Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > E-Gold Based Phones
E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section.
Old 02-28-2004, 00:21   #1 (permalink)
Member: 47066
MC60 SECRET CODES? ANY1 have these?
Anyone know any mc60 secret codes. searching the net and all iv found is
1) IMEI number: * # 0 6 #
2) Software version: * # 0 6 #
3) Bonus screen: in phone booke: + 1 2 0 2 2 2 4 3 1 2 1
4) Net Monitor (S4 Power): Menu 9 8, left SoftKey, 7 6 8 4 6 6 6, Red phone, Menu 5 6
5)Tricks
<Check of the firmware version>
Enter *#06# press the green key and then the left softkey.
The three contractions show the supported language-coding processes:
- HR = Half Rate
- FR = Full Rate
- EFR = Enhanced Full Rate
<PIN2 modification>
The modifications can't be made by menu, only by the following key
combination: **042*oldpin2*newpin2*newpin2# the old Pin2 is mostly 0000.
<Quick access on "Environment">
If the Expert-mode is activated, you'll access the environment menu by
pressing the upper volme key. "fast" Language change
- *#0000# & "green key" = language automatically
- *#0001# & "green key" = language English
- *#0030# & "green key" = language Greek
- *#0031# & "green key" = language Dutch
- *#0032# & "green key" = language French
- *#0034# & "green key" = language Spanish
- *#0039# & "green key" = language Italian
- *#0049# & "green key" = language German
- *#0090# & "green key" = language Turkish
<WAP-Browser>
There is almost a WAP-Browser in the S25, but it's deactivated by most of the german
networks, because the browser doesn't support the current WAP specification 1.1 (just 1.0!).
<Language coding>
The different types of language coding modes are activated/deactivated by the following
inputs:
- *#3370# activates Enhanced Full Rate. The sound quality is increased. standby reduces
approx. 5%
- #3370# deactivates Enhanced Full Rate
- *4720# activates Half Rate Mode. The sound quality is reduced, standby increases approx. 30%
- #4720# deactivates Half Rate Mode
<Assistance to the menus>
If the menu-button isn't used by another function, it will show you the different menu options.
<Organizer>
The storage spaces of the integrated organizer are limited to only 30 entries.
<Display llighting>
It is possible to switch on the display illumination during activated key lock by pressing the
red button.
According to Siemens uses 1 minute light approx.. 1 hour standby.
<The buttons at the left side>
You can modify the volume during a call, scroll down through menus and fade out the lower menu
line during the reading of a SMS.
<Fast Dial>
The menu for Fast Dial modifications is placed at menu-setup-keys-left fast dial/right fast
dial. (9-4-1 or 9-4-2)
<Standby-time extension>
- Avoid repeated swichig between on and off
- Switch off the automatic network selection
- Use the silent alert only if necessary
- Use the IrDA only if necessary. You may place it on a fast dial button
- 1 minute light uses 1 hour standbyt
- 1 minute Cell Broadcast uses 30 minutes standby
- Switching the S25 on and announce to the network uses 2 hours standby
<Repeated SMS dispatch>
If the disptatch of a SMS failed, you can repeat the dispatch immediately by pressing the
lower volume key.
7) SP unlock *#0003*(secret code 8 digits)#
*#06# for checking the IMEI (International Mobile Equipment Identity)
MONITOR MODE
The Siemens S4 series also haves a Monitor mode that can be activated directly from the standard user keypad. In order to activate this mode, you must enter the special access code currently programmed into the phone.
TO ACTIVATE MONITOR MODE
1. Menu
2. 9 (Phone Options)
3. 7 (Phone Status)
4. Left Display Button (left MENU key)
5. 7684666
6. HangUp Button (Red HandSet key)
Now "Monitor" should appear at the bottom of the Network Options menu. Pressing the right Display Button when in monitor mode will show a list of the six cells with the strongest signals. Test Mode Indicators: (* = only available when call in progress )
8) Siemens Phone Codes
Mobile phone secrets, codes and technical information for Siemens Mobile Phone.
All Siemens Phones: Service Provider Unlock: *#0003*(secret code 8 digits)#
Siemens S25/C25
Menu, 9 (Phone Options), 7 (Phone Status), Left Display Button (left MENU key), 5553756, Hang-Up Button (Red Handset key)
Siemens S3 COM/S4
Menu, 9 (Phone Options), 7 (Phone Status - 8 on Some), Left Display Button (left MENU key), 7684666, Hang-Up Button (Red Handset key)
Note: Now Monitor should appear at the bottom of the Network Options menu.
MONITOR MODE
Pressing the right Display Button when in monitor mode will toggle into 1 and 2 modes
CH Channel Number
RX Signal Strength (dB)
N NCC (Colour Code)
B BCC (Colour Code)
CI Cell ID (in Hex)
C1+ How long before phone does forced hand over. (see RX and RXAM)
LAI Location Area Identity. Display Network ID code (42F010 = 240.01) and MSC
TXPWR Transmit Power (dB)
RXAM Receive signal strength cut-off point
TS* Time Slot Number
TA* Timing Advance. Distance from tower in Km X 2
PL* Power Level
POWER table
PL: 5 6 7 8 9 10 11 12 13 14 15
dB: 33 31 29 27 25 23 21 19 17 15 13
Watts: 2 1.3 .8 .5 .3 .2 .13 .08 .05 .03 .02
LF* C1 value with continuous transmission from tower
LS* C1 Value with discontinuous transmission from tower
QF* Bit Error Rate with continuous transmission from tower
QS* Bit Error Rate with discontinuous transmission from tower
BER (bit error rate) table
QF/QS register: 0 1 2 3 4 5 6 7
% of bit sent: 0.2 0.8 0.4 1.6 3.2 6.4 12.8 25.6
Siemens S1/S3
Here's a trick to play Tetris, also known as Klotz on a Siemens S1.
Turn the phone on. Enter PIN. Before the telephone has logged in to the your GSM net do the following steps.
1: Choose F 9 (function settings)
2: Choose send own number and push the right button for choose.
3: Push 9
USE 2 as < and 8 as > , rotate the klotz with 5 and drop with 4.
[I have just heard from one of the programmers of the phone that Tetris was in the phone during development, but it was removed before it was produced. Apparently someone has the patent on games in mobile phones and Siemens didn't want to pay the licensing fees. It was either in Menu F-9-9 or it's not there at all.]
Siemens S3 Comfort
MONITOR MODE
The Siemens S3 Com series have a Monitor mode that can be activated directly from the standard user keypad. In order to activate this mode, you must enter the special access code currently programmed into the phone.
TO ACTIVATE MONITOR MODE:
Turn the phone on.
Enter the PIN access code on press OK. (Only if is enabled).
Press Menu. (Left top button).
Press 9. (Phone Options).
Press 8. (Phone Status) (May be button 7 in some phones).
You may see your IMEI Number
Left Display Button (Top left MENU key).
7684666
Hang-Up Button. (Red Handset key).
Note: Monitor should appear now at the bottom of the Network Options menu.
MONITOR MODE
Siemens S4/S4 Power
In phonebook under "Own Phone No." enter +12022243121 (which is the number to the White House) and you'll get a greeting from the people who programmed the phone.
MONITOR MODE
The Siemens S4 series have a Monitor mode that can be activated directly from the standard user keypad. In order to activate this mode, you must enter the special access code currently programmed into the phone.
Menu, 9 (Phone Options), 7 (Phone Status), Left Display Button (left MENU key), 7684666, Hang-Up Button (Red Handset key)
CH Channel Number
N NCC (Color Code)
B BCC (Color Code)
CI Cell ID (in Hex)
C1+ how long before phone does forced hand over. (see RX and RXAM)
RXAM Reeceive signal strength cut-off point
PL* Power Level
Power Table
Siemens S6/S10
In Phonebook, store as your own number: +12022243121
Then you get the sun and two palms in the display, also a greeting message of the "MMI-team".
It has been said that the phone number is the number of the Capitol building in Washington, DC (but not sure).
Siemens S15 Secret Menu's
Press * -> # -> 7 -> 4 -> 3 -> 6 -> 3 -> 6 -> 7 -> * -> 8 -> 3 ->
7 -> 8 -> # ,press clear key to clear screen and return to
stand-by mode
press Menu, it will show additional menu
Menu 3.3.4 Band selection,
Menu 3.3.4.1 Automatic band selection,
Menu 3.3.4.2 select GSM 900 only,
Menu 3.3.4.3 select GSM 1800 only,
Old 02-28-2004, 18:28   #2 (permalink)
Member: 30542
Hi!
This Netmonitor codes dont works on MC60v10.
Which version, where this codes is work?
Old 04-25-2007, 07:54   #3 (permalink)
Member: 495384
how to find out the secret code to unlock my siemens AL21
*0003*secret code.....
thanks
c205"PHONE CODE" any1 have master reset code mohammed ODM (Original Design Manufacturing) 13 06-26-2008 08:40
Does any1 have converters for polyphonics reo GSM Mobile Links 0 11-19-2003 20:32
any1 have dct3 flasher box hex file? gsm-lord Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 07-29-2002 01:56
does any1 have the hex file to update the Motorola clip ? reo Old Legacy Motorola (EMMI) 9 10-31-2001 14:00
Any1 have an IMEI-hex-patcher for the Nokia 5110? luuk Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 03-19-2000 20:06
Page generated in 0.24964 seconds with 11 queries
