Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > E-Gold Based Phones
E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section.
Old 01-18-2006, 21:48   #1 (permalink)
Member: 48284
How To Remove Metal Shield To get too Test Point A62 ?
Can anybody explain how i remove the metal shield which is covering the test point on the A62 ? managed to fully disassemble the phone but according to position of test point this is underneath a metal shield which looks as though it is secured on with little weld spots all around ( if you know what i mean)
Any help appreciated.
Old 01-19-2006, 04:44   #2 (permalink)
Amir-SkillZ's Avatar
Member: 91045
Sonork: 100.1577222
As far i know
Brother A62 has a Sheild normal one as A55 and others and U can remove it by u Nails
its testpoint is same as MC60 A65 u know...A bit of Cut with the Main IC thats all
Old 01-19-2006, 08:34   #3 (permalink)
Member: 48284
the shield on this one just does not want to budge, it looks as though it is securely inplace, there are small type what looks to be rivet holes all the way along the shield, tried budging these with a tiny screw driver but just does not want to budge.
any more help appreciated.
zomig
Old 01-19-2006, 08:37   #4 (permalink)
Ciubaka's Avatar
Member: 42304
if you don`t know how to remove metal shield be sure you wont know how to cut the testpoint
Old 01-19-2006, 09:20   #5 (permalink)
sin_daemon's Avatar
Member: 85774
Just CUT bro
http://gsmfree.vipserver.ru/Siemens/MC60TSP.htm
Old 01-19-2006, 18:20   #6 (permalink)
Member: 48284
right, managed to get metal shield off, just was a bit tight thats all.....
what type of tool is best to cut the track ? what does everyone else use ?
zomig
Old 01-19-2006, 18:31   #7 (permalink)
shurubelul's Avatar
Member: 124026
zomig
cutter is the best tool to cut
Old 01-19-2006, 18:32   #8 (permalink)
Member: 48284
oh sorry how silly of me...
now for anyone else that actually wants to help..
Old 01-20-2006, 21:46   #9 (permalink)
shurubelul's Avatar
Member: 124026
so, nobody else helped u so far ?
if u don't know how to remove metal shield then u wanna cut TP ?!? don't cry and better buy martech box (but only if u had learned how to remove it )
PS: with a cutter u could had really cutted TP
Old 01-20-2006, 21:49   #10 (permalink)
James-R's Avatar
Member: 104911
use a scapel, its easiest.
Old 01-20-2006, 21:58   #11 (permalink)
Member: 48284
thanks to the people that helped, to the others well you already know.
zomig
Old 01-27-2006, 22:45   #12 (permalink)
sin_daemon's Avatar
Member: 85774
Hehehehehehe, why to give money for Martech when Siemens solutions is FREE and Papunyak Stuff is the BEST.
For cutting i use little knife, and have very much unlocked fones.
Old 01-27-2006, 23:07   #13 (permalink)
ronkor2000's Avatar
Member: 4980
You give money to Martech if you are a professional unlocker/repairman. Or even java patch without cutting is an option
Old 02-01-2006, 19:31   #14 (permalink)
Member: 48284
Many thanks for all your help, managed to unlock 3 of these a62's that i had here using pic posted above and with N-Box using freiaufs2_st
Cheers
zomig
Old 02-01-2006, 22:06   #15 (permalink)
doktortelecom's Avatar
Member: 87231
Cheers
zomig
Good luck man , go ahead!!!
regards,
doktortelecom
how to remove Metal cover of V360v gsmfriend P2k Series 4 03-15-2007 10:05
It Is Deifficult To Open Metal Shield Of New Motorola Phone :( dipu Smart-Clip 1 02-17-2006 15:04
c975 removing sheild to get at test point help??? callan Smart-Clip 5 01-06-2006 19:25
How to flash 8380 whith UC10 cable whithout test point chmatlob Cruiser Suite 3 09-02-2005 19:30
How to remove metallic covers in BF4 board? poweruser BF, BG, TH, BHx Series 1 09-03-2003 08:45
Page generated in 0.34330 seconds with 11 queries
