E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section. |
04-09-2005, 15:01 | #1 (permalink) |
Junior Member Join Date: Oct 2004 Age: 54
Member: 84992 Status: Offline Thanks Meter: 0 | SL55 & the switching off problem... read some of your posts regarding the same problem tried various FUBU's using Winsup program, friea just gives a boot file error (although it unlocked the phone). Have tried with testpoints to gnd on and off - no different Is there a known fix yet for this problem?? Need some help Thanks in Advance |
04-09-2005, 18:34 | #3 (permalink) |
Member: 84992 Status: Offline Thanks Meter: 0 | Have tried maybe 6-8 flashes and still switches off, what do you mean by the friea boot config, ive tried all the options of the boot type, normal, patched and bootcore bug but dont know which one i should use any more help |
04-10-2005, 22:46 | #4 (permalink) |
Registered User Join Date: Dec 2002 Location: The Netherlands Age: 41
Member: 19168 Status: Offline Thanks Meter: 55 | Same Problem by me, I even read the full flash (firmware), bootcore and eeprom from a good SL55 and wrote it to the SL55 with error, still the same! One more thing, It is a version 18 of Telfort NL. it couldn't be booted previousely if I used no testpoint, GND to resistor, but now it boots without testpoint!!! What can be that? |
04-11-2005, 15:05 | #5 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Germany Age: 37
Member: 41076 Status: Offline Thanks Meter: 53 | Of course, because you changed bootcore, so you don't need to connect testpoint to gnd anymore. try to Rehot/reball/change DialogIC or to change PA |
04-11-2005, 15:42 | #6 (permalink) | |
Member: 84992 Status: Offline Thanks Meter: 0 | Quote:
Excuse my ignorance/newbie could you explain further Rehot/reball/change DialogIC or to change PA many thanks | |
04-11-2005, 19:41 | #7 (permalink) | |
Member: 41076 Status: Offline Thanks Meter: 53 | Quote:
alarm in the switched off mode in p910i | drgopoos | Sony Ericsson | 0 | 07-21-2005 18:52 |
3310 switching off problem | yandbass | Nokia Hardware & Hardware Repair | 3 | 07-20-2005 21:08 |
1100 switching off problem? | gsmsikar | UFS2 + UFS3-Tornadoflasher | 2 | 11-23-2004 16:39 |
SL45 switching off problem | Ahmed Jundy | x1x to x45/x50 | 0 | 05-12-2004 20:43 |
BE5 switch off problem | ritzthom | Alcatel & TCL Old Models | 0 | 12-31-2002 14:26 |
