S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here. |
11-27-2006, 15:22 | #1 (permalink) |
No Life Poster Join Date: Feb 2002 Location: burning phones
Member: 9700 Status: Offline Thanks Meter: 62 | Any idea for EL71 dead after papuas 0.9.1.a I have tried to extract hash by normal way and I got this message: Press Red key ! Autostart... ÜTransfer Boot... BOOT geladen... Pause 2 Sec... Getting Information..... FlashID: 0089,887E (64Mb) BCORE Clean ! OTP ESN: ABF6A044 OTP IMEI: 358941003027284 Teste Daten Bus D0..D15...OK. Teste Adressen A2..A22...OK. Lese EELITE Blöcke... EELITE Blöcke nicht gefunden! Lese EEFULL Blöcke... EEFULL Blöcke nicht gefunden! EEP Blöcke nicht gefunden! Boot ist open.. Es gab Fehler! then I have checked by error the "NEW BCORE V22,V11,V7..." option, the log is: Press Red key ! Autostart... ÜTransfer Boot... BOOT geladen... Pause 2 Sec... Getting Information..... FlashID: 0089,887E (64Mb) BCORE Clean ! OTP ESN: ABF6A044 OTP IMEI: 358941003027284 Teste Daten Bus D0..D15...OK. Teste Adressen A2..A22...OK. Lese EELITE Blöcke... EELITE Blöcke nicht gefunden! Lese EEFULL Blöcke... EEFULL Blöcke nicht gefunden! EEP Blöcke nicht gefunden! Lese Segment A0000000 BCORE... Segment BCORE gespeicher ABF6A044_A0000000_BCORE_061127142617.bin Neue BCORE Version: "main_1.0_V11 " Fehler err:FFFF ęîėāíäû įāīčņč ņåãėåíōā A0000000! Fehler beim lesen des BCORE! Bitte wiederholen! Falschen HASH eingegeben! Now, the EL71 is dead, no beep and no service mode, and I don't have much more options for repair it because I can't connect Any idea would be appreciated wbr thecult |
11-27-2006, 15:52 | #2 (permalink) |
Registered User Join Date: Jan 2005 Location: TuNiSiA Age: 43
Member: 111457 Status: Offline Thanks Meter: 967 | @thecult check X85 in BCORE Tab , then check only Pause 2s and do job, post result about Flash type is 100% supported by Papua 091 or higher for Unlock, repair BCORE not work yet |
11-27-2006, 17:53 | #3 (permalink) |
Freak Poster Join Date: Jul 2005 Age: 46
Member: 163721 Status: Offline Thanks Meter: 148 | U can repair with this : Segment BCORE gespeicher ABF6A044_A0000000_BCORE_061127142617.bin Use Vklay and the s75 bkey Loader Start it with testpoint and write ur old bcore back then calculate skey and bkey send skey and make unlock over the buttons Freia.log or 5008 Unlock Lese EELITE Blöcke... EELITE Blöcke nicht gefunden! Lese EEFULL Blöcke... EEFULL Blöcke nicht gefunden! EEP Blöcke nicht gefunden! this is normal for this phone papua can t read the eeprom on x85 devices i work on it In this Version Check Boot Type all not working functions for x85 are disabled Last edited by Gehstock; 11-27-2006 at 18:09. |
12-01-2006, 21:15 | #10 (permalink) |
Member: 9700 Status: Offline Thanks Meter: 62 | thanks gehstock but bkey field only shows "?" I have entered manually "12345678" in skey and generated has with it, then I have generated bloader for vklay and flashed bcore backup... all fine and now my phone works but I don't know how to unlock , because I can't read bkey until now... can I use bkey generated with "12345678" trick for unlocking phone or I will kill it? thanks , really thanks wbr thecult |
12-02-2006, 01:10 | #12 (permalink) | |
Freak Poster Join Date: Oct 2001
Member: 7011 Status: Offline Thanks Meter: 0 | Quote:
can you tel me how to fix my bcore i have a backup but i dont know how to repair with v-klay i have v-klay3.0 | |
12-03-2006, 12:02 | #14 (permalink) |
Member: 9700 Status: Offline Thanks Meter: 62 | for more information: I have tried also with bsreader and x65flasher (tried to read hash) ... both gives me hash: FFFFFFFFFFFFFFFFFFFFFFFFF I can't get valid skey |
CXT70 dead after papuas.... | Dream gsm | S-Gold Based Phones | 4 | 06-25-2010 01:13 |
is there any Emulator for play engage games in symbian 9.1 phones like N71,3250,n73,. | rasoul_s | Nokia Multimedia | 0 | 03-18-2007 23:38 |
s68 and papua 0.9.1 or 0.9.2 | ciclonjvf | S-Gold Based Phones | 4 | 11-30-2006 23:40 |
Any solution for 81xx dead after GDFS flashing? | ayujahndon | LG | 9 | 03-28-2005 20:48 |
Any idea for A35 v18 | lotfiac | x1x to x45/x50 | 5 | 02-12-2002 06:14 |
