 0x030000...
Change BOOTKEY - Ok.
Change EEP0076 - Ok.
Change EEP5009 - Ok.
Change EEP5077 - Ok.
Change EEP5121 - Ok.
Change EEP5122 - Ok.
Change EEP5123 - Ok.
Start...
Loading ServiceBoot...
Sending ServiceBoot Ok.
BFB Speed 115200 Baud - Ok.
HWID: 241 (A70)
A70 lg91 Sw32 18.08.05 10:41:35
DisplayID: 52, Hyundai D0986EF
Code(05): OTP closed
Code(09): BootKEY is written in EEPROM
Code(0D): Keys are registered in BCORE
Code(10): Minimal access to BFB
Code(15): Complete condition
Code(19): Monitoring is switched on
Code(1C): Block 5123 is not found
Battery Voltage 4178 mV.
SecurityMode: Customer
Start...
Already BFB mode!
HWID: 241 (A70)
Battery Voltage 4217 mV.
Start...
Read EEP0067 block (ver00), size 20 bytes - Ok.
Read EEP0076 block (ver00), size 10 bytes - Ok.
Read EEP5005 block (ver00), size 64 bytes - Ok.
EEP5005 uses incorrect wariant and date!
Read EEP5007 block (ver00), size 10 bytes - Ok.
Read EEP5008 block (ver00), size 224 bytes - Ok.
Read EEP5009 block (ver00), size 10 bytes - Ok.
Read EEP5012 block (ver00), size 12 bytes - Ok.
Read EEP5077 block (ver00), size 232 bytes - Ok.
Read EEP5093 block (ver00), size 76 bytes - Ok.
Read EEP5121 block (ver00), size 56 bytes - Ok.
Read EEP5122 block (ver00), size 6 bytes - Ok.
Read EEP5123 block (ver00), size 12 bytes - Ok.
EEPROM blocks is written in ".\Backup\A70lg91Sw32_Backup080718034947.eep" file.
Restore EEP0067 - Ok.
Restore EEP5007 - Ok.
Restore EEP5012 - Ok.
Restore EEP5093 - Ok.
Restore EEP5005 - Error!
Data file "E:\siemens\Joker\A70\A70_4MB_221D_FF.bin".
Write Flash addr: 0x800000 size: 0x400000 - Ok.
Start...
USE SKEY: 12345678
EEPROM backup in ".\Backup\A70lg91Sw32_EEPROM_080718035514.bin" file.
Start...
MobileMode: Service
HWID: 241 (A70)
FSN: 5E067298
SW FlashID: 0001/221D
Code(13): Complete access to BFB
Code(1D): Blocks 5121,5122,5123 are present
Battery Voltage 4120 mV.
SecurityMode: Factory
Start...
Already BFB mode!
MobileMode: Service
HWID: 241 (A70)
FSN: 5E067298
Battery Voltage 4199 mV.
Old 07-17-2008, 17:19   #2 (permalink)
Moderator
dagos's Avatar
Member: 416908
Start...
USE SKEY: 12345678
Start...
HWID: 241 (A70)
Start...
Already BFB mode!
HWID: 241 (A70)
Start...
Start...
USE SKEY: 12345678
Start...
MobileMode: Service
HWID: 241 (A70)
FSN: 5E067298
Start...
Already BFB mode!
MobileMode: Service
HWID: 241 (A70)
FSN: 5E067298
...hmmm,
if you used fullflash file provided from the other phone, you need (after unlock) to repair contrast.
Use Joker -> Contrast -> Service Mode -> 5007Read -> Increase value on first bar -> 5007 Write -> Phone Off.
BTW: Is good to not publish your IMEI in the log files.
dagos
Old 07-17-2008, 17:52   #3 (permalink)
Member: 194285
thanks
i unlocked and repaired contrast acording to u
Read Contrast...
No Ping mobile
Start...
MobileMode: Service
HWID: 241 (A70)
IMEI: 359068005578137
FSN: FC6407DC
Battery Voltage 4112 mV.
Read Contrast...
Display1 contrast: 225, 225
Display2 contrast: 255, 255
Write contrast (225, 255) in block 5007...
Write block 5007 - Ok.
Read Contrast...
Write contrast (78, 255) in block 5007...
Display1 contrast: 78, 78
thanks once again. my all sets repaired
Cect T689 error mesage in screen after flash???? svchost SpiderMan 3 03-07-2009 12:31
T819 only SGH-T819 appearing in screen after flashing T819_Patch_unlock_IMEI.qcr keaelite UST Pro II 3 05-02-2008 10:26
LG MG-161a black screen after flash mansito01 PolarBox 2 4 01-27-2008 17:25
To those who see black screen after flashing GD67/68 ram_barney Panasonic 9 09-07-2003 20:54
A300 with black line across screen after flash! SilentKiller VLSI, Conexant, Skyworks and Old Models 3 09-12-2002 17:40
Page generated in 0.32156 seconds with 11 queries
