Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > E-Gold Based Phones
E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section.
Old 06-05-2005, 20:42   #1 (permalink)
Member: 48916
Siemens C60 dead after unlocking with Freia for UFS3
Hi! I've got a problem with Siemens C60, v.20, I've done testpoint (cut track), successfull - it was comunicating with freia v.15 and freia for UFS3, but I've got a brand new cable for x55 with my UFSx box, so I've used USB/UFS cable with the modified freia. Problem is, I did sw backup, but no bootcore backup, and after 'unlock' function phone's dead. freia (COM version) v15 doesn't see the phone any more, but the one for UFS sees it without any problems, nor no flash updates are helping to change its state... Heeeeeelp !!!???
best regards, stil
Old 06-05-2005, 20:51   #2 (permalink)
Member: 58460
Mail me private man
Old 06-06-2005, 07:33   #3 (permalink)
DMD
DMD's Avatar
Member: 12660
@ stil
You need to write full flash should be 14mb then just rewrite original IMEI that should repair the handset
Regards D.
Old 06-06-2005, 22:28   #4 (permalink)
Member: 48916
Thanks, I've got communication back, one question, should I use 'C60' or 'C60 boot', and do I have to write just FUBU 14mb flash, or maybe eeprom or bootloader as well? After flashing select just 'use original IMEI' or maybe 'IMEI flash update'? I'm dumb if it goes to Siemens software, few years ago I was good at that, now, I don't know much...
Old 06-06-2005, 22:46   #5 (permalink)
randy_d4's Avatar
Member: 71246
HI
First try only with firmware 14mb(select C60 for model,NOT C60 boot) after flash go to unlocking functions>direct unlock no map is saved>use original IMEI!!!
Post result for more hints
Old 06-08-2005, 16:58   #6 (permalink)
Member: 151576
Sonork: 100.1602537
My c60 is dead from where can i find the 14mb flash file for ufs3.pls help me
siemens e71 dead after unlock with dreambox HERBERT23 DreamBox 1 10-06-2009 13:59
Siemens S56 dead after unlocked with sst godwin E-Gold Based Phones 2 07-21-2009 19:24
C60 dead after unlock with martech MadPhone SIEM Service Tools 4 06-05-2005 09:39
A55 completely dead after messing with freia to upgrade to C55 brinx Siemens Hardware Repair Area 9 03-23-2005 17:06
sl55 Dead after unlock with freia mohammed E-Gold Based Phones 4 12-17-2004 20:47
Page generated in 0.24654 seconds with 11 queries
