E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section. |
03-28-2008, 06:58 | #2 (permalink) | |
No Life Poster Join Date: Dec 2006
Member: 416908 Status: Offline Thanks Meter: 398 | Quote:
first you need to know which flash you have inside (Intel flash - 8MB or AMD flash -16MB). I have functional A75 fullflash FW41 (last firmware) but language pack 03. Tonight i will realise fullflash with language pack 01 (italian language inside), but only for Intel chipset. Br, dagos | |
03-28-2008, 14:40 | #3 (permalink) |
Freak Poster Join Date: Sep 2003 Location: italy
Member: 38660 Status: Offline Thanks Meter: 6 | why i have this error??? Open file "C:\Documents and Settings\Windows\Desktop\programmi cellulari\siemens\Nuova cartella\A75_80-80_FF.bin" for write in Flash. FullFlash file info: FlashID: 0001/220C SIEMENS A75 Sw20 lg98 RealLgPack: lg4 Start... Loading BootsModel(A75)... Error: Load StartBoot answer code 0x03! Open file "C:\Documents and Settings\Windows\Desktop\programmi cellulari\siemens\Nuova cartella\A75_80-80_FF.bin" for write in Flash. FullFlash file info: FlashID: 0001/220C SIEMENS A75 Sw20 lg98 RealLgPack: lg4 Start... Loading BootsModel(A75)... StartBoot does not loded! n.b my cellular phone when i turn on he turn off please help me |
03-29-2008, 09:30 | #4 (permalink) | |
First, you cut way to make the testpoint (see picture in Joker -> TP)? If way is cutted correctly, you need to make fullflash with "Protect BCore" option unchecked and "ReCalc Keys" option checked (in the Flash menu). Download fullflash from http://rapidshare.com/files/99440022/A75_4103_FF.rar , flash with this options and post results. dagos | |
The Following User Says Thank You to dagos For This Useful Post: |
03-31-2008, 11:55 | #5 (permalink) |
Member: 38660 Status: Offline Thanks Meter: 6 | Start... Loading BootsModel(A75)... Sending StartBoot Ok. Sending MainBoot Ok. SIEMENS A75 lg3 Sw41 Soft FlashID: 0001/220C FlashID: 0001/227E-220C-2201 Flash Size: 8Mb, WriteBuffer: 32 bytes Region(1): Blocks 128, Size 64Kb Start EEPROM segments at addres 0xFC0000 FSN: 75AACC9F -> PhoneID: 9FCCAA75 OTP IMEI: 358089001012906 HASH: FCC5ED6E6112BF632331C85B17D5C610 Read EEP0067 block (ver00), size 20 bytes - Ok. Read EEP0076 block (ver00), size 10 bytes - Ok. Read EEP5005 block (ver00), size 64 bytes - Ok. Read EEP5007 block (ver00), size 10 bytes - Ok. Read EEP5008 block (ver00), size 224 bytes - Ok. Read EEP5009 block (ver00), size 10 bytes - Ok. Read EEP5012 block (ver00), size 12 bytes - Ok. Read EEP5077 block (ver00), size 232 bytes - Ok. Read EEP5093 block (ver00), size 76 bytes - Ok. Read EEP5121 block (ver00), size 56 bytes - Ok. Read EEP5122 block (ver00), size 6 bytes - Ok. Read EEP5123 block (ver00), size 12 bytes - Ok. EEPROM blocks is written in ".\Backup\A75lg3Sw41_Backup080331122800.eep" file. USE SKEY: 12345678 *#0000*12345678# - Network Lock *#0001*12345678# - Service Provider Lock *#0002*12345678# - Corporate Code *#0003*12345678# - Phone Code *#0004*12345678# - Network Subset Lock *#0005*12345678# - Only Sim WriteFlash: Segment Size error=0x50 at block 0xDE0000! help me |
03-31-2008, 16:27 | #6 (permalink) | |
dagos | |
04-01-2008, 05:53 | #8 (permalink) | |
Normarly, Joker use 115200 bauds for comunication... Which type of cable you use??? Theoretically, this error appair if using not optimal baudrates. Try to use C55 serial cable (or USB DCA510 cable) and Joker version 3.5.6c. If this message appair again, use for flashing SST 5.38 (cracked by BB-gsm) and unlock your phone after flash. Post results, I'm currious dagos | |
Vodafone 332 FM unsuported. Link with full flash | stargsm_ro | FuriousGold | 1 | 03-29-2010 19:54 |
I need A75 Full Flash A75lg92Sw41_80-80_FF | .:HeRo:. | E-Gold Based Phones | 2 | 03-17-2008 04:58 |
I need full flash for A75 with lang polish ....help:) | MarcinH | E-Gold Based Phones | 4 | 03-15-2008 12:07 |
add language ITA | misterdey | Scout | 1 | 08-16-2007 18:30 |
Need Full Flash A75 for joker | stargsm_ro | E-Gold Based Phones | 5 | 09-11-2006 09:34 |
