E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section. |
06-16-2004, 21:36 | #1 (permalink) |
Junior Member Join Date: Jun 2004 Location: Den Haag, The Netherlands Age: 35
Member: 68843 Status: Offline Thanks Meter: 0 | locked m55 phonecode |
06-16-2004, 22:06 | #2 (permalink) |
Freak Poster Join Date: Mar 2004 Location: U.K www.PhoneandIT.com
Member: 59991 Status: Offline Thanks Meter: 40 | very easy solution, Download sofware "Freia v.10" Software from web, http://web5.mn-server6.de/downloads/freia10.zip go to mobile shop and buy serial data cable (its cheap) for M55, come back home. Open Freia Software, from configuration settings, set port and speed 115200 . Connect cable and click on UNLOCKING FUNCTIONS in Freia software , Select "Unlock no map is saved" option click on OK Phone unlock. Go back to shop and return cable on -50%. This solution will cost you about 10EURO and be happy BR |
06-17-2004, 19:19 | #4 (permalink) | |
No Life Poster Join Date: Jul 2003
Member: 35101 Status: Offline Thanks Meter: 12 | Quote:
BEFORE YOU MUST KNOW : WHAT VERSION OF THE SOFTWARE INSIDE YOUR PHONE. IF THIS VERSION IS 11,YOU CAN'T UNLOCK SIMPLY YOU PHONE. WBR | |
06-17-2004, 22:21 | #5 (permalink) |
Member: 68843 Status: Offline Thanks Meter: 0 | I have v.10 a usb siemens datacable got the software but freia says that tge phone is not powered on? btw thanks peepz Last edited by Sander; 06-18-2004 at 10:46. |
06-18-2004, 13:37 | #6 (permalink) |
Freak Poster Join Date: Dec 2003 Location: Romania Age: 43
Member: 47388 Status: Offline Thanks Meter: 0 | if you have an original siemesn data cable it will not work you must have an NO NAME cable. You must turn the phone off then make a backup of eeprom and flash You can use freia 15 or m55tool by pgsm turn you phone off plug the no name cable then start the software. When the soft ask you to open the phone press the ON button shortley then the software must work. If it doesen't work in freia put the bootcore bug and tray again BUT first MAKE back-up fubus of eeprom and flash is safer in this way..regards |
06-18-2004, 18:20 | #8 (permalink) |
No Life Poster Join Date: Nov 2002 Location: INDONESIA
Member: 17360 Status: Offline Thanks Meter: 1 | nope! flashing is work with USB cable. i'm using original USB cable DCA-510 too. @Sander just make sure that your phone is turned off. and don't forget to check the configuration in Freia (port, baudrate). then "short" click the ON/OFF button when "COMM_LoadBoots : Waiting to power on the phone ..." message appear. |
Siemens M55 phonecode | carp | Phone Unlocking Codes & Maps | 0 | 10-01-2005 13:44 |
How to LOCK M55 to provider. | dissident | E-Gold Based Phones | 4 | 02-18-2005 20:08 |
can't lock m55 on network | bandrei2501 | E-Gold Based Phones | 7 | 06-14-2004 17:41 |
Unlock M55 Phonecode | d4uz | E-Gold Based Phones | 8 | 05-15-2004 10:54 |
m55 phonecode | damc23 | E-Gold Based Phones | 1 | 10-05-2003 00:17 |
