Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section. |
| | #2 (permalink) | |
| Moderator ![]() Join Date: Dec 2006
Member: 416908 Status: Offline Thanks: 3
| Quote:
user: mobile password: elibom firmware update (with your country language pack - I suppouse LG07) and flash it using data cable (and phone is powered on). Fullflash files is used only if your phone is crashed... If you needed the fullflash file, go to http://rapidshare.com/files/159989380/c60v27full.rar and download archive. Fullflash it and after make the firmware upgrade with your country language pack (see on attachemment). dagos Last edited by dagos; 03-27-2010 at 04:12. | |
| | #3 (permalink) |
| Insane Poster ![]() ![]() ![]() Join Date: Mar 2004 Location: china Age: 33
Member: 57286 Status: Offline Thanks: 20
| thank's reply. i download C60_270700_service ,but it's can't connect the phone? C60_270700_service isn't supper the intel falsh ?have Chinese language ? |
| | #4 (permalink) | |
| Quote:
If you cut track in your phone to realise testpoint for flashing/ unlocking, of course not is working. In this case you need to use the service cable, open WINSwup file, check "Skip" Pre-Check and Post-Check, configure com port and baudrate to 115200. Click on "Start" button and push quicly power on button from your phone (your phone need to be in Power off status). Regarding to the language pack for your country (see in my last post -attachemment), I suppouse to need to have LG07... dagos | |
| | #6 (permalink) | |
| Quote:
-pin2: GND -pin3: TX -pin4: RX dagos Last edited by dagos; 03-27-2010 at 04:11. | |
| | #7 (permalink) |
| yes ,i try ,but C60_270600_service no connect the phone and JokerV0343 no conect the phone now please give me the file c60v27lg07 for sst ![]() thank's the service config is right? |
| | #8 (permalink) | |
| Quote:
To use Joker: -to connect with Joker, you need to cut one way in your phone. Open Joker and click on TP to see which way you neet to cut. -select phone type A65/C60; COM Port wich you use with the SERVICE cable (data cable not working); com speed to 115200; Bot Typ to Normal. -go to the Service menu, click on Service Mode button and push shortly to the power on button from your phone. In the right application window, needed to apeair the all information about your phone. Now you entered in Service Mode. - Go to the Flash menu and select FullFlash; check after Protect BCore (is esential!!!) and Recalc. Keys -Click on the Write button and wait to finished. Now your phone is flashed and unlocked. To use Winswup file: If way in your phone is cutted, you need to flash firmware with the other methode: -open winswup file and select baudrate and com port. In your picture, I see to you configurated corectly! -connect the SERVICE CABLE to your phone, check "Skip" pre-check and "Skip" post-check. -click on Start button and push shortly power on button from your phone. The progres bar in the Connect Mobile section quicly will be full. After will started Erase Flash..... -wait to finish it and power on your phone.... If the way not is cutted, is easy! Open winswup file, set connection parameters, connect DATA CABLE, power on your phone, click on Start button and wait to finished flashing process. After this process is finished, your phone will start automatically! Is needed to know: -DATA CABLE is cable to transfer files beetwen your phone and PC using one of the Phone Manager software. Is used any Siemens cables type, except the C55 serial data cable. This is the one of the Service Cable in E-Gold and S-Gold phones. USB cables like DCA510 (have inside USB to serial converter chip) is used for Data and Service cable (dual functionality). -Service cable is the serial cables like C55 darta cable, DCA500 and the cables used with the boxes. That is, dagos BTW: not is easy to find fullflashes with the chinese language. Maybe one of the members from China make backup from his C60 phone and give to you. Not essential, for Joker or SST, is the same. | |
| | #9 (permalink) |
| thank's Replies once more ,please look,the joker is ok connect the phone but the WinSwup isn't connect the phone ,you said the lg07 is only someone backup but no one have it ,just i only use the WinSwup ,but it isn't connect my phone ,wo can i do ? the way is cuted) |
| | #10 (permalink) | |
| Quote:
you need to unlock. Enter in Service mode (in the Service menu) and click to Read + Calculate keys). Regarding to the firmware upgrade to your Language pack, I will return. dagos | |
| | #11 (permalink) | |
| Quote:
Open winswup file, set connection parameters, connect DATA CABLE, power on your phone, click on Start button and wait to finished flashing process. After this process is finished, your phone will start automatically. Plese give to me which type of cable you use? dagos | |
| | #13 (permalink) | |
| Quote:
dagos | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Please give me a help for my T720 | seahome | Phone Unlocking Codes & Maps | 0 | 11-14-2003 01:39 |
| Please give me the code for the following phone | charly007 | Phone Unlocking Codes & Maps | 2 | 02-21-2003 21:36 |
| Please Give Me Best Price For Logs! ! ! | CobWeb | Wanted Products | 0 | 01-17-2003 10:08 |
