E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section. |
01-09-2004, 11:00 | #1 (permalink) |
Junior Member Join Date: Jan 2004
Member: 48833 Status: Offline Thanks Meter: 0 | New to siemens need help please im quite new to siemens mobiles its different from others i was searching on the net & i found this is the best siemens forum i saw i have some questions please i tried to upgrade a55 with WINSWUP but it works on some phones but on another it dosnt work is there difference between some phones(i mean hardware) I dont understand what are the testpoints Please help |
01-10-2004, 03:06 | #2 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Germany Age: 37
Member: 41076 Status: Offline Thanks Meter: 53 | Of course is there a difference! For A55 u need a Winswupfile for A55 For C60 u need a Winswupfile for C60 For S55 u need a Winswupfile for S55 ...so go on! |
01-10-2004, 10:35 | #3 (permalink) |
Member: 48833 Status: Offline Thanks Meter: 0 | Hello Chris02 & Thank you for your reply I already done that i have winswup file for a55 but it didnt work for my a55 it works with me on another a55's only on my a55 didnt work so i was thinking maybe there is a different between 2 a55s im searching for another way to flash a55 any idea? Thanks |
01-10-2004, 11:04 | #5 (permalink) | |
Registered User Join Date: Jan 2003 Location: Wild Wild East Age: 55
Member: 20027 Status: Offline Thanks Meter: 5 | Quote:
2. Check SW version. Downgrade with Winswup not possible! 3. If wour phone unlocked by testpoint (cut track T9), Winswup not work never! Check this by Freia, no need opening the phone. If repair T9 testpoint not possible try with fullflash solution! 4. Go to the serial parametrs and try with speed 57 600! | |
01-11-2004, 09:28 | #6 (permalink) |
Member: 48833 Status: Offline Thanks Meter: 0 | Hello & Thank Guys my phone quite new not opened yet & i openit only for be sure its new nothing happened in it Thank you Prasse my problem now is not to convert my a55 to c55 im confused that my a55 cant upgraded with winswup with normal a55 file & when i tried on another phones it works only yesterday another phone comes to me & have the same problem !!! I cant understand whats happens only for my phone i checked every thing is possible tried to change winswup speeds no thing it works on another phones only for mine not work Can i update with another solution Like reading flashfile from another a55 working & flash it to my phone if its possible PLEASE Give me the way I will appriciate That Thaaaaaaaanks |
01-11-2004, 17:43 | #7 (permalink) |
Member: 41076 Status: Offline Thanks Meter: 53 | To write an other fullflash from an other A55 into your A55 is bad! Because batteryparameters, contrast.... Try this: Power on pone connect with cable start Winswup don't set any hook by "skip" press "start" now winswup will turn off you phone and start update! It works with an original Siemens cable too! |
01-13-2004, 09:23 | #8 (permalink) |
Member: 48833 Status: Offline Thanks Meter: 0 | Big thanks to you CHRIS02 It seems like working idea im just now doing that i set the speed on the slowest speed so it will take time to do that I will tell you later what happens thanks for the greatest idea given to me on the net |
01-13-2004, 22:01 | #9 (permalink) |
Member: 41076 Status: Offline Thanks Meter: 53 | I flash with high speed! It works perfect! I need ~6min for a SL55 update 12MB! And u don't need the "high speed flashing patch"! @janosandi Buy a fair cable |
01-14-2004, 09:01 | #10 (permalink) |
Member: 48833 Status: Offline Thanks Meter: 0 | Thanks Chris It takes about 75 minutes to do that it works perfect thank you yesterday at midnight I've bought a new one for my friend i test it on speed 115200 it works perfect thank you again I will search for you for my questions in the future if you dont mind bey |
New with box need help please | eljapa | VygisToolbox | 1 | 10-05-2009 00:16 |
NEw user setoll need help !!!! please | maniek27 | SETool2 | 3 | 09-12-2008 08:21 |
new to forum need help plz | mrclion | VLSI, Conexant, Skyworks and Old Models | 4 | 12-30-2007 12:58 |
New To Cloning need help. | realbg | Sim Cloning and Scaning | 1 | 08-11-2007 08:16 |
New to this need help please. | esh415 | Various CDMA/TDMA Cell Phones | 0 | 03-07-2005 01:58 |
