E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section. |
06-12-2004, 05:40 | #1 (permalink) |
Junior Member Join Date: Jun 2004 Age: 44
Member: 68591 Status: Offline Thanks Meter: 0 | PHONE wont boot anyway to make it boot? i am having so many problems with this m55, i did to install some bin file 10version on it, and now the phone wont boot up at all it wont turn on, though when i run friea, and press power on button it seems to work but it wont boot up any suggestions? what can i do? i download v11 fls files, and it wont write to the phone |
06-13-2004, 01:28 | #5 (permalink) |
Freak Poster Join Date: May 2004 Location: mladenovas,serbia Age: 45
Member: 67014 Status: Offline Thanks Meter: 1 | http://shaaker.uw.hu/testpoint.zip that is testpoint cut the line and try than!!! Last edited by johnnymld; 06-13-2004 at 01:28. Reason: mistake |
06-13-2004, 07:33 | #7 (permalink) |
Freak Poster Join Date: Mar 2004 Location: U.K www.PhoneandIT.com
Member: 59991 Status: Offline Thanks Meter: 40 | @lastdon I had same problem, just made my phone alive. here are instrustions, 1. User Freia 10 , [settings {configuration Function} Speed: 115200 Process: Medium boottype: bootcore bug 2. Download complete flash file from "Flash Siemens v.11 M55 para freia" http://www.unlockeasy.com/modules.ph...ownload&cid=50 3. come back on Freia10, click on "Write flash to Phone" now write all four flashes to phone, EEPROM , Bootcore , Boot, Firmware Full flash of 14MB (bootcore and boot file will be flashed froim Bootcore option of Freia) 4. After flashing phone Press "Unlocking functions" and select "Direct unlock no map is saved" and "USE ORIGINAL IMEI" Press red power button when the program ask for it. Now remove cable from phone, remove battery from phone for about 10 secs. insert battery, and that is how my phone got alive. Best regards, mazhar |
06-13-2004, 22:48 | #8 (permalink) |
Member: 68591 Status: Offline Thanks Meter: 0 | well i used friea, and the bootcore bug that is the only way it would work. go the file above.. and when i went to write flash, selected what i had to do it would say cant not write blah blha so before hand i had done some bin file flash update. from that same site mentioned in the other post for version 10. and now i am screwed! |
06-13-2004, 23:45 | #9 (permalink) |
Member: 59991 Status: Offline Thanks Meter: 40 | 1. Select bootcore bug in configuration section , and go to Unlocking section and check the option UNLOCK NO MAP SAVED... then click on USE original IMEI, after this when all is done , remove the battery and insert back after 10 secs. If this does not work try method 2. Method: 2) Download M55 Freia Flash files, and flash completely EEPROM, BOOTCORE, BOOT and FIRMWARE ... FULLFLASH | 000000~FFFFFF | FFFFFFh bytes ????????? | 000000~1FFFFF | 200000h bytes FIRMWARE | 200000~FFFFFF | E00000h bytes LANG-PACK | 7A0000~7FFFFF | 060000h bytes M55 BOOT | 800000~9FFFFF | 200000h bytes BOOTCORE | 800000~80FFFF | 010000h bytes T9 LANG | 880000~8AFFFF | 030000h bytes FLEXMEM DISK A | D00000~EFFFFF | 200000h bytes FLEXMEM DISK B* | A80000~AEFFFF | 070000h bytes EEPROM | FC0000~FFFFFF | 040000h bytes Check addresses for flash files, after flashing remove and re-insert battery. Hope it must work. All the best. BR Mazhar |
Nokia 6700 Classic. Is there anyway to flash it succesfully ???? | eskerra | HWK | 3 | 01-28-2010 00:48 |
N95 with 31.0.017. Anyway to crack it? | HardSlam | Nokia Multimedia | 6 | 12-14-2009 06:16 |
dead v70...anyway to make it turn back to life? | SicilianBoy | Motorola P2k | 3 | 06-28-2007 20:50 |
L6i and mp3 ringtones - how is it possible to make it work | Carlos555 | Motorola P2k | 3 | 12-12-2006 11:17 |
ZV40 phone FREEZE, i can make unlock but phone still freeze, how to fix it ? | PSG | UST Pro II | 1 | 10-19-2006 20:31 |
