E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section. |
12-12-2009, 16:27 | #1 (permalink) |
No Life Poster Join Date: May 2008
Member: 770503 Status: Offline Thanks Meter: 1,215 | successfully unlock done Egold based A70 & A52 Code: ****** Saturday, December 12, 2009, at 00:39:22 ****** Start... Loading ServiceBoot... Sending ServiceBoot Ok. BFB Speed 115200 Baud - Ok. HWID: 241 (A70) A70 lg98 Sw14 06.06.05 11:27:49 IMEI: 356342007582071 DisplayID: 52, Hyundai D0986EF Code(05): OTP closed Code(08): BootKEY is unknown Code(0D): Keys are registered in BCORE Code(10): Minimal access to BFB Code(15): Complete condition Code(19): Monitoring is switched on Code(1D): Blocks 5121,5122,5123 are present Battery Voltage 3923 mV. SecurityMode: Customer Start... Phone off! BootKey: 6E75747A6F6973746865626573740000 Error: StartBoot answer code 0x00A5! Start... Loading BootsModel(A70)... Sending StartBoot Ok. Sending MainBoot Ok. Com9 460800 BAUD: Ok. SIEMENS A70 lg98 Sw14 Soft FlashID: 0001/220C FlashID: 0001/227E-220C-2201 Flash Size: 8Mb, WriteBuffer: 32 bytes Region(1): Blocks 128, Size 64Kb Start EEPROM segments at addres 0xBC0000 FSN: FC9A98D0 -> PhoneID: D0989AFC OTP IMEI: 356342007582071 HASH: 54059945FA990F4E3E45A688B2140914 Use OTP IMEI: 356342007582071 USE SKEY: 12345678 *#0000*12345678# - Network Lock *#0001*12345678# - Service Provider Lock *#0002*12345678# - Corporate Code *#0003*12345678# - Phone Code *#0004*12345678# - Network Subset Lock *#0005*12345678# - Only Sim Read BCORE addr: 0x800000 size: 0x010000... BCORE backup in ".\Backup\A70lg98Sw14_BCORE_091212004108.bin" file. Write BCORE at addr: 0x800000... Change BCORE HASH - Ok. Read EEPROM addr: 0xBC0000 size: 0x030000... EEPROM backup in ".\Backup\A70lg98Sw14_EEPROM_091212004116.bin" file. Write EEPROM addr: 0xBC0000 size: 0x030000... Change BOOTKEY - Ok. Change EEP0076 - Ok. Change EEP5009 - Ok. Change EEP5077 - Ok. Change EEP5121 - Ok. Change EEP5122 - Ok. Change EEP5123 - Ok. Start... Loading ServiceBoot... Sending ServiceBoot Ok. BFB Speed 115200 Baud - Ok. MobileMode: Service HWID: 241 (A70) A70 lg98 Sw14 06.06.05 11:27:49 IMEI: 356342007582071 DisplayID: 52, Hyundai D0986EF FSN: FC9A98D0 SW FlashID: 0001/220C Code(05): OTP closed Code(09): BootKEY is written in EEPROM Code(0D): Keys are registered in BCORE Code(13): Complete access to BFB Code(15): Complete condition Code(19): Monitoring is switched on Code(1D): Blocks 5121,5122,5123 are present Battery Voltage 3915 mV. SecurityMode: Factory Start... Already BFB mode! MobileMode: Service HWID: 241 (A70) A70 lg98 Sw14 06.06.05 11:27:49 IMEI: 356342007582071 DisplayID: 52, Hyundai D0986EF FSN: FC9A98D0 SW FlashID: 0001/220C Code(05): OTP closed Code(09): BootKEY is written in EEPROM Code(0D): Keys are registered in BCORE Code(13): Complete access to BFB Code(15): Complete condition Code(19): Monitoring is switched on Code(1D): Blocks 5121,5122,5123 are present Battery Voltage 3882 mV. SecurityMode: Factory Send SKey(12345678)... Phone Off. SKey Send: Ok! All Close. Code: ****** Saturday, December 12, 2009, at 05:37:15 ****** Start... Loading ServiceBoot... Sending ServiceBoot Ok. BFB Speed 115200 Baud - Ok. HWID: 226 (A52) A52V lg92 Sw04 15.12.04 10:10:18 IMEI: 355424000950389 Code(05): OTP closed Code(08): BootKEY is unknown Code(0D): Keys are registered in BCORE Code(10): Minimal access to BFB Code(15): Complete condition Code(19): Monitoring is switched on Code(1D): Blocks 5121,5122,5123 are present Battery Voltage 3840 mV. SecurityMode: Customer Start... Phone off! Loading BootsModel(A51)... Sending StartBoot Ok. Sending MainBoot Ok. Com5 921600 BAUD: Ok. SIEMENS A52V lg92 Sw04 Soft FlashID: 002C/0016 FlashID: 002C/0016 Flash Size: 4Mb, WriteBuffer: 32 bytes Region(1): Blocks 32, Size 128Kb Start EEPROM segments at addres 0xBA0000 FSN: AEE7CA3E -> PhoneID: 3ECAE7AE OTP IMEI: 355424000950389 HASH: FCB89EDACE7A96AAB547D1F45E621E39 Use OTP IMEI: 355424000950389 USE SKEY: 12345678 *#0000*12345678# - Network Lock *#0001*12345678# - Service Provider Lock *#0002*12345678# - Corporate Code *#0003*12345678# - Phone Code *#0004*12345678# - Network Subset Lock *#0005*12345678# - Only Sim Read BCORE addr: 0x800000 size: 0x020000... BCORE backup in ".\Backup\A52Vlg92Sw04_BCORE_091212053749.bin" file. Write BCORE at addr: 0x800000... Change BCORE HASH - Ok. Read EEPROM addr: 0xBA0000 size: 0x060000... EEPROM backup in ".\Backup\A52Vlg92Sw04_EEPROM_091212053758.bin" file. Write EEPROM addr: 0xBA0000 size: 0x060000... Change BOOTKEY - Ok. Change EEP0076 - Ok. Change EEP5009 - Ok. Change EEP5077 - Ok. Change EEP5121 - Ok. Change EEP5122 - Ok. Change EEP5123 - Ok. |
The Following User Says Thank You to mbiborna For This Useful Post: |
12-12-2009, 18:22 | #2 (permalink) | |
Banned Join Date: Sep 2009
Member: 1129038 Status: Offline Thanks Meter: 745 | Quote:
01-03-2010, 05:32 | #3 (permalink) | |
Member: 770503 Status: Offline Thanks Meter: 1,215 | another a70 unlock ok Quote:
01-06-2010, 10:55 | #4 (permalink) |
No Life Poster Join Date: Nov 2007 Location: UK
Member: 629391 Status: Offline Thanks Meter: 396 | I installed mobileex 3.3. now I am able to use siemens software via ufs3. but I never unlocked siemens before. is it need testpoint using ufs box? can you explain some, how to use for unlocking siemens?. |
02-10-2010, 14:24 | #6 (permalink) |
Member: 770503 Status: Offline Thanks Meter: 1,215 | another a70 repaired ok ****** Joker Siemens EGOLD Phone Version 0.3.5.4 Inofficial opened. ****** ****** Wednesday, February 10, 2010, at 18:36:10 ****** Open file "F:\SIMMENS\FLASH FILE\A70\a70_v23\full\A70_80-40_FF.bin" for write in Flash. FullFlash file info: FlashID: 0001/221D SIEMENS A70 Sw32 lg1 RealLgPack: lg1 Start... Loading BootsModel(A70)... Sending StartBoot Ok. Sending MainBoot Ok. Com6 460800 BAUD: Ok. SIEMENS A70 lg91 Sw32 Soft FlashID: 0001/221D FlashID: 0001/227E-220C-2201 Flash Size: 8Mb, WriteBuffer: 32 bytes Region(1): Blocks 128, Size 64Kb Start EEPROM segments at addres 0xBC0000 FSN: 2AFD7B88 -> PhoneID: 887BFD2A OTP IMEI: 356342007451087 HASH: 19AA08CC539AA7C54C82DC47655F8BA6 Read EEP0067 block (ver00), size 20 bytes - Ok. Read EEP0076 block (ver00), size 10 bytes - Ok. Read EEP5005 block (ver00), size 64 bytes - Ok. Read EEP5007 block (ver00), size 10 bytes - Ok. Read EEP5008 block (ver00), size 224 bytes - Ok. Read EEP5009 block (ver00), size 10 bytes - Ok. Read EEP5012 block (ver00), size 12 bytes - Ok. Read EEP5077 block (ver00), size 232 bytes - Ok. Read EEP5093 block (ver00), size 76 bytes - Ok. Read EEP5121 block (ver00), size 56 bytes - Ok. Read EEP5122 block (ver00), size 6 bytes - Ok. Read EEP5123 block (ver00), size 12 bytes - Ok. EEPROM blocks is written in ".\Backup\A70lg91Sw32_Backup100210183651.eep" file. USE SKEY: 12345678 *#0000*12345678# - Network Lock *#0001*12345678# - Service Provider Lock *#0002*12345678# - Corporate Code *#0003*12345678# - Phone Code *#0004*12345678# - Network Subset Lock *#0005*12345678# - Only Sim Change BOOTKEY - Ok. Change EEP0076 - Ok. Change EEP5009 - Ok. Change EEP5077 - Ok. Change EEP5121 - Ok. Change EEP5122 - Ok. Change EEP5123 - Ok. Change BCORE HASH - Error! Restore EEP0067 - Ok. Restore EEP5005 - Ok. Restore EEP5007 - Ok. Restore EEP5012 - Ok. Restore EEP5093 - Ok. Data file "F:\SIMMENS\FLASH FILE\A70\a70_v23\full\A70_80-40_FF.bin". Write Flash addr: 0x800000 size: 0x400000 - Ok. Open file "F:\SIMMENS\FLASH FILE\A70\a70_v23\bcore\A70_80-01_BC.bin" for write in Flash. Start... Loading BootsModel(A70)... Sending StartBoot Ok. Sending MainBoot Ok. Com6 460800 BAUD: Ok. SIEMENS A70 lg1 Sw32 Soft FlashID: 0001/221D FlashID: 0001/227E-220C-2201 Flash Size: 8Mb, WriteBuffer: 32 bytes Region(1): Blocks 128, Size 64Kb Start EEPROM segments at addres 0xBC0000 FSN: 2AFD7B88 -> PhoneID: 887BFD2A OTP IMEI: 356342007451087 HASH: 19AA08CC539AA7C54C82DC47655F8BA6 USE SKEY: 12345678 Change BCORE HASH - Ok. Data file "F:\SIMMENS\FLASH FILE\A70\a70_v23\bcore\A70_80-01_BC.bin". Write Flash addr: 0x800000 size: 0x010000 - Ok. Open file "F:\SIMMENS\FLASH FILE\A70\a70_v23\eprom\A70_BC-03_EE.bin" for write in Flash. Start... Loading BootsModel(A70)... Sending StartBoot Ok. Sending MainBoot Ok. Com6 460800 BAUD: Ok. SIEMENS A70 lg1 Sw32 Soft FlashID: 0001/221D FlashID: 0001/227E-220C-2201 Flash Size: 8Mb, WriteBuffer: 32 bytes Region(1): Blocks 128, Size 64Kb Start EEPROM segments at addres 0xBC0000 FSN: 2AFD7B88 -> PhoneID: 887BFD2A OTP IMEI: 356342007451087 HASH: 19AA08CC539AA7C54C82DC47655F8BA6 Read EEP0067 block (ver00), size 20 bytes - Ok. Read EEP0076 block (ver00), size 10 bytes - Ok. Read EEP5005 block (ver00), size 64 bytes - Ok. Read EEP5007 block (ver00), size 10 bytes - Ok. Read EEP5008 block (ver00), size 224 bytes - Ok. Read EEP5009 block (ver00), size 10 bytes - Ok. Read EEP5012 block (ver00), size 12 bytes - Ok. Read EEP5077 block (ver00), size 232 bytes - Ok. Read EEP5093 block (ver00), size 76 bytes - Ok. Read EEP5121 block (ver00), size 56 bytes - Ok. Read EEP5122 block (ver00), size 6 bytes - Ok. Read EEP5123 block (ver00), size 12 bytes - Ok. EEPROM blocks is written in ".\Backup\A70lg1Sw32_Backup100210184032.eep" file. USE SKEY: 12345678 *#0000*12345678# - Network Lock *#0001*12345678# - Service Provider Lock *#0002*12345678# - Corporate Code *#0003*12345678# - Phone Code *#0004*12345678# - Network Subset Lock *#0005*12345678# - Only Sim Change BOOTKEY - Ok. Change EEP0076 - Ok. Change EEP5009 - Ok. Change EEP5077 - Ok. Change EEP5121 - Ok. Change EEP5122 - Ok. Change EEP5123 - Ok. Restore EEP0067 - Ok. Restore EEP5005 - Ok. Restore EEP5007 - Ok. Restore EEP5012 - Ok. Restore EEP5093 - Ok. Data file "F:\SIMMENS\FLASH FILE\A70\a70_v23\eprom\A70_BC-03_EE.bin". Write Flash addr: 0xBC0000 size: 0x030000 - Ok. Open file "F:\SIMMENS\FLASH FILE\A70\a70_v23\lp\A70_A0-04_LG.bin" for write in Flash. Start... Loading BootsModel(A70)... Sending StartBoot Ok. Sending MainBoot Ok. Com6 460800 BAUD: Ok. SIEMENS A70 lg1 Sw32 Soft FlashID: 0001/221D FlashID: 0001/227E-220C-2201 Flash Size: 8Mb, WriteBuffer: 32 bytes Region(1): Blocks 128, Size 64Kb Start EEPROM segments at addres 0xBC0000 FSN: 2AFD7B88 -> PhoneID: 887BFD2A OTP IMEI: 356342007451087 HASH: 19AA08CC539AA7C54C82DC47655F8BA6 Data file "F:\SIMMENS\FLASH FILE\A70\a70_v23\lp\A70_A0-04_LG.bin". Write Flash addr: 0xA00000 size: 0x040000 - Ok. Open file "F:\SIMMENS\FLASH FILE\A70\a70_v23\t9\A70_AB-05_T9.bin" for write in Flash. Start... Loading BootsModel(A70)... Sending StartBoot Ok. Sending MainBoot Ok. Com6 460800 BAUD: Ok. SIEMENS A70 lg1 Sw32 Soft FlashID: 0001/221D FlashID: 0001/227E-220C-2201 Flash Size: 8Mb, WriteBuffer: 32 bytes Region(1): Blocks 128, Size 64Kb Start EEPROM segments at addres 0xBC0000 FSN: 2AFD7B88 -> PhoneID: 887BFD2A OTP IMEI: 356342007451087 HASH: 19AA08CC539AA7C54C82DC47655F8BA6 Data file "F:\SIMMENS\FLASH FILE\A70\a70_v23\t9\A70_AB-05_T9.bin". Write Flash addr: 0xAB0000 size: 0x050000 - Ok. Open file "F:\SIMMENS\FLASH FILE\A70\a70_v23\manuel\A70_AB-05_MN.bin" for write in Flash. Start... Loading BootsModel(A70)... Sending StartBoot Ok. Sending MainBoot Ok. Com6 460800 BAUD: Ok. SIEMENS A70 lg1 Sw32 Soft FlashID: 0001/221D FlashID: 0001/227E-220C-2201 Flash Size: 8Mb, WriteBuffer: 32 bytes Region(1): Blocks 128, Size 64Kb Start EEPROM segments at addres 0xBC0000 FSN: 2AFD7B88 -> PhoneID: 887BFD2A OTP IMEI: 356342007451087 HASH: 19AA08CC539AA7C54C82DC47655F8BA6 Read EEP0067 block (ver00), size 20 bytes - Ok. Read EEP0076 block (ver00), size 10 bytes - Ok. Read EEP5005 block (ver00), size 64 bytes - Ok. Read EEP5007 block (ver00), size 10 bytes - Ok. Read EEP5008 block (ver00), size 224 bytes - Ok. Read EEP5009 block (ver00), size 10 bytes - Ok. Read EEP5012 block (ver00), size 12 bytes - Ok. Read EEP5077 block (ver00), size 232 bytes - Ok. Read EEP5093 block (ver00), size 76 bytes - Ok. Read EEP5121 block (ver00), size 56 bytes - Ok. Read EEP5122 block (ver00), size 6 bytes - Ok. Read EEP5123 block (ver00), size 12 bytes - Ok. EEPROM blocks is written in ".\Backup\A70lg1Sw32_Backup100210184208.eep" file. USE SKEY: 12345678 *#0000*12345678# - Network Lock *#0001*12345678# - Service Provider Lock *#0002*12345678# - Corporate Code *#0003*12345678# - Phone Code *#0004*12345678# - Network Subset Lock *#0005*12345678# - Only Sim Data file "F:\SIMMENS\FLASH FILE\A70\a70_v23\manuel\A70_AB-05_MN.bin". Write Flash addr: 0xAB0000 size: 0x050000 - Ok. Start... Loading BootsModel(A70)... StartBoot does not loded! Start... Loading BootsModel(A70)... Sending StartBoot Ok. Sending MainBoot Ok. Com6 460800 BAUD: Ok. SIEMENS A70 lg1 Sw32 Soft FlashID: 0001/221D FlashID: 0001/227E-220C-2201 Flash Size: 8Mb, WriteBuffer: 32 bytes Region(1): Blocks 128, Size 64Kb Start EEPROM segments at addres 0xBC0000 FSN: 2AFD7B88 -> PhoneID: 887BFD2A OTP IMEI: 356342007451087 HASH: 19AA08CC539AA7C54C82DC47655F8BA6 Use OTP IMEI: 356342007451087 USE SKEY: 12345678 *#0000*12345678# - Network Lock *#0001*12345678# - Service Provider Lock *#0002*12345678# - Corporate Code *#0003*12345678# - Phone Code *#0004*12345678# - Network Subset Lock *#0005*12345678# - Only Sim BCORE HASH is equivalent - not change. Read EEPROM addr: 0xBC0000 size: 0x030000... EEPROM backup in ".\Backup\A70lg1Sw32_EEPROM_100210184250.bin" file. Write EEPROM addr: 0xBC0000 size: 0x030000... Change BOOTKEY - Ok. Change EEP0076 - Ok. Change EEP5009 - Ok. Change EEP5077 - Ok. Change EEP5121 - Ok. Change EEP5122 - Ok. Change EEP5123 - Ok. ****** Joker Siemens EGOLD Phone Version 0.3.5.4 Inofficial closed. ****** ****** Wednesday, February 10, 2010, at 18:44:48 ****** |
02-10-2010, 15:34 | #7 (permalink) | |
Member: 770503 Status: Offline Thanks Meter: 1,215 | here another one a70 unlock done Quote:
n70 fffffffffff repaired successfully unlock done | omer100 | BB5KING | 1 | 11-30-2008 18:23 |
N95 Successfully UNLOCK done | gsm54 | BB5KING for (BB5BOX) | 2 | 11-20-2008 06:34 |
Z310i cid52 successfully unlock done without TP | Qaisar Mahmood | SETool2 | 0 | 05-25-2008 08:17 |
{***z240i success unlock done***} | GUDO-GSM | UST Pro II | 8 | 07-29-2007 18:13 |
