Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > E-Gold Based Phones
E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section.
Old 06-03-2004, 13:01   #1 (permalink)
Member: 67447
How to unlock M55 without restpoint and How to repair dead phones.
Here is how to repair and unlock your M55.
1. Download dataexchangesoftware_v267.exe
2. Download px5amd
3. execute mobile from your desktop (step 1), conect cable to phone, upload px5amd.jad and px5amd.jar extracted from step 2 to Java/jam folder of your phone.
4. (phone) go to Menu -> card-explorer -> Java -> jam -> px5amd and execute px5amd (the file without down arrow )
5. type 39116 when ask you for a code. Press 2 (path bootcore).
The phone will turn off.
6. Download Freia_M55_AMD and execute it.
My settings in Configuration are:
Com port for cable: COM1
speed comunication: 115200
Boot type: test point (x5x)
Com port setup: RTS and DTR enable.
Process information: Low
Press UNLOCKING button.
When program ask for, press power button of your phone.
If everything was ok your M55 phone is free.
Guide for troubleshooting:
A. If your phone doesnt boot.
B. If your phone doesnt boot but appear a blue screen while a few seconds with a buzz and then it turn off.
PART A:
1. Download a Full flash of 14Mb (M55_v.11_lg92_freia.zip from unlockeasy.com --- http://www.unlockeasy.com/modules.ph...ownload&cid=50)
2. Download freia 10 biuld 9 (I have test it maybe other version work too)
3. Execute freia, ATTENTION select "Siemens M55" NOT "siemens M55 BOOT" . Go to -> Configuration functions:
My settings are:
Com port for dongle: COM1
Process information: Medium
Boot Type: Patched bootcore.
Then press OK button
3.1 Press "Write flash to phone" button.
3.2 Now you have to Search and select SIEMENS M55 LG92 V11 - 00200000.FLS (14Mb)
3.3 Select "firmware" in Presets option.
3.4 Press red power button when the program ask for it.
This process will be slow, maybe 45 min or more.
3.5 Remove battery phone and put it again.
In this point when you try to power on the phone, will appear a blue screen with a buzz while a few seconds a then it will turn off.
PART B:
3.6 Remeber Select "Siemens M55" NOT "Siemens M55 BOOT" and the same configuration (boot type, speed, etc)
3.6.1 Press "Unlocking functions" and select "Direct unlock no map is saved" and "USE ORIGINAL IMEI"...
3.6.2 Press red power button when the program ask for it.
And after it... and if G O D was good with you, your phone will be repaired and unlocked.
This is my gift to GSM FORUM COMUNITY for help me too many times...
I hope to have been usefull. AND DONT GET DESPERATE, LIFE GOES ON...
Old 06-08-2004, 09:10   #2 (permalink)
Member: 60545
i hope you can give also instructions for repairing dead C55 coz mine is dead.
these are the following errors that i have encountered:
1. EEPROM IMEI (17) is corrupt
2. RAM error (only occurs once and maybe it's bcoz of my settings)
3. boot file not accepted
4. update is not accepted
5. erase/read/write error at 00800000 (or sometimes other block)
i cannot unlock, write map, write firmware, EEPROM, boot core. please help me. i've cut the test point and cut it right.
Old 06-08-2004, 19:20   #3 (permalink)
Registered User
to_deal_with's Avatar
Member: 19168
Thanks Meter: 55
@phmobile
in the configuration, choose bootcore bug, then unlock the phone using original imei and no map saving. If the phone still dead, write a good eeprom from another phone and rewrite the original imei from back of the phone.
If it fails in this case too,you have to full flash the phone and write the original imei.
lots of suxess
Old 06-08-2004, 19:26   #4 (permalink)
Registered User
Member: 19168
Thanks Meter: 55
@halcon.cpu
there are things missing in the method of unlocking M55 you mentioned.
After patching the bootcore with pxamd5, you should first write bootcore and then unlock, otherwise the message of the update was not accepted will appear and the phone still locked. So do write a bootcore after patching.
Second, for blue screens, you don't always need to fullflash the phone, infact even not at all needed. Just download the contrast program and it will take you to service mode, adjust the contrast and save it. the program is the contrast by Acid.
anyway, thanx for your information, but try to have a complete information. I like it cuz it is detailed for beginners but there are still things missing and they dicussed lots of times in other threads.
Best regards
tO_dEaL_wItH
Old 06-09-2004, 01:43   #5 (permalink)
Member: 60545
i can't really flash because it's giving me the same errors as above. i have use freia9 and martech software but no good still. is there any other resorts?
Old 06-09-2004, 05:40   #6 (permalink)
Member: 64449
Thanks Meter: 2
Could you use freia 15 instead?
Old 06-09-2004, 17:08   #7 (permalink)
Chris02's Avatar
Member: 41076
Thanks Meter: 53
yes u can use freia15 too
Old 06-10-2004, 05:30   #8 (permalink)
Member: 60545
I SOLVED IT!!! my phone is alive. one thing that i have learned.... FLASH/UPGRADE WITH FULL BATTERY. it's all my problems reason why i can't repair it. i used external power from my PC IDE power.. use the 5V power. thanks all for the help m8s!
Old 06-10-2004, 17:32   #9 (permalink)
Member: 67447
@to_deal_with
Is true... I forget update bootcore before...
thank you my friend.
2. Download px5amd
2.1 Download goodc60bootcore.fls (64Kb)
7. Press "Write flash to phone" button.
7.1 Now you have to Search and select godc60bootcore (64Kb)
7.2 Select "bootcore" in Presets option and OK button.
7.3 Press red power button when the program ask for it.
8. Press UNLOCKING button.
I think, now is ok... what do you think?
Old 06-10-2004, 17:34   #10 (permalink)
Member: 67447
ATTENTION: THIS METOD WORK IN MC60 AND C60 TOO !!!!!
Just Select MC60 or C60 in freia with the same bootcore file (goodc60bootcore.fls)
Old 06-19-2004, 14:31   #11 (permalink)
patric's Avatar
Member: 8228
Thanks Meter: 132
to go to phone menu u need original simcrad or motorola tet card and if u haven't what u can do to unlock your phone
Repaired dead phone without backup Prodigal Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-29-2011 11:26
How to make ASK/RPL calculation to repair dead phones, ASK/RPL server settings InfinitySupport Infinity-Box 4 03-20-2008 23:57
Hot to unlock V235 without box and testpoint lupos Motorola P2k 5 11-10-2007 04:34
How to repair dead phones or phones with blue screen! Chris02 E-Gold Based Phones 105 09-07-2005 19:05
Repaired dead phone without backup Prodigal Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 03-01-2001 21:47
Page generated in 0.35965 seconds with 8 queries
