E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section. |
12-30-2004, 23:31 | #1 (permalink) |
Junior Member Join Date: Dec 2004 Age: 62
Member: 102031 Status: Offline Thanks Meter: 0 | MC60 unlock & freia15 problem I have tried running the freia15 software but it is saying bootfile is not accepted when I try running it. I have checked the com port is ok (usb com3) but still cannot do anything with the software. Does anyone have any ideas or suggestions? Thanks |
12-31-2004, 00:17 | #2 (permalink) |
No Life Poster Join Date: Aug 2004 Location: With old & new friends Age: 49
Member: 79640 Status: Offline Sonork: 1577251 Thanks Meter: 238 | hi 1- If SW version of phone is less then ver 10 : use MC60 unlocker by sEBaGSM 2- Else use Frei build 10 cracked (select MC60 not MC600 boot) + test point wich is same as A60 and C60 (take care when cuting the track) U ll find th softs and test point photos en : unlockeasy.com in download section good luck |
12-31-2004, 09:55 | #4 (permalink) | |
No Life Poster Join Date: Jan 2004 Location: Life's a Journey Age: 44
Member: 49495 Status: Offline Sonork: 100.9 & 100.12345 Thanks Meter: 1,026 | Quote:
12-31-2004, 13:52 | #6 (permalink) |
Member: 79640 Status: Offline Sonork: 1577251 Thanks Meter: 238 | C60 A60 and MC60 test point U have to open phone then take of carefully the metal cover and cut with a drill the track as in attached pic later run freia 10 choose MC60 and unlock ur phone 100% tested |
01-01-2005, 15:13 | #7 (permalink) |
Member: 102031 Status: Offline Thanks Meter: 0 | Hi again DZ. I have opened up the phone and removed the metal plate. The picture you have posted looks like the inside of the phone already. As you can probably tell I have never done this before, which part of the picture is the test point? kittybird (neil) |
01-01-2005, 18:34 | #9 (permalink) |
Member: 102031 Status: Offline Thanks Meter: 0 | I have tried installing and running px5amd but when I run it I get an error message 'failed to load ,aim-class manifest from.....' I have read that you can change the java program manually but I do not know how to. Greatly appreciating all the suggestions and having fun trying, but as yet, no luck |
01-01-2005, 19:03 | #10 (permalink) |
Member: 79640 Status: Offline Sonork: 1577251 Thanks Meter: 238 | i tried java application but after executing it freia says always boot file not accepted and i was obliged to cut the track : not easy but 100% working br |
01-01-2005, 19:10 | #11 (permalink) |
Member: 102031 Status: Offline Thanks Meter: 0 | If I do have to cut the test point I am still not sure, from the picture, what I am supposed to be cutting with the drill as the inside of the phone looks exactly as the picture does already and I do not know what I am missing? |
01-01-2005, 19:19 | #12 (permalink) |
No Life Poster Join Date: Sep 2004 Location: Serbia
Member: 82990 Status: Offline Thanks Meter: 106 | 100% working solution!!!!!!!! Cut test point (see attachment picture) and use freia 10 software. select mc60 phone type, normal boot, and just click unlock |
05-13-2006, 16:55 | #15 (permalink) | |
Freak Poster Join Date: Jan 2006 Location: Poland
Member: 221472 Status: Offline Thanks Meter: 8 | Quote:
Regards Axe Man | |
Need help unlocking MC60, C65 & S55 | joe7338811 | Wanted Products | 0 | 11-23-2006 18:25 |
freia15 problems.. | lavzy | E-Gold Based Phones | 28 | 10-20-2005 09:46 |
D500 Unlocking & Flashing Problem with v3.2.2 | fonetech | NSPRO | 5 | 08-06-2005 07:59 |
MC60 unlocking problems | christesh | E-Gold Based Phones | 10 | 05-09-2004 15:38 |
mc60 unlock & flash | mr_ace_sk | E-Gold Based Phones | 1 | 04-30-2004 10:24 |
