E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section. |
08-26-2004, 06:16 | #1 (permalink) |
Banned Join Date: Aug 2004 Location: Gsm Unlockers Awareness Report
Member: 76978 Status: Offline Thanks Meter: 15 | SL55, MC60, C60 & M55 "NO" Test Points I have come to reason that the same solution (software) works for all four phone types: SL55, MC60, C60 & M55. I copied and edited the following from (www.unlockeasy.net) Please Note: went using KEYWORDs [glow=red] "Siemens (phone of choice)" [/glow] means the you can choose ONLY one of phone types that is SL55 or MC60 or C60 or M55 for the examples. Now lets get started:: Software required: Freia build 10 or higher, Siemens Dataexchange Software v.2.67, Siemens C60 Bootcore & PX5AMD Java Application for M55. Unlocking: 1º - First install "Siemens Dataexchange Software v.2.67" software, power on the mobile phone, connect the cable and run the software. The phone must be without SIM card inside. 2º - Go to /java/jam/ folder and create a new folder, upload inside the two PX5AMD Java aplication archives (.jad & .jar). 3º - Now power on the "Siemens (phone of choice)" with a SIM card inside and run the Java aplication. This aplication will ask you for a code, code = 39116. Then you will see a menu, first select "backup bootcore", second select “patch bootcore” option and in a few seconds the phone will turn off. To finish repeat this process again and you will receive "Already OK" message. In this moment the bootcore will be patched. 4º - In this stept is very important make a full backup firmware with "Freia build " software selecting "Siemens (phone of choice)" type phone. If something goes bad you will have a good backup of your mobile phone to resolve the problem. 5º Now is time to flash the “patched bootcore C60". Run the software (Freia build 10), select "Siemens (phone of choice)" phone type , in "Configuration Functions" options select "Patched bootcore", press on “Write flash to phone” button, select “goodc60bootcore.zip.fls” flash file, click on “bootcore” box and press “OK” button. Software will ask to press ignition button of the mobile phone, press it and the software will flash the phone in a few. 6º - The final stept is to unlock the mobile phone. Select "Siemens (phone of choice)" i.e. Sl55 phone type, with "Freia build" software and unlock the "Siemens (phone of choice)" i.e. Sl55, with "Direct Unlock no map is saved" option and the software will unlock the phone in a few seconds. Suggestions: · Mobile phone battery must be full charged. · Never disconnect the cable while phone is unlocking. · Is very important select "Siemens (phone of choice)" phone type and no "Siemens (phone of choice) boot". If you select "Siemens (phone of choice)" boot", you will kill your phone. [glow=red] This my reasonig correct !!![/glow] |
08-26-2004, 15:27 | #2 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2003 Location: gsmcity Age: 44
Member: 21296 Status: Offline Thanks Meter: 328 | For M55 you don't need to exchange the bootcore, just unlock without exchanging bootcore, and as for the SL55 I didn't tried it, don't have any phone to try it, has anybody tried it??? |
09-16-2004, 23:29 | #4 (permalink) | |
Member: 76978 Status: Offline Thanks Meter: 15 | Quote:
read http://forum.gsmhosting.com/vbb/show...86&postcount=3 By the way you can also add CF62 to the list. Regards, Last edited by ednacell; 09-18-2004 at 14:37. | |
09-24-2004, 00:07 | #5 (permalink) | |
Member: 76978 Status: Offline Thanks Meter: 15 | Include CF62 in the list anymore?? Quote:
09-26-2004, 03:00 | #6 (permalink) | |
If you are interested you can pick-up a copy on how to unlock SL55. http://people.itu.int/~emartine/ and for SL55 V16 Testpoints go to: http://gsmfree.vipserver.ru/Siemens...s_Testpoint.htm | |
mc60,c60,a60,m55,a65,s55 Wishmaster | ahmet karacula | Siemens Hardware Repair Area | 29 | 08-20-2006 20:28 |
///___Siemens M55 V11 test point her__/// | bakarioss | E-Gold Based Phones | 8 | 02-27-2004 23:48 |
M55 unlock, test point pc problem | DelBoyTroter | E-Gold Based Phones | 1 | 02-05-2004 20:43 |
cannot unlock c60 with freia 9 ,test point cuted ,BOOT FILE NOT ACCEPTED. | crossings | E-Gold Based Phones | 9 | 01-19-2004 17:20 |
