S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here. |
11-05-2004, 15:06 | #1 (permalink) |
Registered User Join Date: Sep 2003 Location: Palestine Age: 50
Member: 39208 Status: Offline Thanks Meter: 152 | After cut the test point, Boot file not accepted I have MC60 , i cut the test point normally, try to unlock it using freia 9 i got the folowing : FREIA - Engine build 9, Frontend build 3 Thanks goes out for the following: Maxim, Rolis, Sergey, PapaJoe, Lead, TheWizard, Jozso (for hardware and cable support and of course beta testing), Nico, Victor, Pinker, Tom, and all the others who supports ... MISC_calibrate_delay : 1179.64 BogoMIPS COMM_LoadBoots : selected phone family is 10 TTY_OpenCOMPort : opening COM1 COMM_IsBootRunning : bootcode does not seem to be running COMM_LoadBoots : Waiting to power on the phone ... COMM_LoadBoots : phone is powered on COMM_LoadBoots : internal loader version is 01.00 SEC_BCDIMEIToNormalIMEI : invalid decoded IMEI COMM_LoadBoots : EEPROM IMEI (17) is corrupt COMM_LoadBoots : original IMEI is 35343400134616 (locked) COMM_LoadBoots : found SIEMENS MC60 lgX vff (1) COMM_LoadBoots : flash ids are 00012212 [00000000] - FFFF COMM_LoadBoots : phone ids are 1A04D0AC [00000000] COMM_UpdateIMEIBlocks : update is not accepted Why BOOT FILE NOT ACCEPTED ...? pls help Note That SW version is : 10 Last edited by Byte; 11-05-2004 at 15:23. |
11-05-2004, 18:00 | #2 (permalink) | ||
No Life Poster Join Date: Aug 2003 Location: BiH
Member: 37090 Status: Offline Thanks Meter: 42 | Quote:
11-06-2004, 08:33 | #3 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Baltchik,Bulgaria Age: 50
Member: 47236 Status: Online Thanks Meter: 58 | find good full from live phone or look here and search thare is good fubu www.gsm-free.com and use freia9 162c for flashing |
11-08-2004, 18:08 | #4 (permalink) |
No Life Poster Join Date: Feb 2003 Location: TelServisHalo,Loznica, Serbia Age: 53
Member: 21365 Status: Offline Thanks Meter: 92 | I have exactly... ...same prb with one mc60 v10, and You can't write any deam thing to these phone so idea about write full flash etc. don't have results (update not acsepted) I allredy try everithing (check lines under CPU-ok, reball CPU-ok, new CPU from working phone-ok. any version off Freia....) My phone is now in the box and if You finde some solution pls let me now. Cheers. |
11-08-2004, 19:01 | #5 (permalink) |
Registered User Join Date: Jul 2004 Age: 39
Member: 74514 Status: Offline Thanks Meter: 0 | I have the same problem not 1 time -))) first flash it with good fullflash (fubu for example) v4 or v10 {size 14 336 k} try to flash bootcore (select in freia MC60 boot, after flashing bootcore you must write fullflash) |
11-08-2004, 19:05 | #6 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Canary Islands Age: 53
Member: 17351 Status: Offline Thanks Meter: 41 | No no dont flash it You just have not made a decent cut on the testpoint. You need to go deeper then it will accept the bootfile. Flashng will not unlock the phone! |
11-08-2004, 19:17 | #7 (permalink) |
Member: 74514 Status: Offline Thanks Meter: 0 | ..Yes cut more deeper and you have new problem : navigation button not work-))))) freia connect phone - it mean that testpoint -ok freia said : COMM_UpdateIMEIBlocks : update is not accepted after correct flash (bootcore and fullflash v4) update will be accepted |
moto v3r dead after cutting the test point | sesime | Motorola Hardware Repair | 2 | 05-14-2009 20:36 |
boot file not accepted ( siemens c45) need test point | leroi | x1x to x45/x50 | 5 | 03-25-2005 15:09 |
A55: boot file not accepted after TP | Sp2000 | E-Gold Based Phones | 8 | 08-29-2004 07:07 |
a50v11 boot file not accepted pls help | lypen17 | x1x to x45/x50 | 10 | 04-12-2004 19:35 |
cannot unlock c60 with freia 9 ,test point cuted ,BOOT FILE NOT ACCEPTED. | crossings | E-Gold Based Phones | 9 | 01-19-2004 17:20 |
