E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section. |
08-04-2006, 19:29 | #1 (permalink) |
Insane Poster Join Date: Jan 2001
Member: 3043 Status: Offline Thanks Meter: 0 | M55 totally dead - bootcore lost? Pls help Usual M55 unlocking procedure ended with unusual result: - I've uploaded px5amd java applet then patched the bootcore - all OK - Flashed goodc60bootcore.fls to the bootcore area with freia_v10.exe (M55, patched bootcore option) - all OK Now phone is really dead, it doesn't turn on or communicate with any prog. Battery is full. Is there any way to restore the bootcore and revive the phone? BR, TreshSD |
08-04-2006, 19:39 | #2 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: GEORGIA,Tbilisi
Member: 75765 Status: Offline Thanks Meter: 722 | Quote:
I must tell that two steps together are terribly nonsence and has nothing with unlocking ! Just first step was all about bootcore, you should just press unlock button ! I guess, phone cant boot now, you should make TP and write fullflash in it, for TP picture, flash and flasher, take a look on forum, all of them are available! Regards, B | |
08-04-2006, 20:57 | #3 (permalink) |
Member: 3043 Status: Offline Thanks Meter: 0 | Rather old phone type, but as I remember this was the way I used to unlock them. Here's the howto I used: 1-attach ur phone with card on ( the card that phone is locked for) 2-start the siemens software (mobile) 3-open the java folder..and next the jam folder 4-copy the java applet to this jam folder 5-go to surf & fun- games & more in ur phone..u should c px5amd there 6-Run this px5amd ( type 39116 and choose 2 for patching) 7-Run Freia 10 and choose write flash to phone..choose the bootcore from the laser...and choose bootcore in Freia 8-press unlocking functions in Freia..choose Direct unlock no map saved. and ur phone should be unlocked Now it's obvious to me that just simply using SST/Joker/etc would be more easier, but I'm an oldschool guy So after TP cut the phone will communicate again? This is great, that's the info I needed, thank you for it. The flasher/flash content is not problem, I have them all BR, TreshSD |
N96 unlocking error, 40 credits lost. pls help | fonERICKS | Universalbox | 23 | 04-15-2009 09:18 |
C35 dead after flash ???pls help??? | proxy_gsm | x1x to x45/x50 | 8 | 04-22-2004 16:19 |
dead sie A36 pls help | habib76 | x1x to x45/x50 | 2 | 12-16-2003 14:27 |
R210s dead by myself pls help??? | proxy_gsm | VLSI, Conexant, Skyworks and Old Models | 8 | 11-22-2003 06:46 |
TOTALLY DEAD ERICSSON T10s: Need HELP | jaron | Old Ericsson Phones & Sony Phones | 1 | 08-30-2000 00:45 |
