Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > E-Gold Based Phones
E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section.
Old 11-29-2006, 14:46   #1 (permalink)
Member: 64721
How to flash a SL55?
Hi,
I would know how to flash sl55. I have some boxes like tornado, cruiser and so on. I have the flash file, so I tried with tornado in directcom mode and joker, but it stops with an error. Do I need a testpoint? Pls could someone describe the procedure? Thank you.
Old 11-29-2006, 18:31   #2 (permalink)
Moderator
BB-gsm's Avatar
Member: 75765
You should post the error log from the software, to help us to know where is your problem ...
Old 11-29-2006, 19:24   #3 (permalink)
spinbaaz.com's Avatar
Member: 277447
sl55 flashing
you must need to make test point.
and the than flash the with freia
download freia
http://www.spinbaaz.com/freia.rar
Old 11-29-2006, 19:53   #4 (permalink)
Member: 64262
yes use freia and make the test point. very important you not need to solder to make the test point. Just take very thin wire and stick to test point and the other end to the metal corner, like spinbaaz has done but without soldering.
Also you will need torx t3 screw driver and when you take the back case off do not try to unscrew the tiny screw in the middle only the ones on the side.
Old 11-30-2006, 00:34   #5 (permalink)
Member: 64721
Thank you guys, I will try
how to flash a52? fuadgsm E-Gold Based Phones 1 03-29-2010 18:48
How to flash SGH B520.-URGENT- prashantvrm Samsung Flashers, Software, Firmware. 1 03-29-2010 13:24
how to flash e250i adda2004 Samsung Flashers, Software, Firmware. 0 03-29-2010 12:26
how to flash winswup for sl55 flo_sb E-Gold Based Phones 7 01-05-2005 14:10
How to unlock siemens sl55 w/ UFS-3 and freiaufs2_st.exe ???? drti UFS2 + UFS3-Tornadoflasher 6 09-18-2004 22:19
Page generated in 0.31972 seconds with 12 queries
