Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > E-Gold Based Phones
E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section.
Old 03-06-2003, 01:16   #1 (permalink)
Member: 23705
Cool Upload Ringtones to C55
Hi All,
Does anybody know how can I upload a poliphonic ringtone into my C55 via data-cable?
I tried a lot of things, but all unsuccessfull.
Thanks,
David.
Old 03-06-2003, 04:28   #2 (permalink)
Sixth`SenSe's Avatar
Member: 12495
Thanks Meter: 2
use java activator for x50/x55 by jordik
so use DES 2.6.7
copy paste to folder ringtones in DES (10 kb or under)
Old 03-08-2003, 18:19   #3 (permalink)
Member: 23277
If you have an original cable ??? whit your c55 use this
Open your cable whit a knife or something like this:
http://www.gsm-multifund.com/Anleitu...mt50/bild1.jpg
Then connect 3 1.5 volt battaries whit eachother and wires at the end like this
http://www.gsm-multifund.com/Anleitu...mt50/bild2.jpg
Then connect the Plus (+) whit pin 1 (you can slide the wire in at the back) and - pole in the shaft from pin 2. Make sure you do this job while your cable is unplugged. (for safety)
http://www.gsm-multifund.com/Anleitu...mt50/bild3.jpg
ok now you can use this program to unlock.
http://www.gsm-multifund.com/Downloa...0-java-new.zip
(to test if your battaries are connected you can look at your phone and when you see that your battary is charging then it is ok.)
Good luck
4 questions ... please mail/post sometin
grtz DeNMaN
Old 03-09-2003, 14:37   #4 (permalink)
Member: 23705
Hi Dennis,
I made it, but still not work (The SW remains scanning). Instead of the three batteries I used a 5V power supply. Is that a problem?
Doubts:
Should I have the mobile turned off in this process?
Should I have the mobile with the SIM card?
Can I do this with the Siemens Original data cable?
Is there difference to use COM1 or the COM2 of the PC?
My SVN is: 15
Thanks,
how to upload ringtones to 7250i ? the_frightener Nokia Multimedia 4 10-17-2003 15:47
how to upload games to c55 a55 s55 sl55 medo E-Gold Based Phones 5 09-05-2003 15:57
How to upload ringtones to T720?? Kot Motorola P2k 0 08-06-2003 13:32
how to upload ringtones to A55 arema E-Gold Based Phones 1 05-08-2003 23:29
Help! How to upload ringtone to Samsung A800 using a T100 cable? petit_jack VLSI, Conexant, Skyworks and Old Models 0 03-20-2003 09:10
Page generated in 0.22733 seconds with 8 queries
