Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here. |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jun 2007 Location: ma / fr
Member: 521295 Status: Offline Sonork: 100.1607380 Thanks: 44
| helo, help me i need to write bcore or full flash to el71.when i turn it on. i have just a beep plese help |
| | #4 (permalink) |
| thanx for replie . i forgot i d'ont have data cable to transfer java esn calculator to phone . any solution with unlock cable? if no give me tp picture please. thnx in advance |
| | #8 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2005 Age: 29
Member: 145088 Status: Offline Thanks: 16
| for me;i can't flash this EL71 i'm getting every time error, using winswap or X65flasher or V-klay the phone hang on start-up, i already try to change from ELF1 to EL71 because it is detected as ELF1 using x65flasher-2103 but with no success any one have an idea? how to solve this problem thanks in advance |
| | #9 (permalink) |
| tp is detected but X65flasher give errror when i try writen flash. papua dedecte tp.but no solution for flashing el71 with... where are you siemens MASTER? |
| | #10 (permalink) | |
| Moderator ![]() Join Date: Dec 2006
Member: 416908 Status: Offline Thanks: 3
| Quote:
...try to use baudrate 115200 bauds with X65Flasher or Papuautils. Because you have ELF1 bootcore, you need use fullflash with the same type (normal flashing - without bootcore); flash with the EL71 fullflash (and write bootcore using x65flasher /b with the DOS command), or change manually bootcore name and force writing new flash with the SWUP firmware. One suggestion: not use write "new bootcore" option from Papuautils, because you don't have possibility in the future to make in the good condition the other fullflash or firmware upgrade. See bellow how to change bootcore in the good condition: ELF1 flash to EL71? dagos | |
| | #11 (permalink) | |
| Quote:
dagos | |
| | #12 (permalink) |
| now i have other problem (in attachements) i have this problem after (reckalk all key in flash) &(new bcore ) and when i push flash bitton in x65 flasher it say connection lost ![]() i need help |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| What about EL71 and EF81? Impossible to unlock? | James_S | NON Siemens Brand (ODM Phones) | 6 | 06-04-2007 20:20 |
| Read and write Bcore | linfen | DreamBox | 2 | 03-27-2007 19:56 |
| Papua v0.9.1acan't repair Bcore in EL71 | BouRRi_GSM | S-Gold Based Phones | 30 | 12-03-2006 10:12 |
| how to repair damaged bcore for c72 ? | Black_Attack | S-Gold Based Phones | 3 | 12-02-2006 13:31 |
| CX65 Dead - IMEI not in BCORE! | .::AkhavanGSM::. | E-Gold Based Phones | 3 | 07-16-2006 16:32 |
