S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here. |
11-12-2005, 02:03 | #1 (permalink) |
No Life Poster Join Date: Aug 2002 Location: BULGARIA Age: 53
Member: 14868 Status: Offline Thanks Meter: 44 | Secured update not possible, device not prepared. - how to avoid it? now phones are alive, but with ver.04 so i want to upgrade them to v.50, but... Winswup 4.09 always gave me this error message - "Secured update not possible, device not prepared." How to prepare the phones for upgrade??? ps. solved - PapuaUtils - > forgot to make freeze WBR Last edited by Stoyan; 11-12-2005 at 02:13. |
08-17-2008, 18:10 | #2 (permalink) | |
Junior Member Join Date: Aug 2008
Member: 839890 Status: Offline Thanks Meter: 0 | what you means that "PapuaUtils - > forgot to make freeze" how to do? Quote:
08-18-2008, 03:45 | #4 (permalink) |
Member: 839890 Status: Offline Thanks Meter: 0 | Model: SIEMENS CX7A 25 lg8 Phone is in "Normal Mode". SecurityStatus: "FactoryMode" IMEI: 356424000913451 HWID: 5000 Accumulator Voltage: 3864 mV. Checking values entered and necessary blocks... IMEI: 356424000913451 Code(05): OTP is Closed for write Code(0D): Keys is stored in BCORE In this mode Freeze not possible! |
08-20-2008, 07:01 | #6 (permalink) |
Member: 839890 Status: Offline Thanks Meter: 0 | I have tried in service mode, but it seems failed Boot in "Service mode" Ok Awaiting Power On phone... Getting Information: Model: SIEMENS CX7A 25 lg8 Phone is in "Service Mode". SecurityStatus: "FactoryMode" IMEI: ? HWID: 5000 Accumulator Voltage: 4121 mV. Getting Information: Model: SIEMENS CX7A 25 lg8 Phone is in "Service Mode". SecurityStatus: "FactoryMode" IMEI: 356424000913451 HWID: 5000 Accumulator Voltage: 4107 mV. Checking values entered and necessary blocks... IMEI: 356424000913451 Code(05): OTP is Closed for write Code(0D): Keys is stored in BCORE In this mode Freeze not possible! |
11-01-2009, 23:57 | #8 (permalink) |
Freak Poster Join Date: Nov 2000
Member: 2515 Status: Offline Thanks Meter: 4 | I had a problem with WINSWUP secured update not possible I wanted to upgrade my CX70 version 50 to version 56 (0400) Czech. WINSWUP CX70560400 stopped always at 33% (AMD Flash). Phone was not working, so I had to connect test point to switch, with PapuaUtils make R65> Falsh>Carry out CALC.. +SKEY +BootKEY and send.... [is selection R65 ok for CX70 ? I do not know...] But then in WINSWUP(version 4.12) was not possible to update it... because message secured update not possible In the menu was not option to change this [may be extract or convert to any other winswup.exe + xbz file??] So I solved this by PapuaUtils Conver > Extract XBZ from serviceWinSWUP32, then Create Base WinSwup32+XBZ and this SWUP(version 4.14) was successful in flashing. BTW-this created winswup from PapuasUtil has got option update-concept with two possibilities (1. was selected): 1. Force BSL, unsecured mode 2. Force Secured Mode, customer mode Phone is now sw56. maybe that winswup version is important (4.12 was not good for my CX70 AMD flash) so try to use another/higher version of WINSWUP or try to use/make somehow/ pack of: [new version of WINSWUP.EXE + XBZ flash content].... and use this to update your phone... <BR to=All> |
Sagem X5-2 with Security Code??!!How to unlock it | Maurone | ARM9 BASED M62 / M62+ | 10 | 01-18-2011 08:23 |
I have lost the security code.....how to restore it??? | deftoned | Nokia Base Band 5 ( BB-5 ) | 1 | 10-20-2005 00:43 |
How to avoid contact service in 6610i 100%? | hooi76 | UFS2 + UFS3-Tornadoflasher | 11 | 07-22-2005 04:56 |
A3618 security code. How to read it? | barvik | Sony Ericsson | 0 | 11-10-2002 14:29 |
