E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section. |
05-30-2004, 14:26 | #1 (permalink) |
Freak Poster Join Date: Apr 2004 Location: UK Age: 53
Member: 63354 Status: Offline Thanks Meter: 1 | SL55 Filesystem empty after flash...? I flashed an SL55 with the firmware read from another SL55 the file name was SIEMENS SL55 LG2 V14 - 00400000-2004.03.01-13.58.58.FLS. Not normally a problem as I had also used this file before to repair dead phones, but this time all the contents of the Siemens FILESYSTEM were deleted. The folders are still there but the actual tones and pictures etc have been wiped. Can anyone suggest a way of reloading all these standard files. Any help much appreciated. WBR Blade |
05-30-2004, 16:17 | #3 (permalink) |
Member: 63354 Status: Offline Thanks Meter: 1 | OK........ Any ideas where I can get DES....? Oh and ppl please, no answers of use this serach engine or that search etc... If you can be bothered to write that much then some constructive direction needed, else no need to write anything. THX Blade |
05-30-2004, 19:05 | #5 (permalink) |
No Life Poster Join Date: Nov 2002 Location: INDONESIA
Member: 17360 Status: Offline Thanks Meter: 1 | well, your flexmem's wiped out coz you was reflash the fullflash taken from other phone. then your flexmem will be what-n-how the source is. DES and the original contents of SL55 flexmem should be in a place as Shaaker shown. |
N95 vibrate then cutoff after flash [SOLVED - Thanks Crazy Ratata] | jus_chillin | Cyclonebox | 19 | 03-29-2010 11:57 |
???Garlery is empty after flash | quybk | Nokia Digital Core Technology 4 ( DCT-4 ) | 14 | 11-21-2007 06:30 |
sl55 battery empty. | manyosa | Siemens Hardware Repair Area | 12 | 04-10-2007 12:03 |
6600 gallery empty after flash | gorgans | MT-BOX | 15 | 02-01-2007 08:25 |
RH-12 content is empty after flash with MT. | drag | MT-BOX | 8 | 01-19-2007 18:46 |
